Author Topic: How do you reduce voltage from 12 volt to 9 volt?  (Read 1842 times)
Hoagie_one
  • Um....whats a cabinet
« on: January 27, 2009, 04:43:06 pm »
I have a set of powered PC speakers, but do not have the power brick.  It says it requires 9v AC in, and since I'm just going to use the amp inside to power my original cab speakers, I want to just power it directly from my PC's internal power.  What do I have to solder in to reduce the voltage?
Also, does internal PC power run AC or DC?
csa3d
  • Will game for food
    • Galaxian Mame Conversion
Re: How do you reduce voltage from 12 volt to 9 volt?
« Reply #1 on: January 27, 2009, 04:56:22 pm »
Pc power supplies serve out DC voltages.  It would probably be easier to go to RadioShack and pick up a Walwart (plug that fits yours which is rated 9v) and then use a SmartStrip power supply.  The smart strip will turn on and off with the power of your computer.  This setup will prove to be the easiest, and probably only set you back about 30$ total.
-csa
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #2 on: January 27, 2009, 05:20:23 pm »
Actually, you don't want to run it from your PC power supply.  It will place additional work on the PS and eventually fail because of that.
Hoagie_one
« Reply #3 on: January 27, 2009, 05:30:20 pm »
Whats funny is the price for a new AC adapter is generally more than a whole new set of generic PC speakers.
Any other alternatives?
« Reply #4 on: January 27, 2009, 06:27:17 pm »
buy a new set of generic PC speakers
Hoagie_one
« Reply #5 on: January 27, 2009, 06:36:35 pm »
lol, yeah
ghettodish
  • Last login:October 21, 2017, 03:41:58 pm
« Reply #6 on: January 27, 2009, 10:41:48 pm »
edit...was off topic
« Last Edit: January 28, 2009, 01:08:14 pm by ghettodish »
Thenasty
  • Last login:Yesterday at 04:30:09 pm
« Reply #7 on: January 27, 2009, 10:53:22 pm »
Use 9V batteries  :dunno
Free VGA Breakout Cable
BobA
  • What Me Worry?
« Reply #8 on: January 27, 2009, 11:24:50 pm »
The power requirement for is PC speakers was 9V AC.    A 9V AC wall wart looks like the only way to go.
  • Last login:November 30, 2025, 12:59:41 am
« Reply #9 on: January 27, 2009, 11:53:15 pm »
Tell the 12Volts it has to pay taxes still. That should get it to about 9Volts.
Blanka
« Reply #10 on: January 28, 2009, 02:17:35 am »
Use a 7809 voltage regulator with a heatsink. It can handle 1 or 1.5 ampere, depending on the model.
http://nl.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=5164812
Oops: READ, it says AC
BUT,
9 V AC is often regulated to 12V DC. Amplifiers always run on DC. Make a picture of the circuitboard.
« Last Edit: January 28, 2009, 02:27:05 am by Blanka »
