Author Topic: Light gun market research question.  (Read 43032 times)
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« on: January 19, 2009, 04:38:47 am »
Hi,
I would like to know the following, from users of light guns or potential users:
What distance from the screen would you normally want to use a gun?
If you were forced to use a longer distance, how far would you consider is "too far" from the screen to be comfortable with?
Thanks for any help.
Andy
CathalDublin
  • Last login:March 01, 2024, 04:05:23 pm
Re: Light gun market research question.
« Reply #1 on: January 19, 2009, 05:03:36 am »
Personally 3foot back from machine, so possibly 3.5/4feet from screen
Defender(multiwilliams), SF2CE
Whirlwind, Lethal Weapon 3
thatitalian
  • The Revolution Is Coming...
« Reply #2 on: January 19, 2009, 05:31:19 am »
Again, approx 2.5-3 foot away from the screen.
Blanka
« Reply #3 on: January 19, 2009, 07:01:42 am »
I think it would be best if the gun works as BT mouse. In that case the gun is usefull for MAME and for consoles/pc's (broader range of customers), which brings me back to the answer of the question:
For cab use, 1 meter will be maximum (your bwittish right? no feet there I thought), but for console use 2-3 meters will be common.
But the corner-2-corner angle of two lines from the gun to the corners of the screen will be always similar I guess.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #4 on: January 19, 2009, 11:08:35 am »
Between 2 - 4 ft
doctorhifi
  • Last login:July 05, 2013, 08:21:41 am
    • My cabinet
« Reply #5 on: January 19, 2009, 11:31:47 am »
2-3ft
AndyWarne
    • Ultimarc
« Reply #6 on: January 19, 2009, 03:04:23 pm »
Thanks for your replies. This is close. The proximity to the screen is a real challenge for light-gun design.
Andy
Ginsu Victim
« Reply #7 on: January 19, 2009, 03:22:17 pm »
Just the fact that you're asking has me excited. I can't wait to see what you're up to :)
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
« Reply #8 on: January 19, 2009, 04:02:24 pm »
Ohhhhhhhh snap..
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
ark_ader
  • I glow in the dark.
« Reply #9 on: January 19, 2009, 04:13:37 pm »
Bet it's not cheap....
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #10 on: January 19, 2009, 04:43:05 pm »
Probably depends on whether it's 1 player or 2. 1 player, probably about 2 feet. 2 players, probably closer to 3.
markc74
  • Last login:Yesterday at 11:25:45 am
  • Flipping out
« Reply #11 on: January 20, 2009, 07:51:10 am »
2 - 4 feet.
As long as its not as bad as the TopGun...
scriptfactory
  • Last login:February 18, 2009, 04:31:14 pm
« Reply #12 on: January 20, 2009, 09:30:25 am »
Co-signed.
Definitely interested in this.
sWampy
  • Last login:February 02, 2010, 04:23:40 pm
« Reply #13 on: January 20, 2009, 09:39:56 am »
I would think the distance would be proportional to the screen size.  19" you have to be close, 26" not so close, 50" not close at all.
Ginsu Victim
« Reply #14 on: January 20, 2009, 09:44:58 am »
Yeah, that's why I said 2 - 4 feet....I only have a 19" monitor.
AndyWarne
    • Ultimarc
« Reply #15 on: April 01, 2009, 04:07:07 pm »
OK just to follow-up.
A more direct question: would the following minimum distances be considered acceptable?:
28 inch monitor: 3 feet
19 inch monitor: 2 feet.
Andy
Ginsu Victim
« Reply #16 on: April 01, 2009, 04:08:57 pm »
Sounds good to me.
zaktallica
  • Last login:September 18, 2019, 07:44:21 pm
« Reply #17 on: April 01, 2009, 04:10:33 pm »
yup thats perfect
jeffremiller
  • Last login:January 03, 2011, 05:55:16 pm
  • No matter where you go... There you are...
« Reply #18 on: April 01, 2009, 04:20:22 pm »
2-4 feet would work for me with a 29" screen.
Are you taking into consideration a smoked plexi or glass over the CRT?
I had pretty much given up the thought of guns on my cab.
"If all wishes were gratified, many dreams would be destroyed." - B. Banzai
TAG
  • Last login:May 23, 2014, 05:52:05 pm
« Reply #19 on: April 01, 2009, 05:14:47 pm »
Sounds like it'd work on my set-up!
I may not have gone where I intended to go, but I think I have ended up where I needed to be.
-- Dirk Gently
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
« Reply #20 on: April 01, 2009, 05:18:18 pm »
19" monitor for me, but have lightly-smoked glass in front.
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
Flake
  • Last login:January 11, 2025, 01:16:20 pm
  • I am Evil Homer....I am Evil Homer....
« Reply #21 on: April 01, 2009, 06:00:51 pm »
This is exciting!  I have been sitting on the sidelines waiting for a better light gun technology to appear.  Hopefully this is an improvement over the existing tech (hopefully the guns look cool too!).   :cheers:
TheShanMan
« Reply #22 on: April 01, 2009, 06:10:57 pm »
Is it too early to ask what advantages (or disadvantages) this potential light gun would have over that sonic gun (which so far is vaporware). I've been holding off on buying a light gun product in anticipation of that sonic gun, but it would be nice to have another solid option to consider. ;D
DJ_Izumi
  • Last login:November 04, 2023, 04:19:22 pm
« Reply #23 on: April 01, 2009, 07:19:43 pm »
I think it would depend on the screen.  I use a 19" screen for my light guns so 1 meter (3 feet) is roughly at what I play with.  I had a roommate once upon a time with a 36" CRT, we did 2 meters (6 feet) then.
rbarr110
  • Last login:January 28, 2026, 12:10:10 pm
  • I already built my own arcade controls!
« Reply #24 on: April 01, 2009, 07:47:32 pm »
2-4 feet, similiar to most "real" arcade machine layouts.
Organic Jerk
    • OmeshPersaud.com
« Reply #25 on: April 01, 2009, 08:04:14 pm »
If it's of consistent quality and stability at the distance, that sounds great...
Burn4Evr
  • Last login:January 20, 2016, 05:49:14 pm
« Reply #26 on: April 01, 2009, 08:04:47 pm »
How often have you seen cheap in this hobby?
I don't care what the exact product is, I wanna be able to use guns with my cab.
To me value is much more important.... and Andy hasn't disappointed me yet.
Personally I use a 36in TV, 5 feet seems comfortable. My rig is hell to get guns to work on though (guncon even hates my CRT, rolling x, I believe to my TVs auto upscaling))
DJ_Izumi
« Reply #27 on: April 01, 2009, 09:34:17 pm »
This is why when I build a cab it's going to JUST have a PS2 inside of it, controllers wired up to the panel but wire PlayStation game ports to the front area where a coin mech would normally be where you can simply plug in DualShocks, Guncons, or any other specialty PS2 controller.  (USB ports and composite video jacks for guncons as well on the front.
Just trying to figure out if you can 'seperate' the optical drive from the system and relocate itso as to have a drive tray on the front too.
Bam.  Connect gun.  Insert disk.  Save Astigos Island from Zagoria.  No fuss, no muss.
« Last Edit: April 01, 2009, 09:35:59 pm by DJ_Izumi »
Burn4Evr
« Reply #28 on: April 01, 2009, 10:06:07 pm »
You have other options available to you on the PS2 rather then relocating the DVD drive. Mainly based on the HDDLoader systems. Just do some research, you can get your PS2 rigged up for pretty much free.
Its based on running off a hard drive rather then a optical drive.
Since it doesn't apply to this site too much I'd rather avoid talking about it on here but send me a PM if you are intrested and I'll give you my email address, and at least point you in the right direction
severdhed
  • RIP Dinosaur Hippo
« Reply #29 on: April 01, 2009, 11:56:13 pm »
i had a 26" tv with a playstation 2 gun cabinet setup a while back and i stood about 3 to 4 feet back.  my current cabinet has a 19" LCD monitor, so no light guns for me.
i am contemplating trying to set up a ps2 gun cabinet again though... although if there was a good gun option for cabinets with LCD monitors, i wouldn't have to do that
DJ_Izumi
« Reply #30 on: April 02, 2009, 01:47:44 am »
Problem is, HDDLoader ONLY supports PS2 games (The PS1 CPU is used as the HDD controller in PS2 mode, so it can't be a PS1 CPU -and- a PS2 I/O controller at the same time).  Since there are great PS1 light gun games including Point Blank, which I've made the effort to buy the ligit copies of their game disks, I'd prefer to stick with having the ability to play optical disks.
« Last Edit: April 02, 2009, 05:08:41 pm by DJ_Izumi »
TPB
  • Last login:March 01, 2021, 09:12:52 pm
« Reply #31 on: April 02, 2009, 09:30:40 am »
« Last Edit: April 02, 2009, 09:32:21 am by TPB »
Todd H
  • Last login:August 26, 2024, 02:23:32 pm
  • It's Gameday!
« Reply #32 on: April 02, 2009, 09:34:18 am »
Ooooooohhhhh...Andy's doing market research on a light gun! I sure hope this means he's going to release one to the MAME community! Hopefully it works with an LCD monitor (fingers crossed).  :cheers:
swamprat96
  • Last login:January 10, 2012, 03:29:46 pm
« Reply #33 on: April 02, 2009, 07:50:14 pm »
the range Andy suggests is spot on. I'm in
mlalena
  • Last login:June 12, 2021, 12:31:44 pm
« Reply #34 on: April 02, 2009, 08:33:57 pm »
In case Andy is still looking for opinions...
For games like Police Trainer and Area 51, I stand as far back as the gun cord will let me and I would still like to be further back. I like the challenge.
If a gun is going to use a quality cable (with strain relief) instead of a simple USB cable, then longer is better since there is no way to extend the cord. Also, gun cabinets tend to have mount the cables where most people put their keyboard drawer. MAME cabinets will probably have to mount the guns off to the side out of the way so an extra foot of cable might be necessary.
DJ_Izumi
« Reply #35 on: April 02, 2009, 08:53:46 pm »
Standard USB cables arn't necessarily a bad way to go either.  They're certianly good and universal and it's easy to find replacement plugs or extention cables.  I think 'Ease Of Maintance' is something to considder.  I think in a home arcade, the risk of the cable getting damaged isn't signifigant.
Having a gun survive falling onto the floor when it slips out of the hands of an excited and frantic player would be a more pressing issue I think.  I'm still fearing a crack in one of my guncon shells one of these days. :/
wooowman93
  • Last login:September 04, 2014, 03:56:02 pm
« Reply #36 on: April 02, 2009, 09:05:55 pm »
Oh and don't make it cost too much please
Shoegazer
  • Last login:May 10, 2015, 10:37:58 am
    • NonMAME - The ultimate site for the OTHER arcade emulators!
« Reply #37 on: April 03, 2009, 12:03:20 am »
Well, since it looks like we could be waiting forever for the Sonic Gun System at this point, I'm glad to see Andy take charge with this one.  Andy's/Ultimarc's products (and service) have never disappointed, and he actually produces more product than he hypes.  I for one am very happy and excited to see what this turns out to be, and I'm sure to be among the first to buy when it's released.
My biggest wish is for the guns to be arcade quality (unlike the cheap crap HKEMS stuff), and to feature real recoil.  Now THAT would be great.
Shoegazer
« Last Edit: April 19, 2009, 09:23:58 am by Shoegazer »
NonMAME: Your best source for the OTHER arcade emulators!
http://nonmame.retrogames.com
smalltownguy
  • Last login:February 27, 2026, 07:59:15 pm
« Reply #38 on: April 03, 2009, 12:21:15 am »
After researching this to the N'th degree, I'm prepared to pay whatever it takes to get ahold of whatever Andy's working on. Undoubtedly whatever the final product is will underpromise and overdeliver.
Those measurements are perfect for me, BTW.
I too had written off any real possibilities for light gun use. Can't wait to see what's cooking here!
briktop11b
  • Last login:December 24, 2009, 12:19:33 am
« Reply #39 on: April 03, 2009, 12:25:48 am »
I am in! I amso excited that this is even being discussed. I had some topguns. Pain in the butt to get to work and then when they do the distance is a turn off. Act labs are to high. I dont know if anybody has asked but are you gonna make these lcd compatable or just crt compatable? I would be happy as a hippo with crt as long as they are user friendly, durable, and the distance you talked about sounds excellent. If you can do this and keep the price reasonable this is a very smart move on your part because this is what a lot of people around here have been waiting on for a long time. Very exciting. :applaud:
