December 20, 2025, 05:29:13 am
When you refresh your games list, what happens?I ask because the emulator behavior sounds like what happens when the command line contains the wrong rom name or non-existent rom.Did you move the rom directory or rename roms AFTER you setup MALA?
Quote from: Sardu on December 07, 2008, 09:15:59 pmWhen you refresh your games list, what happens?I ask because the emulator behavior sounds like what happens when the command line contains the wrong rom name or non-existent rom.Did you move the rom directory or rename roms AFTER you setup MALA?how does one refresh the game list?yes I set up this emu and directories after I had MALA running for a while.
What do you see when you open that gamelist in the gamelist editor?
