Author Topic: Setting up multipule emus in MLA and have come across a proble with SNES  (Read 3356 times)
pharoah007
  • Last login:June 29, 2017, 07:27:26 pm
  • Why buy it when you can BUILD it!
So I am setting up a few emulators in MALA and learning as I go. I have 3 or 4 working now with there respective layouts switching to the emulator selected.
My SNES (SNES9X) emulator seems to have some problems tho. When I set up mu SNES emulator, The art sections and the game list sections are blank. The bottom of the screen still says 1 or 933 roms (or whatever the number is of roms that I have) and I can scroll throughout the roms list and hear sound effects of next rom being selected and the number will change to 2 of, 3 of ,4 of ect. So the roms are there but there names are not showing up on the list.
When I do launch a rom "blind" the Emulator starts but says failed to load rom. The emulator stays open and if I go to "file" "open Rom" I can open the rom and play no problem.
Anyone have some insight on my problem?
TIA
Sardu
  • Last login:April 08, 2023, 05:45:54 pm
Re: Setting up multipule emus in MLA and have come across a proble with SNES
« Reply #1 on: December 07, 2008, 09:15:59 pm »
When you refresh your games list, what happens?
I ask because the emulator behavior sounds like what happens when the command line contains the wrong rom name or non-existent rom.
Did you move the rom directory or rename roms AFTER you setup MALA?
pharoah007
« Reply #2 on: December 08, 2008, 08:46:26 am »
how does one refresh the game list?
yes I set up this emu and directories after I had MALA running for a while.
Sardu
« Reply #3 on: December 08, 2008, 11:36:43 am »
I'm not sure if this is the solution but it doesn't hurt to try.
With MALA running(SNES), right click anywhere and select  "Refresh Main Game List" from the pop-up menu.   MALA will populate the list with Roms it finds in the folder YOU set in the setup menus.
pharoah007
« Reply #4 on: December 08, 2008, 06:02:24 pm »
Thanks for the help man. I tried refreshing the list and it seem to pick up the roms, compiles a list with a total number and I can scroll thru the numbers,,,,but there is no "text" where the list needs to be.
Could I be missing a "font"?`
Sardu
« Reply #5 on: December 08, 2008, 07:17:12 pm »
I think by default, Mala uses ARIAL font.
You can change what font is used using the malalayout application.  Make sure the list is set to "text" instead of image.
pharoah007
« Reply #6 on: December 12, 2008, 08:49:51 pm »
Hummm no Joy there either. Frustrating for sure.
loadman
    • MaLa
« Reply #7 on: December 12, 2008, 09:46:47 pm »
What do you see when you open that gamelist in the gamelist editor?
pharoah007
« Reply #8 on: December 13, 2008, 10:07:34 pm »
Not sure how to run the game list editor. I will do some research into how and get back to you when I figure it out.
Thank you.
pharoah007
« Reply #9 on: December 14, 2008, 02:45:31 pm »
So I have been playing around to no avail.
I got this window (pic) up and it says that I have 757 games, however, none show up on this list either.
http://i4.photobucket.com/albums/y145/pharoah007/sneslist.jpg
am I on the right track?
