Author Topic: How long does a CRT keep its' CHARGE?  (Read 29484 times)
SnotRockit
  • Last login:October 07, 2008, 08:00:11 pm
  • Stickin' with the classics!
    • A.J.'s Place
« on: September 10, 2008, 03:18:13 pm »
I'm going to attempt to change the chassis (E07) on my CRT and so I need to remove the old one. I was just wondering how long does a CRT hold its' charge? I have looked at the steps required to discharge the CRT and it's got me a little scared...all this talk about 30,000volts, etc.
The last time this CRT got any power was about 1 week ago...(to test it). It has been unplugged since then. Is there still a charge in the CRT and if so, could it still be as high as they say (ie. 30,000v)? I'm just nervous about even discharging it.
Any help is greatly appreciated. Thanks.
SnotRockit
Re: How long does a CRT keep its' CHARGE?
« Reply #1 on: September 10, 2008, 03:56:12 pm »
Can be quite a while.... and it can rebuild the charge, although at a much lesser current rate, after it has been discharged once or twice.  If you're ever in doubt do the discharge.  If you're too nervous to do the discharge don't try the swap.
Kevin Mullins
    • Me on Myspace
« Reply #2 on: September 10, 2008, 04:13:40 pm »
Rule of thumb is "FOREVER" and "ALWAYS".
(gotta play it safe)
northerngames
  • Trade Count: (+18)
« Reply #3 on: September 10, 2008, 06:14:56 pm »
I would not put my faith in that method your best bet is to do it the right/safe way instead of getting jolted and a doctor bill that cost more then the cab your toying with.
on top of that you may cause even more unwanted damage to other components and make it even worse
« Last Edit: September 10, 2008, 06:17:38 pm by northerngames »
Kevin Mullins
    • Me on Myspace
« Reply #4 on: September 10, 2008, 07:18:35 pm »
Which method would you be referring to ?
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #5 on: September 10, 2008, 08:05:53 pm »
A few things regarding the "discharge"
- first off the charge on the tube is " static" this means one shot .. it will not kill you unless you have a severe heart problem. Biggest danger is dropping the tube because of the shocking surprise.
- next the charge is due to the internal capacitance of the tube, this means that depending on the tube it may last longer or be stronger. It may actualy recharge after being discharged.
Yes Discharge every time you handle the tube... I don't but after years of getting hit I am used to it.
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
Kevin Mullins
    • Me on Myspace
« Reply #6 on: September 10, 2008, 10:13:59 pm »
My point exactly.
And yes.... I have been put flat on my duff by a crt before.
Cameronj
  • Last login:August 03, 2012, 12:59:01 pm
  • I'm a Super llama!
« Reply #7 on: September 10, 2008, 10:48:16 pm »
Yeah my buddy unloaded a monitor on himself a couple months ago. Not knowing anything, he wanted to see what was under the suction cup thingy. :)
Didn't hurt him, but scared the crap out of him.
Kevin Mullins
    • Me on Myspace
« Reply #8 on: September 10, 2008, 11:22:06 pm »
Well, I know a recently charged older 25'er will make you do something to the effect of  "unnnghghgh" and will sit you down for a bit to regain some form of mental state that is measurable.
 :o
So yes, please take proper precautions and properly discharge any crt monitor prior to removing the chassis and or anode lead from the tube regardless of how long it's been unplugged or turned off etc.
And then do so again prior to re-installing any said chassis or anode lead or prior to handling the tube as long as the anode is detached. (that little hole in the tube could bite)
northerngames
« Reply #9 on: September 11, 2008, 12:47:27 am »
by the initial post I was assuming he was asking if it was safe to just pull it without discharging it and therefore putting his faith in it in hopes it died out by letting it sit for x amount of days to lose the power.
therefore I would not suggest using that method understood now?
« Last Edit: September 11, 2008, 12:49:15 am by northerngames »
« Reply #10 on: September 11, 2008, 09:45:57 am »
The rhythm method is not reliable - make sure to dump your discharge properly.
Kevin Mullins
    • Me on Myspace
« Reply #11 on: September 11, 2008, 10:55:48 am »
Ah ... understood now ... and I absolutely agree.
Do not trust ANY crt tube regardless of how long it's been sitting around.
shardian
  • Trade Count: (+23)
« Reply #12 on: September 11, 2008, 11:02:05 am »
I prefer the CN method:
You invite Chuck Norris over, then he will give the monitor a stare icy enough to make the tube crap out all its charge.
For an extra payment, he will instead roundhouse kick the charge out of the monitor.
ahofle
    • Arcade Ambience Project
« Reply #13 on: September 11, 2008, 11:34:29 am »
Yeah I've had good results with the 'pearl neckboard' discharge method.
  • Last login:Yesterday at 03:00:01 pm
« Reply #14 on: September 11, 2008, 12:27:39 pm »
The charge lasts exactly 27 hours and 13 minutes. After that, it's safe to lick all the components in/around/on the monitor.
Nice knowing ya.
« Reply #15 on: September 11, 2008, 01:51:07 pm »
Or you could just stick it in the anode to begin with.
Thenasty
  • Last login:February 13, 2026, 10:27:24 am
« Reply #16 on: September 11, 2008, 02:16:06 pm »
Rule of Thumb.
Always Discharge no matter how many years its been sitting, never assume its discharge, don't ever stick your finger in the hole ;) men always seem to stick something in a hole (it's not a rule, but it's a habit).  :P
Free VGA Breakout Cable
ahofle
« Reply #17 on: September 11, 2008, 02:54:28 pm »
That would be ideal, but unfortunately for me my monitor's purity rings won't allow that method of discharge.  :cry:
« Reply #18 on: September 11, 2008, 02:56:06 pm »
Try swapping the chassis.  Maybe the next one won't have that problem.
ahofle
« Reply #19 on: September 11, 2008, 03:21:23 pm »
I think you're right.  Even a brand new set of shiny caps sure as hell didn't get me anywhere with this one.  :banghead:
« Last Edit: September 11, 2008, 03:24:25 pm by ahofle »
« Reply #20 on: September 11, 2008, 03:26:42 pm »
It's not much use sticking with a monitor that won't give you good B+.
ahofle
« Reply #21 on: September 11, 2008, 03:34:04 pm »
 :laugh2:
you win
« Reply #22 on: September 11, 2008, 03:37:29 pm »
Damn.  I had a great black level joke lined up.
