Author Topic: Do I need an ArcadeVGA Card to use an original monitor?  (Read 1901 times)
Igorr
  • Last login:February 04, 2009, 10:22:08 pm
« on: September 06, 2008, 05:34:34 pm »
I have a Zenith arcade monitor, 25k7193 from a 1991 spiderman game.  I am hooking it up to my computer.  I read a bit here and found out that I need the ArcadeVGA Card.  Do I REALLY need that or can I use something else cheaper?
Thenasty
  • Trade Count: (+17)
  • Last login:January 01, 2026, 04:37:44 pm
Re: Do I need an ArcadeVGA Card to use an original monitor?
« Reply #1 on: September 07, 2008, 12:31:40 am »
no matter which one you choose, you will need a breakout cable (check wiki).
You can always go for what you have now, a regular video card and use a software to drive it down to 15khz (make sure that your card is listed on the supported card list).
Some don't like using a regular one cause of the BOOT/POST of the PC (but there are ways of fixing that).
AVGA = Make life easier
VGA = Needs tweeking and time to make work.
It's really up to you. Read more about it in the WIKI about using a regular card vs avga card.
Free VGA Breakout Cable
northerngames
  • Trade Count: (+18)
« Reply #2 on: September 07, 2008, 06:35:19 pm »
that would be a wells gardner monitor and make sure that the 25K you posted is not a medium res only :badmood:
TOK
  • The Game Always Wins
« Reply #3 on: September 07, 2008, 08:28:58 pm »
Think the 7500 series is medium res... Spider Man is a standard res game.
WG has some funky numbering schemes... I have a 27" K7391. Ken Layton helped me determine what it was. WG has no literature on it and I couldn't find the model number elsewhere. I worked through my connection issues basically by trial and error.
Ummon
  • Trade Count: (+13)
« Reply #4 on: September 07, 2008, 10:03:39 pm »
Read the monitor/video wiki.
Yo. Chocolate.
Stephen Hawking
« Reply #5 on: September 08, 2008, 11:26:29 am »
I have the exact same monitor, I use Soft 15 on it with few issues
EDIT: mines a 27k7193  which I think just means the chassis is for up to a 27" tube
« Last Edit: September 08, 2008, 11:30:13 am by Malenko »
