December 06, 2025, 10:18:50 pm
For some reason, the masters only checkbox doesn't seem to be working. I check it, exit the screen, and the setting doesn't take. Any ideas?
Quote from: Necro on September 06, 2008, 05:14:41 pmFor some reason, the masters only checkbox doesn't seem to be working. I check it, exit the screen, and the setting doesn't take. Any ideas?Known bug. Just close out of Mala, then edit Mala.ini. Change master=0 to master=1. After restarting Mala, refresh the main game list. The checkbox will still not be checked, but it should trim the list to masters only.
Also, my videos are coming out looking like when you try to use a PAL source on an NTSC tv...they play fine in the MALA video previewer app thing, but are all screwed up when played in Mala 1.04 or 1.05b
Great, thanks for the info on the master setting in the ini.Regarding the video, thanks NOP. I had a feeling that was what it was looking like...Loadman, any idea if this will be fixed in mala soon?
