Author Topic: No MAME Clones? Checkbox not working.  (Read 4858 times)
Necro
  • Last login:November 29, 2022, 08:22:22 pm
  • Building a 'Classic' MAME Cab
« on: September 06, 2008, 05:14:41 pm »
For some reason, the masters only checkbox doesn't seem to be working.  I check it, exit the screen, and the setting doesn't take.  Any ideas?
« Last Edit: September 06, 2008, 05:22:45 pm by Necro »
Necro
Re: No MAME Clones? Checkbox not working.
« Reply #1 on: September 06, 2008, 05:34:39 pm »
Also, my videos are coming out looking like when you try to use a PAL source on an NTSC tv...they play fine in the MALA video previewer app thing, but are all screwed up when played in Mala 1.04 or 1.05b
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #2 on: September 06, 2008, 11:43:20 pm »
Known bug.  Just close out of Mala, then edit Mala.ini.  Change master=0 to master=1.  After restarting Mala, refresh the main game list.  The checkbox will still not be checked, but it should trim the list to masters only.
loadman
    • MaLa
« Reply #3 on: September 07, 2008, 07:43:30 am »
This has now been done fixed   ;)
It will be in the next release.
« Last Edit: September 07, 2008, 08:00:23 am by loadman »
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
« Reply #4 on: September 07, 2008, 09:22:40 am »
this may be due to the rescaling done if the display box of your layout isn't an exact multiple of the original .avi resolution.
I ended up fixing that by finding a video that did work just fine, and then did a batch resizing job in virtualDub on all of the videos that didn't work correctly.  I mean it probably should be fixed in mala, but if you're under the gun and want it to work, virtualDub will fix them.
Necro
« Reply #5 on: September 07, 2008, 02:47:16 pm »
Great, thanks for the info on the master setting in the ini.
Regarding the video, thanks NOP.  I had a feeling that was what it was looking like...Loadman, any idea if this will be fixed in mala soon?
loadman
    • MaLa
« Reply #6 on: September 07, 2008, 10:48:29 pm »
Nope  :(  Unless you can suggest a better video engine under Delphi..
Refer here: http://forum.arcadecontrols.com/index.php?topic=82577.msg878004#msg878004
Necro
« Reply #7 on: September 08, 2008, 09:17:35 am »
OK, yeah, in searching for the problem I read how you were restricted due to Delphi on the video engine.  Just wondering if it was actually the engine or something else.  Thanks for the info.
