Author Topic: "BENDERAMA" folding portable bartop (quick video of unfolding 6-28-10)  (Read 217059 times)
Franco B
Re: "BENDERAMA" folding portable bartop (little more progress 1-14-09)
« Reply #80 on: January 15, 2009, 08:15:40 am »
Agreed, awesome paint job :)
I don't blame you for re-doing parts until you are 100% happy with them. It would only niggle you at the end if you looked back at it and wished you had spent the extra time.
Keep it up, I'm looking forward to the next days already  :applaud:
(btw, I don't know if its just me but I can only see three pics from your last post)
  • Last login:Yesterday at 12:39:15 am
« Reply #81 on: January 15, 2009, 08:17:40 am »
Bender is notorious for posts lacking content.
thatitalian
  • The Revolution Is Coming...
« Reply #82 on: January 15, 2009, 08:20:09 am »
HAHAHAHA!  :laugh2:
Yeah I can't see them either. Can someone just delete this thread along with Bender's other one? ;D >:D
Bender
« Reply #83 on: January 15, 2009, 09:42:17 am »
DUDE! I was thinking "how the hell did he bend the laminate over the curved edge so well!" That does not look like paint AT ALL! :applaud:
I have a can of like every black spray paint possible from a different project, so I just tested them all to find the one that matched the finish of the laminate I ended up with Krylon Semi-Flat matches almost identically
funny you should mention bending laminate.
I'm a Bender that's what I do, this is the Benderama so there has to be some bending somewhere
There are two places I have to laminate around curves, the front of the CP, and the back of the top
so I've been practicing on some scrap laminate, or I should say its scrap now (I'm using the thinner vertical grade laminate)
I'm using a heat gun leather gloves and a LOT of patience. I've found that if you can pre-form the laminate before gluing it it works much better cause the heat you need to bend it negates the glue and also if you mess up the rest of the sheet is glued down to your piece and very hard to get off
The Top back has a sharp 1/2" radius that is really tough, but I think I got it last night
I'm going to do the CP today that should be a bit easier as it has a 1 1/2" radius
cross you fingers
it took four tries to get the top right
Really? that's strange
let me know if that is still the case and I'll reload them, there should be 8, they come up fine here
That's exactly what I was worried about
that and you razzing me at the end! ;)
« Last Edit: January 15, 2009, 10:06:29 am by Bender »
mountain
  • Last login:January 29, 2025, 08:31:47 am
    • Mountain Jukeboxes
« Reply #84 on: January 15, 2009, 10:09:17 am »
Bender,
I have also done my share of laminate bending, here are a few tricks that I have learned.
Use a nice clean, flat, sturdy work table, lay the laminate on the table and use your weight to roll the piece to the laminate.
Spray the glue on if you can. Rollers and brushes make it tough to get a level film of glue.
Vertical grade laminate shows everything under it. Make sure the surface is perfect and be careful not to contaminate the glue while the lid is open. One little shaving in the glue can be seen in the final product.
Be very careful with the heat gun.
Trust the glue manufacturers instructions.
Pure Xylene rocks when it comes to cleaning off glue.
I lkie hte semll of gule
« Last Edit: January 26, 2009, 11:39:25 pm by mountain »
Bender
« Reply #85 on: January 15, 2009, 02:42:02 pm »
thanks so much for the info mountain
words from the master will be taken to heart  :notworthy:
unfortunately I don't have access to a sprayer
but I've had good luck with a roller specially made for applying the glue to laminate, I put it on a little thick for the vertical stuff to cover any imperfections
tough I try to make sure every thing is smooth and clean
everything has turned out great so far! (knock on wood)
« Last Edit: January 15, 2009, 11:58:34 pm by Bender »
Bender
« Reply #86 on: January 16, 2009, 03:23:35 pm »
I would have never thought of doing it upside down like that.
what a great solution, even pressure across the piece as you bend it
I tried it out today and it worked perfectly. Thanks again Mountain.
Encryptor
  • Trade Count: (+34)
« Reply #87 on: January 26, 2009, 04:50:02 pm »
Anything new with this one?
Encryptor
Bender
« Reply #88 on: January 27, 2009, 12:05:31 am »
Encryptor
Funny that you should ask!
here is little update on the CP, and the top marquee panel (the pieces that had to be bent) and some other odds and ends
I decided to add a player2 button so I had to fit 3 holes where I had already drilled 2...   Bondo to the rescue again!
a couple of my failed atenpts at bending the laminate for the top. 1/2" radius is too tight so I tried with 3/4" and got it to work
the 1" radius for the CP seemed easy after that
these are shots of carefully bending the laminate over a form, all done before glueing
Here is the almost finished CP. I'm going to try something a little different with the trackball mounting...        Stay tuned!
« Last Edit: February 26, 2009, 04:26:08 pm by Bender »
Bender
« Reply #89 on: January 27, 2009, 12:28:41 am »
the top part
this is actually after it was all glued down but you can see where I marked it all out before I glued it so that the bent laminate would line up right with the wood
also to get the bend to stay put I added the 2" right angle part(on the top with the grove cut in it)
here is the same piece with the laminate trimmed and slit, below which will be removed
the final piece
« Last Edit: February 26, 2009, 04:29:11 pm by Bender »
Bender
« Reply #90 on: January 27, 2009, 12:49:06 am »
a few more Pics
ready for T-Molding
almost all the pieces frontside and backside
I had already removed this from the laptop anyway so I decided to try to use the media controls
all cut out and epoxied into there new home!
« Last Edit: February 26, 2009, 04:34:04 pm by Bender »
Encryptor
Re: "BENDERAMA" folding portable bartop (progress Pics 1-27-09)
« Reply #91 on: January 27, 2009, 05:28:43 am »
Very nice! Can't wait to see it together.
Encryptor
thatitalian
« Reply #92 on: January 27, 2009, 09:47:49 am »
Ahh dude, that is some insane "bender"ing skills!
Kaytrim
  • I'm too nice a guy
« Reply #93 on: January 27, 2009, 10:02:41 am »
Very nice result so far Bender.  Just keep in mind that you have to crack a few eggs to make an omelet. :bat :cheers:
Michael
Bender
« Reply #94 on: January 27, 2009, 10:23:01 am »
thanks all
I think I can start to see the ghosts at the end of the tunnel!
at least for the build, the computer is a whole other story
anyone know anything about XP 64? and nLite?
« Last Edit: February 26, 2009, 04:36:30 pm by Bender »
Barry Barcrest
  • Last login:Today at 03:47:03 pm
  • Simple Plan
    • E-Touch Jukebox
« Reply #95 on: January 28, 2009, 07:57:11 am »
WOW This is looking great, not checked this thred in ages.
Encryptor
« Reply #96 on: February 08, 2009, 05:35:00 pm »
Anything new to report on this build?
Encryptor
Bender
« Reply #97 on: February 08, 2009, 09:50:27 pm »
I'm getting there
I finally "upgraded" the laptop to XP from vista (god that took a while) but I think I got it running pretty stable now
but I'm still working on:
the software side of things, FE and EMU configuration and of course some LED goodness thanks to help from Arzoo
and the actual wiring of the controls
and the artwork too is coming along
so I hope to have some new pics soon
« Last Edit: February 08, 2009, 09:52:27 pm by Bender »
system01
  • Last login:March 04, 2023, 08:06:55 pm
  • System Idle Processes are the Devil's Playthings
« Reply #98 on: February 08, 2009, 10:30:03 pm »
I just acquired an ISO of TinyVista.  I havent tried it yet, but it has some really good reviews.  I was going to use it for an HTPC, but the PC hasnt shown up yet.  It looks like it still has the Aero and Ultimate stuff and all that, and also all the generic networking stuff.  It is missing a bunch of the "enhancements" like the desktop sidebar and such.
I cant vouch for it yet, just letting y'all know.  Im using TinyXP r09 on my cocktail now and looove it.
I wont tell you where to find it, but Im sure youre aware of the usual suspects. ;)
Keep up the work, Im really liking this thing!
bigdady92
  • Last login:September 16, 2009, 05:11:32 pm
  • Pies before Cake
« Reply #99 on: February 26, 2009, 01:46:45 pm »
Hey bender, can you update your links. I don't see pictures anymore on your posts.
Do you happen to have the dimensions of this stuff? I'd like to build something simillar for my niece for her birthday and having your specs would help allot!
thanks in advance!
I like south beach, women are hot, foreign, and don't know how to dial 911.
Bender
« Reply #100 on: February 26, 2009, 04:41:54 pm »
thanks in advance!
Thanks for pointing out the issue with the pics. should be all set now.
Want the prototype? You can have it I'd hate to throw it out.
I can get you the sketch up file too if you want. I did modify it a bit after that but I can let you know the changes I made,
should have some updates on this soon ;)
Bender
bigdady92
  • Pies before Cake
« Reply #101 on: February 26, 2009, 04:50:51 pm »
Yes to both. I've been scratching my head trying to figure out your exact dimensions. I would be changing a few things:
no laptop, put motherboard in marquee area
no marque light use usb
lcd panel
etc
Overall nothing earth shattering, I wanted to know how you mounted the handles and pictures for it. I'd love to see the inner workings.
I'm native to florida. Lord only knows how much the shipping would be :D
you can email them to me at: bigdady at gmail dot com
Much appreciated! Reall
Encryptor
« Reply #102 on: March 19, 2009, 05:31:10 am »
Any new progress on this?
Encryptor
Encryptor
« Reply #103 on: April 28, 2009, 05:33:37 am »
Been a while on this one. Any progress lately?
Encryptor
Yvan256
    • Yvan256
« Reply #104 on: June 02, 2009, 12:47:38 pm »
Any update on your project? I want to see more!
And I know it's a bit late for that, but wouldn't it make more sense to put the trackball in the middle? When playing with the joystick and buttons it wouldn't really be in the way and make for a wider control area (i.e. your arms aren't confined to the left+middle, they're positioned at the left and right, if that makes any sense).
« Last Edit: June 03, 2009, 10:10:53 am by Yvan256 »
Bender
« Reply #105 on: June 07, 2009, 06:50:15 pm »
alright, alright, I'm busted
I've made a lot of progress on this and that is the problem, it became fully playable 2 months ago and I got sucked in, never heard of that happening on this forum before ;) so I've been super lazy about posting
I have a couple of little things to finish up, mostly the LED's on the trackball, spinner, and a couple buttons and and a little work on the front end, then I'll post the finished (at least for a while) product
I've been using it for a while and I have to say I'm really happy with the placement. I'm right handed so the trackball on the right side with nothing behind it works fantastic for me, it could be a little awkward for a lefty but on such a tight panel you can't have everything
« Last Edit: June 07, 2009, 07:52:44 pm by Bender »
Bender
Re: "BENDERAMA" folding portable bartop (small update 6-07-09)
« Reply #106 on: June 07, 2009, 07:35:33 pm »
here's a little teaser
« Last Edit: June 07, 2009, 09:02:12 pm by Bender »
polaris
  • veni vidi congai
« Reply #107 on: June 07, 2009, 07:43:10 pm »
sick, i want to see the rest :applaud:
swaffar
« Reply #108 on: June 07, 2009, 08:47:21 pm »
cab's looking nice bender!
i'm just waiting on a U360 rotary tutorial...
My projects:
Bender
« Reply #109 on: June 07, 2009, 09:01:07 pm »
someday, I hope :dunno
rotary and dual joystick games are about the only games not playable on this now
so I really want to get the rotary working for this project, but it's pretty low on my list, so it 's going to be a while
« Last Edit: June 07, 2009, 09:03:03 pm by Bender »
  • Last login:January 10, 2026, 01:53:23 pm
« Reply #110 on: June 07, 2009, 09:55:25 pm »
Wow....................
Franco B
« Reply #111 on: June 08, 2009, 02:08:04 am »
You tease!  ;D
That look awesome Bender, can't wait to see the rest!!
thatitalian
« Reply #112 on: June 08, 2009, 11:04:43 am »
YOU BASTARD! >:D
That looks ---smurfing--- awesome bud!
« Reply #113 on: June 08, 2009, 11:28:41 am »
Holy crap.   :dizzy:
MORE PLEASE.
Kaytrim
« Reply #114 on: June 08, 2009, 12:16:23 pm »
« Reply #115 on: June 08, 2009, 01:28:30 pm »
Bender - can you provide a link to where ever you got that pause button?  It looks way nicer than the small ones I use from Radio Shack.
Oh yeah - MORE PICS.  :cheers:
Bender
« Reply #116 on: June 08, 2009, 06:09:57 pm »
Thanks for the kind words everybody! :cheers:
I'll have more in a couple weeks
hey buddy,
I found out about those buttons from dmworking247's alien bartop project, he gave me the link to a company in australia, they got here pretty quick though
I orderd a bunch cause the shipping is like $10
I really like them, I used them fro the admin type buttons on my xbox 360 sticks too, their much better than the Radio Shack ones
they come in red too (used that for the power button on the back)
« Last Edit: June 08, 2009, 06:14:00 pm by Bender »
mountain
« Reply #117 on: June 08, 2009, 09:29:05 pm »
What!? You can't do that...it's not fair... :timebomb:
Lookin good there buddy! Can't wait to see the nice completed shots.  :cheers:
smalltownguy
  • Last login:October 07, 2025, 12:45:27 pm
« Reply #118 on: June 08, 2009, 09:51:47 pm »
Come on come on come ooooooooooonnnnnnn.......!!!!!! I can't wait.
I'm living vicariously through Bender on this one.
But I'm slowly building the WAF of an arcade machine on our counter top  >:D
Bubble bobble helps  ;D
flowon
  • Last login:October 04, 2016, 05:22:41 am
« Reply #119 on: June 09, 2009, 07:22:01 am »
Hi... I'm generally more of the lurking jealous type (all these lovely cabs  :notworthy: ) but I gotta crawl out of the woodwork on this one and say YES MORE PICS SOON PLEASE! This looks so great!
