Author Topic: Mountain's Bartop Jukebox - Kits now available!!  (Read 206748 times)
Encryptor
  • Trade Count: (+34)
Re: Mountain's Bartop Jukebox for Dad *MAMEY WINNER*
« Reply #160 on: September 12, 2008, 03:45:23 pm »
No new pics?  :(
  • Last login:Today at 07:49:55 pm
« Reply #161 on: September 12, 2008, 04:44:06 pm »
No new pics?  :(
You want to see it in a swimsuit or something?  ;) It's a completed project.
mountain
  • Trade Count: (+9)
  • Last login:January 29, 2025, 08:31:47 am
    • Mountain Jukeboxes
« Reply #162 on: September 12, 2008, 06:23:07 pm »
 :laugh2:
He is talking about the pictures I had taken of the juke. I have the raw un-doctored shots that aren't that impressive. I will try to get a few up by the end of the weekend.
« Reply #163 on: September 25, 2008, 12:34:16 pm »
« Last Edit: September 25, 2008, 02:29:20 pm by javeryh »
mountain
  • Trade Count: (+9)
« Reply #164 on: September 26, 2008, 08:33:57 am »
No new pics?  :(
Here are the shots I said i would post a while back. Unfortunately they have not been adjusted.
thatitalian
  • The Revolution Is Coming...
« Reply #165 on: September 26, 2008, 08:55:17 am »
HOLY C**P! :notworthy:
Loafmeister
  • Last login:June 03, 2025, 01:49:49 am
« Reply #166 on: September 26, 2008, 03:33:39 pm »
  :notworthy:  :cheers:  :dizzy: :applaud:
Need I say more?  Yes?  Ok.  I think many produce great work here but only select members produce something that looks so "professional".  You're obviously one of them, well done.
Encryptor
« Reply #167 on: September 26, 2008, 06:57:48 pm »
mountain,
Thanks for posting the new pics. It is truly a work of art. The craftsmanship and exquisite attention to detail can be seen even better in these quality pictures. Truly an outstanding piece of work.  :notworthy: :notworthy: :notworthy:
Encryptor
Benevolance
« Reply #168 on: September 27, 2008, 05:38:27 pm »
Wow. Kudos on the fantastic workmanship! That looks sleek.
AngryCanadian
  • Last login:April 24, 2011, 09:34:24 pm
  • It's not a CUBAN.
Re: Mountain's Bartop Jukebox---> For Dad
« Reply #169 on: September 27, 2008, 09:57:35 pm »
The other problem that was driving me crazy was the swivel mechanism and the magnets. After all of the work I did, the problem hit hit me the other day like a ton of brick. When one uses the touchscreen the pressure of the touch makes the top move back and forth. The magnets are installed in a way the prohibits them from actually making contact with the steel discs. I wanted it to be smooth but the downside is that they don't hold very tight this way. It was very sloppy to say the least.
The fix turned out to be very easy. The lazy susan swivel is basically two stamped pieces of steel with a row of bearings all the way around. One is folded over the other with a slight gap to keep the friction down. I dug out my old aviation rivet squeeze and crimped the the two pieces tighter together.
It took forever to get it right because if I crimped it too much the swivel would be ruined. Good thing the tool is adjustable. I had to crimp it a little all the way around and then assemble everything to test. It took 4 attempts to get it right. Now the top stays put when touched but swivels nice and still has noticeable stopping points every 30 degrees.
If you get a chance can you go into more detail on how you set up the magnets and fixed the lazy susan so that they remain in a fixed position when pressing against the touch screen.
I am looking at building a custom bar top project with a touch screen and wanted it to be able to swivel around but be able to lock into position. I love the idea of magnets and the lazy susan but was not sure how you finally got it to work.
Is the combination of magnets and crimping the lazy susan to tighten up the rotation the trick?
Great minds discuss ideas; Average minds discuss events; Small minds discuss people...I prefer to discuss Arcade Cabinets!
Snowblindz
  • Last login:May 09, 2018, 04:03:30 pm
« Reply #170 on: November 19, 2008, 03:42:26 am »
I just had to stop and comment on this.. That is the most amazing looking touch jukebox I've ever seen! I am blown away! I would love to have one of these!
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #171 on: January 12, 2009, 10:27:37 pm »
Bump for easy finding.
Barry Barcrest
  • Last login:November 09, 2021, 09:54:17 am
  • Simple Plan
    • E-Touch Jukebox
« Reply #172 on: January 13, 2009, 06:43:57 am »
Did you finally switch the software over?
  • Last login:November 09, 2025, 07:06:54 pm
« Reply #173 on: January 13, 2009, 08:22:33 am »
You do realize you can bookmark threads using the forum's software, right?  :D
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #174 on: January 13, 2009, 10:53:58 am »
Forgot about that when I did this.
deoblo85
  • Last login:April 01, 2025, 01:22:30 pm
  • GAME or DIE
« Reply #175 on: January 20, 2009, 10:24:28 am »
Thats the coolest jukebox i've seen  yet  :applaud: were did you get the usb volume knob?
« Reply #176 on: January 20, 2009, 10:50:34 am »
Do you know it's a Griffin Powermate? If not, you should read the posts.
http://www.griffintechnology.com/products/powermate
deoblo85
  • GAME or DIE
« Reply #177 on: January 22, 2009, 12:57:14 pm »
Ok thanks. Mountian i've looked every were for 1/8" mdf board know one seems to think it exists were exactly did you get it  :banghead:
mountain
  • Trade Count: (+9)
« Reply #178 on: January 22, 2009, 01:07:46 pm »
I found it locally at a specialty woodworking store called Woodwerks
« Reply #179 on: January 22, 2009, 01:19:10 pm »
I used what they call "1/8" hardboard" at Home Depot and it worked just fine.  CHECK IT OUT.
  • Last login:November 19, 2025, 06:13:57 pm
« Reply #180 on: January 22, 2009, 04:58:21 pm »
Thats what I used too JH..
I put two layers of "skins" on my juke, but I think one would have been enough.
explorerman
  • Last login:May 12, 2010, 10:00:11 am
« Reply #181 on: January 22, 2009, 09:26:05 pm »
Yup, I'll be using the same stuff.  Should have the frame skinned this weekend.
Explorerman
deoblo85
  • GAME or DIE
« Reply #182 on: January 23, 2009, 07:17:18 am »
Wow is this turning into a mountain jukebox mania it must feel great to make a design that people have to have  :notworthy: and to show us step by step is even better.It's great to build a jukebox and to already have an idea what it's going to look like.Anyways hard board it is, thanks for the help!!
one more question did you use wood glue or contact for the skins........thanks agian mountian/javeryh
deoblo85
  • GAME or DIE
« Reply #183 on: January 23, 2009, 07:23:09 am »
Im going to post mind when its done i think everyone knows how it was made. :banghead: except for the right glue ;D
newman25
  • Last login:June 02, 2022, 05:06:17 pm
« Reply #184 on: January 26, 2009, 08:57:08 pm »
Very nice looking juke Mountain!  You did a great job.  I have been watching this thread for some time now.  And, the others you have inspired with your design look great as well.
Did you get your mounting bracket, power pushbutton switch, and USB plug from an old PC case or did you purchase them from somewhere?  I have searched all over the forum/internet and either I am not searching for the right things or they just aren't out there to be found (at least by me hahaha).
I'm getting ready to start a jukebox project(my own design) and I want to find the items that I need to order so that they are on their way while I work.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #185 on: January 29, 2009, 11:01:26 pm »
I may have missed it due to the sheer number of posts here, but what was the total project cost? I'm looking to build a similar shape now I know it can be done but I know it won't be to anywhere near the standard of this. I'm thinking of doing a much simpler design with no swivel base and simply internal speakers.
How much did you stretch to for this bad boy?
mountain
  • Trade Count: (+9)
« Reply #186 on: January 30, 2009, 11:35:22 pm »
If memory serves me correct, the electronics ran about $450-$550. The laminate, wood, plexi. and misc. Hardware was another $150-$300.
I have kicked around the idea of producing "Mountain Jukebox" kits for sale. This would be for people who would enjoy one of these but were not willing to invest the time and labor into figuring out all of the cuts on their own. These would be made by me and could range from a simple flat pack of wood all the way to a working unit.
What do you guys think, would they sell?   :dunno
« Reply #187 on: January 31, 2009, 12:23:15 am »
Yes.  Assembly would have to be worked out beforehand with guides to line everything up but I think people would by a kit to get started.  Would have saved me a lot of time!
deoblo85
  • GAME or DIE
« Reply #188 on: February 03, 2009, 06:55:03 am »
Man i sure could have used that kit before i started it's not as easy as it seems atleast not for me it would have save me alot of time and  :soapbox: how much would you charge for a kit?
mountain
  • Trade Count: (+9)
« Reply #189 on: February 03, 2009, 07:36:26 am »
I am working on this now. The trick will be to make it affordable enough for someone to justify the time it would save while making it worth my while. I think in the beginning the best way to approach it would be to make a kit available that had the front and back templates, 2 pieces of 1/8" MDF (cut to size) a bank front piece for the monitor (with the marquee area cut out), pre-cut marquee Plexiglas, the bottom, and internal mounts for the HD, Mini ITX Mitherboard etc. + instructions.
I think a completed shell with finish options would be wanted as well but the pricing needs to be worked out on both.
Any ideas??
« Reply #190 on: February 03, 2009, 07:42:42 am »
Pricing in this instance should take into consideration all the time that is saved by using a kit.  The materials probably aren't that expensive ($50 or less for the MDF and plexiglass) but I know from personal experience that working 3 hours a night for 6 weeks straight is barely enough time to make the shell.  I guess it depends on your skill set in the shop but people ordering the kits would be on the little to no experience side of things.  There are plenty of times when I would have gladly handed out $200+ just to be done with it out of frustration.   ;D
deoblo85
  • GAME or DIE
« Reply #191 on: February 03, 2009, 02:58:34 pm »
Just having the front plexiglass facing cut out and polished is worth 200 hundred to me ;D
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #192 on: February 03, 2009, 06:49:15 pm »
Could you not work something out McCoy to do them using the machine? Might bring the cost down a bit on materials etc and save on a lot of manpower.
deoblo85
  • GAME or DIE
« Reply #193 on: February 04, 2009, 04:53:50 am »
Alot of cost would be shipping, you would have to be local.but its worth trying just estimate a cost for the complete job and see.
mountain
  • Trade Count: (+9)
« Reply #194 on: February 04, 2009, 06:47:12 am »
Yes, the kits would have to be CNC cut, at least the MDF.  I am working on how all of that will unfold right now.
A kit would not weigh that much; no need to keep it local.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #195 on: February 04, 2009, 07:49:34 am »
Ping! That's the magic right there... You are more than welcome to advertise these on my site and forum dude if you go ahead. I am sure some folks will be interested.
Nvts
  • Last login:September 15, 2010, 02:30:14 pm
« Reply #196 on: February 04, 2009, 09:21:25 pm »
After making one of these things (and yes, its still not quite done) a good spot to start building one of these would be the front plexi, the front and back panel and the MDF for the front and back frame. Add in a support structure that can go in the middle (like McCoy has on his), but with a place for a dowel to hold the front to the back.  In fact, after looking at what McCoy did with his CNC, I think that would be a great place to start.  Hell, just having the front panel and front plexi would save people 10's of hours.
The only downside to making a kit would be having the front panel 'routered' for the monitor mounting.  that to me was the hardest part, yet not all screens would mount the same, I assume.
"A common mistake that people make when trying to design something completely foolproof was to underestimate the ingenuity of complete fools."
deoblo85
  • GAME or DIE
« Reply #197 on: February 05, 2009, 11:01:35 am »
Maybe that would be part of the kit that you would work out with mountain.kit includes monitor,man i would have got the kit in a second and for anyone wanting to biuld one its by far not easy all the tools and the right bits on and on its been two weeks and i still have alot to go. :hissy:
KnightofTruth
  • Last login:December 21, 2013, 12:51:58 am
« Reply #198 on: February 17, 2009, 02:45:43 pm »
Well, after wiping off the drool from my keyboard (didn't realize I actually had my mouth open at its awesomeness)... all I can say is *great job!*
And yes...please let us know as soon as you have the specifics worked out with your DIY Kits for this - could most certainly use one of these at home, in my office, and even at the church!
Deefish
  • Last login:September 01, 2025, 12:33:47 pm
  • Is there something in my teeth? Look close.
« Reply #199 on: March 30, 2009, 11:05:30 am »
Hey Mountain, I would pay $300 for a complete kit. I have a 15" ELO in the closet waiting for a jukebox.
Also, where did you get that power button on the back? Does it light up?
In one pick it looks like at first you used just a regular arcade button, but in the finished pics it is a shiny metal start button with power logo. I bought one of those bulgin vandal resitant buttons that light up, but it does not have power logo on it.
Ok thanks and keep us posted on the kit situation,
Deefish
