Author Topic: FREE Laserjet 5  (Read 1779 times)
Thenasty
  • Last login:Today at 02:47:28 pm
FREE Laserjet 5
« on: April 24, 2008, 01:08:59 pm »
Come ang get it............ Considered it not working (no toner) when powered on, I get error 13 (paper jam). Just incase you are wondering how it turn on without a toner, I put one in  :D (borrowed it from another).
Free VGA Breakout Cable
Yarb
  • Last login:December 26, 2019, 01:18:30 pm
Re: FREE Laserjet 5
« Reply #1 on: April 25, 2008, 11:46:06 am »
For an HP 5 that gives an Error 13 at power up (Before attempting to feed a page) check the sensor on the fuser in the back (Careful the rollers inside are hot) and the exit sensor at the top. If these are clear and working then you have to check the hard one, if you turn the printer on it's side you will see there is a slot where the paer feeds up. There is a sensor in this slot that can get a piece of paper torn off it when a paper jam is improperly cleared (Pull paper through from the inside if at all possible, avoid pulling it backwards). Usually you can clear this with a piece of cardstock to gently push the paper though from the bottom (NEVER try to push it backwards as you can break the sensor arm). I have seen cases where a label fed from the tray (Which should NEVER be done on a 4/4+/5 series) gets peeled off and stuck. In this case it is a major pain to dissassemble the printer to clear it.
Yarb
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Re: FREE Laserjet 5
« Reply #2 on: April 25, 2008, 05:44:10 pm »
Might want to note your location.  Those beasties are heavy.  And large.
Thenasty
Re: FREE Laserjet 5
« Reply #3 on: April 25, 2008, 08:21:54 pm »
Click on my username and it tells you New Jersey....
Anyone in NJ, come and get it.......Maybe its a quick fix like mentioned above.
Thenasty
Re: FREE Laserjet 5
« Reply #4 on: April 26, 2008, 10:00:01 am »
This will be thrown out SUNDAY NIGHT (tomorrow), but before I thow it out, I gonna take the RAM and offer it here. Anyone want the RAM (if there is any) ?
Havok
Re: FREE Laserjet 5
« Reply #5 on: April 26, 2008, 09:08:47 pm »
They're not that bad. I think you are thinking of the 5si - that ones a beast, about twice the size of the 5. I have a 5 in my office. Nice medium duty laser printer, real workhorse. Definitely worth the time to fix if you are so inclined.
Thenasty
Re: FREE Laserjet 5
« Reply #6 on: May 01, 2008, 08:22:14 pm »
This has now faced the TRUTH.......It's in Hp Heaven/Hell  >:D :angel:
SirPeale
Re: FREE Laserjet 5
« Reply #7 on: May 01, 2008, 08:58:35 pm »
Too bad.  Though a beast, those printers are made to last practically forever.
Thenasty
Re: FREE Laserjet 5
« Reply #8 on: May 01, 2008, 09:11:35 pm »
So as the 4L. There is a chance you can have one....100% Working this time.
I pulled out the Memory, its a 4MB stick. Anyone want it, throw me 5.00 for s/h.
