Author Topic: Converting Marvel Vs Capcom  (Read 2936 times)
J8son
  • Last login:February 12, 2008, 07:21:49 pm
« on: February 10, 2008, 12:22:07 am »
I'm getting a good deal on a Marvel Vs Capcom cabinet that I plan to convert to a MAME cabinet. I plan to keep all the original hardware and convert it to run off a PC I'll build and put inside (typical MAME cabinet setup).
I'm unsure how to convert the monitor and cabinet speakers to run on a PC. I plan to use JPAC for the control panel and I think it has a monitor feature.
Any thoughts?
Thanks!  ;)
M37R01D
  • Last login:April 25, 2009, 06:23:25 pm
    • M37R01Dz M0Dz
Re: Converting Marvel Vs Capcom
« Reply #1 on: February 10, 2008, 12:56:45 am »
One of my favorite fighters, what a shame to destroy  :'(
J8son
« Reply #2 on: February 10, 2008, 01:04:01 am »
One game must die so many more can live on in its place.  ;)
Besides, I'll be selling the Jamma board so technically it will not be destroyed.
wana10
  • Last login:December 27, 2016, 09:44:04 pm
« Reply #3 on: February 10, 2008, 02:33:18 am »
mvc didn't have a dedicated cab. all it needed was a jamma compliant generic cab with a kick harness.
J8son
« Reply #4 on: February 10, 2008, 03:37:13 am »
Yeah, I figured. That's why I don't want to gut the cabinet as all the parts still work well. Just need to remove the board and convert everything. And like I said before, I know the JPAC board will do that job but I'm not sure how to convert the monitor and speakers.
wana10
« Reply #5 on: February 10, 2008, 03:53:07 am »
actually it's pretty easy, the jpac will do that for you as well.
here is a jpac. you plug the vga cable from your computer into the vga port on the right, and as long as the signal is safe for a arcade monitor to display it will be routed through the jamma edge to the cabinet's monitor.
you can also attach the speaker out from your computer to the two screw terminals on the right that are labeled speaker.
finally the kick harness from your mvc setup gets attached to the other screw terminals labeled 1sw4-8 and 2sw4-8. attach the jpac to the computer as though it were a keyboard and poof! it works.
(disclaimer: this is second hand knowledge from a friend of mine who did it himself, if i'm wrong...blame him ;))
J8son
« Reply #6 on: February 10, 2008, 04:01:04 am »
Thanks for breaking that down for me wanna10. However, being that I've never actually seen the inside of an arcade cabinet yet, I'm getting a little lost here.
Based on your illustration, you said I can take my VGA out of my computer and into the VGA port of the JPAC board (which will not be a problem since I'm buying a special video card just for arcade monitors).
But, on the cabinet side, how would I get the connections for the monitor and the speakers to join up with my PC through the JPAC board? Also, dont the speakers need some kind of power?
wana10
« Reply #7 on: February 10, 2008, 04:22:25 am »
because you have a mvc board already in the cab everything will be wired into two sets, the jamma harness and the kick harness.
jamma
this mess of wires(with any luck whoever wired your cab took their time and it won't look like a rats nest.) controls practically everything on the cabinet. the power, the monitor, the coindoor, the speakers, the buttons, everything. plugging this onto the top edge of the jpac will connect the cabinet speakers and monitor.
kick
this is the kick harness. as per its name it has the kick buttons and a ground. nothing else.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #8 on: February 10, 2008, 08:40:50 am »
When I drop a PC into a JAMMA-wired cab I use a JPac as wana10 has suggested and an ArcadeVGA video card to produce the 15K signals.
Only thing I would mention is that JAMMA expects amplified audio while your PC sound card probably doesn't produce amplified audio. The JPac FAQ discusses this and the options that you can use.
http://www.ultimarc.com/jpac1.html
Since I am using these cabs typically for classic gaming, I typically don't need stereo, just amplification, so I drop an audio amplifier circuit inline between the PC and the JPac. I pick these up from the local surplus store for a couple of bucks and drive them with 12V from the PC power supply.
Example:
http://forum.arcadecontrols.com/index.php?topic=60297.msg615954#msg615954
It may be easier for you just to use a pair of amplified PC speakers, but my intent is typically to not alter the cabinet's wiring at all so I can swap the PC in or out at will.
Working: Not Enough
Projects: Too Many
Progress: None
J8son
« Reply #9 on: February 10, 2008, 09:23:55 am »
So your saying there is no way to just run the sound out of my sound card, to the board and through the pre-installed speakers? I was hoping to keep the originals but I'm not to good at doing all the power amp stuff.
CheffoJeffo
« Reply #10 on: February 10, 2008, 09:41:55 am »
Unless your sound card puts out an amplified signal, then nope.
I know CornChip was looking at finding a plug and play inline amplifier -- dunno if he ever found one.
Working: Not Enough
Projects: Too Many
Progress: None
J8son
« Reply #11 on: February 10, 2008, 10:52:24 am »
When shopping around for parts to build the computer inside the cabinet, is it common to find a sound card with the ability to amplify the audio? Or is that next to impossible?
somunny
  • Is it hot in here?
« Reply #12 on: February 10, 2008, 11:26:19 am »
I used this model amp for my last project and was very happy with the results:
Sonic Impacy 5066
Doesn't look like they make them anymore though.  Aftermarket prices are double what I paid in 2006.  This appears to be the successor (and less powerful?) model.  I'll most likely be using this one on my Ark project:
Sonic Impact 5065 Gen 2
« Last Edit: February 10, 2008, 12:19:53 pm by somunny »
J8son
« Reply #13 on: February 10, 2008, 12:52:25 pm »
Sonic Impacy 5066
Well, it that is the case then I can't see myself going with the amp solution. I mean, it looks to cost almost $60 and for that I can buy a 2.1 speaker/subwoofer combo that connects directly to the sound card and will probably sound better than the original speakers anyway.
A little disappointing but at least I wont run into technical issues I'm not familiar with.
Kajoq
  • Last login:June 14, 2024, 11:28:46 pm
« Reply #14 on: February 10, 2008, 01:49:56 pm »
Thats what I ended up doing J8Son.  I still have the original speaker in the cab because my cab stays hooked up to the arcade cart of Super Street Fighter 2 X most of the time, but I have a set of altec lansing 2.1 speakers I got for like 25 bucks on clearance when CompUsa was liquidating.  Theres plenty of room to mount them in my cabinet as well, Yours might be large enough to keep both.
J8son
« Reply #15 on: February 10, 2008, 02:04:39 pm »
That's funny you mention that as I had planned to use this set of Altec Lansing 2.1 speakers:
http://www.newegg.com/Product/Product.aspx?Item=N82E16836113016&Tpk=Altec%2bLansing
But, I have heard that people have interface issues when used with a computer monitor. Do you find any interference issues with the arcade monitor?
