Author Topic: Static Electricity Build up on my Cab making it go CRAZY!  (Read 7773 times)
rdowdy95
  • Last login:July 29, 2011, 11:48:50 am
  • This is my rifle.
Re: Static Electricity Build up on my Cab making it go CRAZY!
« Reply #40 on: September 27, 2007, 11:53:02 am »
I haven't moved it at all.  Through the months of June, and July, and some of August we have had tons of rain for Texas weather.  Now it is getting to be a dryer climate.  I went into the bedroom to check the static on the bedroom tv.  It was pretty bad as well.
The static comes about an inch off the TV.  I can usually feel about that much.  Once my hand gets to be about an inch from the glass that is when I can feel the static.
I wonder if I don't do the loop, and just maybe like put it along the bottom of the TV screen or maybe at the top.  Like maybe one side of the screen like left or right.  Lightning rod style.
Fozzy The Bear
  • Handbags at dawn in here!!!
« Reply #41 on: September 27, 2007, 12:27:27 pm »
NO! because of the way it works you need to make it a complete loop to get the best effect from it.
Best Regards,
Julian (Fozzy The Bear)
rdowdy95
  • This is my rifle.
« Reply #42 on: September 27, 2007, 01:02:50 pm »
Dang just hate the idea of the ugly copper loop.  Maybe I need to start looking at 27inch Arcade monitors with a 15 pin monitor connection.
« Reply #43 on: September 27, 2007, 09:04:00 pm »
You can always scotch tape the copper wire loop first, just to make sure it is going to fix the problem.
travandalex
  • Last login:August 04, 2009, 11:08:49 am
« Reply #44 on: October 09, 2007, 02:48:31 pm »
Hey Guys.  Hope I'm not too late to jump in on this topic.  I have experienced the same thing, with the result of killing several (expensive!) Happ USB trackball interface boards.  My setup:  homebuilt MDF cabinet, 27" Samsung TV (with picture framing matt for a bezel), Happ 3" trackball, Tornado spinner, 4 way stick (with i-pac), and X-Arcade 2 player panel.  The X-Arcade panel is mounted furthest out from the TV, with the 4-way, trackball and spinner in a line across between it and the TV.  I use the front button on the TV to turn it off an on.  This requires reaching over the trackball and spinner to touch the button.  I would get the same usb/windows 'be-bunk' noises of usb devices disconnecting occasionally (static from tv going down my arm to the spinner and trackball).  In addition, the up/down axis of the trackball has stopped working (and works again only by replacing the board in the trackball).  What tipped me off was when I created a lexan bezel for the TV (a flatscreen - so the bezel was almost touching the screen).  The static buildup was CRAZY.  I've made things better (but not perfect yet) by running a strip of tinfoil (a conductor) around the edge of the screen and grounding it with a wire to the third prong in the power bar.  This runs under a custom bezel cut from the picture framing mat (nice because it is black with a red visible core).  In addition, I've changed the trackball from usb to ps2 (an experiment to see if it helps) and run a ground wire from the trackball to the computer case.  This has stopped the usb random disconnects, and touching the tv screen produces MUCH less static.  Hoping it will also mean no more replacement boards for the usb trackball.
So in short:
I recommend the ground loop for the tv screen (couldn't find any info on anyone doing this before - so with some trepidation for life and limb, I tried it to success).
Ground the trackball to the pc.
Worked for me so far, and I'm interested in any other suggestions from there.
johnperkins21
  • Last login:December 07, 2019, 07:02:34 pm
« Reply #45 on: October 09, 2007, 08:05:42 pm »
Tape it on there with black electrical tape. Take your time and you'll barely even notice it. Try it with cheap regular tape first because electrical tape will leave a waxy residue that isn't much fun to clean.
Bob Dole likes cheese.
