Author Topic: ArcadeVGA ,... help me :)  (Read 4395 times)
Vampyre
  • Last login:April 14, 2004, 09:19:47 am
  • Roger Roger!
« on: April 29, 2003, 10:18:49 pm »
Does the arcadeVGA require a dual res monitor.
Because I've got a single res mon and it wont display anything except for the post info. if i go into the bios or try to boot windows it cant display them properly.
Thenasty
  • Last login:February 26, 2026, 10:04:40 pm
Re:ArcadeVGA ,... help me :)
« Reply #1 on: April 30, 2003, 09:34:08 am »
ArcadeVga is for the 15Khz Arcade Monitors only.
Free VGA Breakout Cable
Vampyre
  • Roger Roger!
« Reply #2 on: April 30, 2003, 09:38:02 am »
how do i know if my monitor is a 15khz mon or not ?
it came with the cab and i dont know much about it.
oh and this is an arcade monitor
« Last Edit: April 30, 2003, 09:38:30 am by Vampyre »
Thenasty
« Reply #3 on: April 30, 2003, 11:34:18 am »
What game did it come with ? There are 15khz (Standard res) 25khz (Medium res) then the 31 khz (High res). It depends on the game you got. Look at the chassis and find the model number.
gamecaptor
  • Last login:October 15, 2004, 01:26:48 pm
« Reply #4 on: April 30, 2003, 12:09:59 pm »
Uh, does the ArcadeVGA work with a WG D9200...hope so, cause I have one and I just ordered an ArcadeVGA card....
paigeoliver
  • Awesome face!
« Reply #5 on: May 01, 2003, 01:23:42 am »
They are almost ALL 15khz monitors. The 31 Khz ones will almost certainly have a VGA plug in the back, and mid res monitors are nearly non-existant. Few games used them.
MrArcade
  • Last login:May 29, 2025, 02:06:06 pm
  • I wish I had time to play these games !!!
« Reply #6 on: May 01, 2003, 01:53:54 am »
a lot of high production games used medium res monitors....nowhere near as many as standard res....but they are out there...
games that are medium res...
the nfl blitz series
virtua-anything
apb
paperboy
720
super sprint
just to name a few
Just try to find the model number of the monitor and post it...we can tell you if it is standard or medium res.
Oh, the memories of living on pizza subs and Dr Pepper...
paigeoliver
  • Awesome face!
« Reply #7 on: May 01, 2003, 02:45:20 am »
That was pretty much every title I could think of that used them also. But, really, you are more likely to end up with a vector monitor than a medium res one.
Thenasty
« Reply #8 on: May 01, 2003, 08:10:19 am »
virtua-anything
apb
paperboy
720
super sprint
just to name a few
Don't forget NARC, Bottom of the Ninth...
« Last Edit: May 01, 2003, 08:13:14 am by Thenasty »
Vampyre
  • Roger Roger!
« Reply #9 on: May 01, 2003, 11:14:56 pm »
Well i looked and the only info i could find was on the tube and it was a sticker with a heap of sstuff on it.
Its a Zenith tube and the serial number is OEM 483097
  • Last login:Yesterday at 08:36:11 pm
    • GroovyGameGear.com
« Reply #10 on: May 01, 2003, 11:30:21 pm »
This might be a silly question, but do you have the monitor plugged into the proper HD-15 connector?
You want the inside one, just in case :)
Vampyre
  • Roger Roger!
« Reply #11 on: May 03, 2003, 11:23:32 am »
yeah ive got it in the middle one which all the manuals and stuff tells me to use.
« Reply #12 on: May 03, 2003, 12:10:26 pm »
You say that you can see the post information, correct?
If so, your monitor should be a 15khz type or you wouldn't even see that.
Is the BIOS on your system one of the goofy GUI types or standard text?  If it's a GUI type, it might be kicking the card into an incompatible mode (although this seems unlikely).
Have you tried booting into "safe mode"?  What happens then?
Just trying to see what you have tried....
Vampyre
  • Roger Roger!
« Reply #13 on: May 10, 2003, 03:04:57 am »
I got windows 98 on it and it cant even display that. It gets close but the picture breaks up.
« Reply #14 on: May 10, 2003, 07:14:02 pm »
Can't help you without good information.  Read my questions again :)
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
« Reply #15 on: June 13, 2003, 07:49:05 pm »
I was having almost the same problem. Windows would load up and just before the desktop icons appared the system would hang. The only way I got around the problem was to go into BIOS and there was a setting
"int first display-PCI"
I changed it to
"int first display-AGP"
and no problems loading win98se after that.
Curls in the squat rack !?!?!
weizur
  • Last login:April 05, 2004, 01:49:09 pm
« Reply #16 on: June 18, 2003, 08:28:30 pm »
Hmm I do have a med res monitor, that I got in my NFL Blitz cab what are my options for displaying stuff?
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #17 on: June 18, 2003, 08:41:36 pm »
short of replacing it was a standar resolution monitor?
You'll need to find a video  card that handles 25khz  and /or tweak software to make it output at 25khz...  (things aforementioned like powerstrip, Advance Mame... etc)
I have no idea if ArcadeVGA handles 25khz, but my gut/initial response is nope.. or not well... as it was designed to interface with 15khz and I don't think Andy just dropped in extra rezes that couldn't be used with a 15khz monitor for kicks...
*shrug* but i'm outa my league here... so...
carry on...
Rampy
