Author Topic: Stupid super joystick question  (Read 1676 times)
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
« on: April 28, 2003, 06:52:37 pm »
i bought 2 happs super joysticks last week, and have two questions
1) that little grip, y'know, the one that clips to the very bottom of the shaft, how do i get it off, it seems stuck.
2) is it possible for me to buy just that part, preferably not from happs
please help me
Thanx
It's all about the Pentiums
Thenasty
  • Last login:Yesterday at 09:22:54 pm
Re:Stupid super joystick question
« Reply #1 on: April 28, 2003, 06:58:01 pm »
thats called the E-clip. Just use a long nose plier and pull it off.
Free VGA Breakout Cable
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: April 28, 2003, 07:58:01 pm »
What Thenasty said.
Also, when you pull the e-clip off, be careful: you need quite a bit of force, and it can go flying off at a pretty high speed if you aren't holding it.
You can get e-clips at home depot or Ace, but be sure to bring the original.  They come in all different sizes, so you need the original to find the match.
Robin
Knowledge is Power
jakejake28
« Reply #3 on: April 28, 2003, 09:13:15 pm »
ah, a plier. well, thanx for the help. e-grip. i'll keep that in mind
OSCAR
  • Last login:September 06, 2018, 11:31:53 pm
  • I think Bigfoot is blurry, that's the problem...
    • Oscar Controls
« Reply #4 on: April 28, 2003, 09:33:06 pm »
If you need a replacement e-clip, the ones that fit the Happ Super and Competition sticks is an 8mm.  The shaft is actually 10mm, but IL overcuts the groove and uses an e-clip designed for an 8mm shaft.
FYI - Happ incorrectly identifies the e-clip as a 7mm clip, but that is because the groove on the shaft is 7mm diameter, which requires an 8mm clip.   :)
JoyMonkey
  • Voodoo Wiki Master . . .
    • JoyMonkey.com
« Reply #5 on: April 28, 2003, 09:42:56 pm »
I just came accross this review of the Happ Super and Wico Leafswitch:
http://www.arcadeparadise.org/reviews/joysticks.html
I've been using Happ Ultimates (not too happy with them) and X-Gaming sticks. I'd like a good ball-top stick thats available in black, but haven't come accross much yet.
