Author Topic: Help with Advance Mame Video Settings  (Read 6478 times)
rgardjr
  • Last login:December 05, 2002, 06:03:32 pm
  • I want to Build My Own Arcade Controls!!
« on: March 21, 2002, 10:50:32 am »
Thanks to everyone here I was able to figure out how to get  Windows to run on my 27" EYGO VGA monitor.  The key was that the monitor only supports a 60hz refresh rate.  That being said I know the next step is to setup Advance Mame to support this resolution.  When I used the automatic  configuration settings the games didn't (Pacman & Galaga) vertically fill up the monitor.  I was looking at the pcsvga60.rc file and it looks like these are the settings I'd need to use-minus the ones that go above the 640x480 resolution of the monitor.  After reading the information I still don't understand where to put these settings.  Can anyone help me out with this???
Thanks-
« Last Edit: December 31, 1969, 07:00:00 pm by 1026619200 »
AlmtyBob
Re: Help with Advance Mame Video Settings
« Reply #1 on: March 21, 2002, 11:40:10 pm »
I'm not an expert in this, but 60hz is the vertical refresh rate, and windows definately supports this.  Your problem is with the horizontal refresh rate which is 15khz or possibly 25khz if you have a medium resolution monitor.  I think the bare minimum for windows is 30khz.  If you're using a j-pac (www.ultimarc.com) a trident blade 3d video card is supposedly supposed to allow you to run windows.
Hope that helps
zzafarsuppari
  • Newbie
  • Last login:February 09, 2015, 04:59:25 am
« Reply #2 on: January 27, 2015, 12:08:34 am »
 I was trying to install the sound blaster card to work in DOS (which I still havnt gotten to work) and the menu in ArcadeOS is real slow. When I UP/DOWN to change games,
Join online ccnp training dumps and security+ book to pass pmp dumps exam in first ccna videos - pass4-sure and Hood College training tutorials guide you
nitrogen_widget
« Reply #3 on: January 27, 2015, 12:17:01 pm »
Thanks-
I never touch any of the files themselves with advmame.
I just pull up the menu in game with the Tab key, go into video settings & pick a resolution & scaling option that works for that game size then save it for all games that size & it usually works pretty good.
Thenasty
  • Last login:Today at 11:02:57 am
« Reply #4 on: January 27, 2015, 08:36:08 pm »
13 years.....and OP never came back for 13 years..... :banghead:
Free VGA Breakout Cable
nitrogen_widget
« Reply #5 on: January 27, 2015, 08:46:42 pm »
Of geez.
Well, I hope he figured it out.
