Author Topic: coin mechs  (Read 1033 times)
philby85
  • Last login:August 28, 2008, 08:25:17 pm
coin mechs
« on: June 20, 2007, 10:40:13 pm »
Hey Guys,
Bought a mech , ( not electronic) It has height and width adjustments. When I mount it in my cab the coins always rarely drop. say 1 in 30. I checked the mech it is square in the cab. I have adjust the height and width many many times no joy. Any ideas I was expecting a normal coin mech to be easy to setup.
cheers
Philby
Thenasty
  • Last login:Today at 11:37:04 am
Re: coin mechs
« Reply #1 on: June 20, 2007, 11:56:24 pm »
are you using the right coin/token size ?
Free VGA Breakout Cable
philby85
Re: coin mechs
« Reply #2 on: June 21, 2007, 12:09:56 am »
Yes, they are setup for local 20 cent pieces (australia) however I have adjusted the height and width.
Attached is a pic of the mech.
phil
« Last Edit: June 21, 2007, 12:18:33 am by philby85 »
Ken Layton
  • Guru
  • Technician
Re: coin mechs
« Reply #3 on: June 21, 2007, 12:31:39 am »
Thickness adjust is also important. If this unit was bought used then cleanliness is of the utmost important. Any hint of dirt/grime/gunk along the rails can slow the coin down just enough to not work.
philby85
Re: coin mechs
« Reply #4 on: June 21, 2007, 01:01:06 am »
Thanks guys, will try again.
philby
