Poll
Which OS is running on your cab / arcade gaming rig?
DOS
Win95/98SE
Win2000
WinXP
Vista
Linux
MacOS X
Other (BeOS, etc)
Dedicated
Author Topic: POLL: Which OS is on your arcade gaming rig?  (Read 12034 times)
  • Last login:Yesterday at 11:12:43 pm
    • GroovyGameGear.com
« on: May 21, 2007, 04:30:14 pm »
Hopefully this hasn't been done to death.  It seems that today more than ever, there are a lot of options out there for OS'es.  And one thing is for certain about our community:  We don't follow the normal trends, as quite a few still use DOS on their arcade gaming setups.
Please limit responses to configurations where the system in question is dedicated to an arcade-gaming setup.  It will skew the poll numbers if you enter the information for your everyday system that you occasionally play a game on.  That's not the information we're looking for here.
If you are using Linux, or "Other", then please elaborate on the Distribution / Operating System you are using and why you selected it.  Likewise, if you are using modified versions of the more mainstream OS'es, then feel free to elaborate on what's been modified and how the modifications benefit your particular situation.  if the OS is a free one, links are good too!
Participants are allowed to change their vote if desired so,  if it can be kept track of, the poll can serve as a running reference and provide a better understanding of the OS'es we choose to use.  Not to mention, serve to guide new members of the community who might be just getting ready to set up their systems.  Each user can vote up to 3 times so more than one type can be represented in the case of multiples.
In addition, basic system specs (Processor, Speed and Memory) and what you perceive as its limitations when coupled with your OS of choice would also be helpful.
Thanks,
« Last Edit: May 21, 2007, 04:35:13 pm by RandyT »
spacies
Re: POLL: Which OS is on your arcade gaming rig?
« Reply #1 on: May 21, 2007, 04:41:45 pm »
XP here because its just too easy!
I just replaced my rig with a new one. AMD X2 4200. 1gig ram. SATA 80gb HDD. 256meg GFX card.
Computers are getting cheap these days!
Bloinkxp
  • Last login:August 30, 2020, 11:20:28 am
« Reply #2 on: May 21, 2007, 05:18:41 pm »
XP Arcade Rig-
2.0 GHZ AMD64 (3200+)
1 Gig RAM
20 Gig Boot Disk
80 GIG SATA Disk for the ROM(s)
Runs pretty well.  Basically you want enough RAM to load the OS and Game in to memory.  This reduces the hard drive chatter that most people complain of.
-d
Nothing witty here...move along.
edge
  • Last login:May 08, 2025, 09:08:47 am
  • AttractMode and GroovyArcade rock!
« Reply #3 on: May 21, 2007, 05:46:00 pm »
XP (fully patched) in all my cabs.
most of my machines are high end p4's and above, so I have not had to try any other OS yet.
Apollo
    • Eight Bells
« Reply #4 on: May 21, 2007, 05:47:25 pm »
XP
1.6GHz cpu
512 ram
40 gb HD
mame .86b
roms .86
mamewah 1.62b13
26 " arcade monitor
arcade vga video card
slycrel
  • Last login:June 25, 2025, 07:42:34 pm
  • Mmm... Portal.
« Reply #5 on: May 21, 2007, 07:14:17 pm »
Modded xbox (softmod)
UnleashX
Hardware is as it came.
psychotech
    • psychotech
« Reply #6 on: May 21, 2007, 07:58:58 pm »
No vote .. ;)
DOS 6.22, DOS 7.1 & WIN98SE
Come on! Retro games, retro hardware!
Well, one KeyWiz per machine..
patrickmaher
  • Last login:May 30, 2009, 06:45:05 am
    • Patrick Maher
« Reply #7 on: May 21, 2007, 08:41:46 pm »
Windows XP stripped down with nLite
P4 2.4 GHz
512MB RAM
250 GB SATA drive
My OS of choice for normal use is Windows 2000. Through much testing I found that Windows 2000 boot up takes to long for arcade use. Although Windows 2000 and XP are the same in most ways and 2000 works fine for normal use/modern gaming, there are some improvements in XP that make it the choice for arcade use.
After alot of optimization Windows 2000 boot up from power button press to usable OS was always over 1 minute. XP boot up after optimization is around 20-30 seconds. Although I did not try this myself, I have read many times that 2000 does not support multiple mice.
I started my build wanting to use 2000 because I am most comfortable with that version. After using nLite to strip XP I am satisfied with what I have. Most of the graphical differences and things I disliked about XP are gone/disabled, leaving me with something that feels close to 2000 but has the improvements needed for my arcade setup.
emerica
  • Last login:September 18, 2024, 09:27:07 pm
  • Goodtimes!
    • My ongoing projects
« Reply #8 on: May 21, 2007, 08:51:43 pm »
1)
winxp
celeron 2.93ghz
1g ram
64 mb ati 9200se
gameex
Everything I would want to play runs fine except for those dreaded CHD games.
2)
Dos 7.1
amd duron 700mhz
256 MB pc100 ram
8 MB ati rage xl
arcadeos
This system used to be my main machine with winxp. Windows booted slowly as well as mame, so I ditched the older hardware for the newer stuff above. This now sits in a mini-mame I built for my daughter. Using mame .36, every game in the machine runs smoothly (just 4-way classics for now). I think Dos has a better arcade feel to it when looking at load times. I also like the idea of turning off the power switch to turn the machine off without the worry of screwing up windows.
Each system has a keywiz. one eco and one max. (shame-less plug  :dunno)
« Last Edit: May 21, 2007, 08:53:17 pm by emerica »
I saw the best minds of my generation destroyed by madness, starving hysterical.
Thenasty
  • Last login:Yesterday at 11:00:26 pm
« Reply #9 on: May 21, 2007, 09:24:21 pm »
Intel 2.4Ghz CPU
1GB RAM
80 GB HD
AVGA 7000
IPAC 4
3" PS2 Imperial/Betson Trackball
Tornado Hack mouse/Serial Com1 Spinner
DOS 7.1
SB 16 PCI
2 19" WG7200 Arcade CGA Monitors
Advmenu 2.4.13 (Used my own created Snaps) see pic for one.
Advmame v106
Free VGA Breakout Cable
ringram
  • Last login:January 19, 2021, 05:25:37 pm
« Reply #10 on: May 21, 2007, 11:26:26 pm »
dos 6.22, arcadeOS
celeron 350Mhz overclocked to 450Mhz, 196Mb of ram
mostly playing the older classics. Works fine.
loadman
    • MaLa
« Reply #11 on: May 21, 2007, 11:43:08 pm »
winxp sp2- No Strip down, but fe is running as the shell
512k ram
amd proc 2ghz
geforce4 video
wireless network card (that is so handy with a Cocktail cab on wheels)
It runs way better than what I need it for, which is games pre 1995
gonzo90017
« Reply #12 on: May 22, 2007, 01:45:50 am »
WinXP stripped down with nlite
256mb ram (runs great with 128 but neogeo games load slow sow I upgraded to 256)
400MHZ Celeron
80gb hd
3dfx pci video card
Runs almost all games full speed with no frameskip. Just need to now what emus to use:
Raine - all + cps1, cps2
Winkawaks - NeoGeo
Everything thats left:
Mame37b16
Pmame59
Fastmame 71
Fastmame84
Zeppo
  • Last login:February 14, 2024, 10:26:44 am
  • Greetings Program!
« Reply #13 on: May 22, 2007, 07:28:12 am »
I use Tiny XP.
It's a stripped down version of XP.
It boots and runs quick.
Here's a link to a review:
http://www.secguru.com/link/tinyxp_run_xp_from_400mb_hdd_and_under_40mb_ram
Z
Guaranos
« Reply #14 on: May 22, 2007, 08:04:19 am »
I use FreeDOS on a Duron 600 with a 10gb hard drive and 128mb of RAM.  It runs AdvanceMAME 0.78 and AdvanceMenu from around that same era.  It runs everything up to around the SF2/Neo Geo level without a hitch.  It takes about 10-12 seconds from the push of the power button to playable.  It's four years old, and I have no plans to upgrade/change it in any way.
In the past, I have usually built cabinets for friends using FreeDOS.  I built one with XP due to special requirements (needed USB for an analog controller), and it seemed stable enough, but I wouldn't do it again unless I had the same special requirements.
I love OS X, but I wouldn't waste a Mac on a MAME machine unless I was making something tiny and wanted to use a Mac Mini.
ElfShotTheFood
  • Last login:January 01, 2010, 11:05:06 am
« Reply #15 on: May 22, 2007, 09:26:00 am »
Well, I haven't actually built my cab yet, but the plans are almost done, the parts have shipped from ggg and the computer hardware is just waiting to have the dust blown off of it.
OS is probably the easiest choice so far in this project.
Slackware linux of course.  Why because it lets me do what I want the os to do.  no need to strip anything, just don't install any extra stuff in the first place.  I already have it installed on my laptop, server and mp3 boombox, so most of the other programs i will need are already made into slackware packages in a directory on the server.
also when you plug in a usb hid device it just starts working.  if you plug it into a new port, it just works, you dont have to click "continue anyway"  a bunch of times for a device that you have used before in the same machine.
msi nforce1 board with athlonXP 1800+
512 mb
whatever hdd is handy
Havok
« Reply #16 on: May 22, 2007, 09:38:09 am »
Windows XP
AMD Athlon 3300+
X300 PCI-e 256MB video
250GB Hard Drive
512MB RAM
« Last Edit: May 22, 2007, 12:19:46 pm by Havok »
rovingmind
  • Last login:October 17, 2023, 11:13:48 pm
  • If you only knew the POWER of the Dark Side
    • rovingmind
« Reply #17 on: May 22, 2007, 09:51:21 am »
ibook 6oomhz dual usb running OS X 10.4, <- secondary
athlon 1.4 gig, 512meg ram, chaintech nvidia geforce 4, running XP,  <- main
350mhz, 16meg generic graphics card, 1gig ram running Mandrake linux. <- going into a cocktail for classics.
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHHH!!!!!
Tiger-Heli
    • Tiger-Heli
« Reply #18 on: May 22, 2007, 09:52:02 am »
I cheated and voted for WinXP anyway.  I don't have a dedicated arcade-gaming setup, but I run WinXP and MAME on my primary computer, and it's what I would load on a dedicated cab, and is more than just an occasional game system.
AMD Barton XP 2800+
1.5 G Ram
Drawbacks - Mainly I can't use a USB keyboard and hot-swap the KeyWiz.  WinXP will not detect the PS/2 Keyboard device unless it is connected at bootup.  Win98 assumes you have a PS/2 keyboard installed, so no such problems.
gnateye
  • Last login:December 05, 2011, 11:22:36 am
  • 4 cabs and counting!!!
    • natty's arcade
« Reply #19 on: May 22, 2007, 10:09:15 am »
mac os 8.6 super stable and runs macame .57 perfectly, runs faster than other os x rigs on my 300mhz beige desktops i salvaged.....
Kaytrim
  • I'm too nice a guy
« Reply #20 on: May 22, 2007, 10:59:38 am »
TinyXP Beast edition on a PIII 730mhz with 512M ram.
Fast and dedicated. ;D
ahofle
    • Arcade Ambience Project
« Reply #21 on: May 22, 2007, 11:07:34 am »
I smell an upcoming arcade cabinet software product announcement from GGG.  ;D
Oh, I voted 98 and XP because I just upgraded last week (and only to get the better ArcadeVGA drivers).
I am using an Athlon XP 2000+ with 512 Meg RAM.
Kaytrim
« Reply #22 on: May 22, 2007, 11:14:27 am »
He could be looking at the OS demands for his new 49-way joysticks and interface. ;)
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« Reply #23 on: May 22, 2007, 11:21:12 am »
Windows XP this is the computer on my upright quad 4
AMD Athlon 4000+
arcadevga PCI-e 256MB video
250GB sata Hard Drive
1 gig MB RAM
Windows XP considering VISTA but it sures slows down the computer
AMD Athlon 4000+ computer on my racing set down cab
xvga 7900 GS PCI-e 512MB video
2 gig Corsiar extreme RAM
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
ahofle
« Reply #24 on: May 22, 2007, 11:37:13 am »
I certainly hope he's way past that point for the new 49-ways!  I thought they were just about ready to go?
Havok
« Reply #25 on: May 22, 2007, 12:22:18 pm »
AMD Athlon 4000+
1 gig MB RAM
Stay away from Vista if you have XP - it WILL run slower on the same hardware - I have already seen this on a few systems I run at work (new hardware too...)
grundle
  • Last login:July 20, 2016, 11:17:27 pm
« Reply #26 on: May 22, 2007, 12:23:24 pm »
I use Arch Linux.  There are XMame and wahcade packages available and it doesn't install anything you don't ask for.
I would use XP because it's easier to set up, but the price tag is too much for me.  I already have three computers running xp (two that have office also,) so I think I've paid enough into the Gates Foundation.
Dervacumen
  • Last login:June 12, 2024, 01:58:21 am
  • Home of Three Squares dice game
    • Beaker Games
« Reply #27 on: May 22, 2007, 03:03:05 pm »
I use Windows ME so I chose the Win95 option.
Windows ME is the only legal copy I had that was disposable for my cabinet.
Bringing to life a child's imagination.
ark_ader
  • I glow in the dark.
« Reply #28 on: May 22, 2007, 03:15:32 pm »
For the bartops I use good old DOS on CF.  Cannot beat it, and it runs real fast on vintage laptops.  If its vintage gear and windows is required then NT4.0 SP4 is the ticket.
For my main Athlon rig I use Tiny XP or 2000 Lite.  Both can be very fast on 512MB.  I just wish I knew how to load the OS into memory like you can Linux...
I hear that Windows 2000 ramdrive might work...
It tickles me that I can get a laptop on ebay for £10 and run Pacman and Dig Dug on it.   :laugh2:
Raitsa
  • Last login:March 29, 2024, 10:45:35 am
« Reply #29 on: May 22, 2007, 03:21:50 pm »
I am using TinyXP rev06 and loving it, really fast & hasslefree ;)
fuadramsey
  • Last login:July 17, 2008, 12:12:02 pm
« Reply #30 on: May 22, 2007, 03:37:11 pm »
XP
NoOne=NBA=
« Reply #31 on: May 22, 2007, 06:59:05 pm »
I use a G3/300 B&W Mac on my main cab, running OS 9.2.
miles2912
  • Last login:October 31, 2019, 05:30:24 pm
  • My first Home Game. Fairchild System F.
« Reply #32 on: May 22, 2007, 08:08:51 pm »
Yea XP because it is easy and just about everything works with it.
Don
  Scratch built upright MAME Cab
turbo6
  • Last login:June 28, 2012, 10:03:40 pm
« Reply #33 on: May 23, 2007, 12:39:24 am »
Win XP for stand up cab:
AMD Athlon XP 2000+
512 MB Ram
GE Force 2/32 mb video
Tiny XP Beast Edition for my cocktail cab:
PII 400 mhz
192 MB Ram
TNT Video Card
Using Mame v90 for both cabs. Tried to use Tiny XP on my stand up cab but had problems with House of the Dead... Wouldn't run, just black screen. Runs fine on full version of XP.
danny_galaga
  • Online Online
  • Last login:Today at 12:26:56 am
    • dans cocktail lounge
« Reply #34 on: May 23, 2007, 08:27:51 am »
win98 here (and mame32 'front end'. yeah, i know, i know  :-[). why is win95 lumped in with 98? id like to see how many of each. i might try tiny xp or something for the next one since atomic runs well on xp but takes a bit of work on win98
albarellij
  • Last login:October 24, 2018, 09:31:29 am
« Reply #35 on: May 23, 2007, 10:53:10 am »
Win 98 w/ Mamewah, on a P2 w 512M RAM.  I don't imagine much else would run ont he machine but DOS or 95 or 98.
« Reply #36 on: May 23, 2007, 11:04:11 am »
The only PC based dedicated setup I have right now is the one I'm currently building - which is a win98se box specifically because it is for games that require 95/98.  It will not have MAME on it.
northerngames
  • Trade Count: (+18)
« Reply #37 on: May 23, 2007, 11:26:18 am »
xp pro sp2
nanao 26" monitor with switachable res.
1 gig ram
AMD 64 3200
arcadevga2
mamewah
avgain for native auto res
WD caviar 160 gig hdd
ulti minipac
ElKootcho
  • Last login:October 22, 2012, 07:58:43 pm
« Reply #38 on: May 23, 2007, 12:54:31 pm »
OS X only because I'm a Mac guy and had a spare BW G3 floating around. If I had my choice I'd run Windows simply so that I'd have more options including front end launchers and pinball.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #39 on: May 23, 2007, 01:02:12 pm »
I voted DOS, but it's actually Win98se set up to boot straight to DOS mode.
NO MORE!!
