Author Topic: Kymaera Skin Editor ?  (Read 1363 times)
Thenasty
  • Last login:January 29, 2026, 11:38:03 am
« on: May 14, 2007, 10:11:32 am »
I've been toying with Kymaera, and downloaded all the files I found on the Kymeara page and I don't see the program to edit/make SKINS. I tried Kymaera config but its not there. I don't see any Kymaera SKIN EDITOR.EXE anywhere on all the zipfiles I've downloaded. Am I missing this program ? Where can I get this Skin Editor ?
Free VGA Breakout Cable
Buddabing
Re: Kymaera Skin Editor ?
« Reply #1 on: May 16, 2007, 12:01:51 am »
The skin editor is part of the configure program. In the emulator config dialog box you'll see a "skin" section. Clicking Edit in that section should pull up the skin editor.
Please read the wiki!
Thenasty
« Reply #2 on: May 17, 2007, 03:53:55 pm »
thanks Budda. Dunno how i missed that one. Maybe i been reading ahead to much and was looking for the kymaeraConfig.exe file  :banghead:
Thenasty
« Reply #3 on: May 17, 2007, 06:06:00 pm »
Budda, is the GAME_CONTROLS not working w/v2.0.2 ? I tried it several times and its not doing what it supposed to do. The only solution that I came up with is to use CONTROL_PANEL and copy the joy4way.png to GAMENAME.png etc...
Also, all the testing i'm doing now are all in Windows, I am planning to run this in pure DOS. I know the video part will not work in DOS, is there going to be a problem in DOS when I'm all done with the SKIN LAYOUT, SETUPs, etc... ? TIA for your tips.  :)
Buddabing
« Reply #4 on: May 18, 2007, 12:04:27 am »
Sorry, I don't know the answer to your question. Is your workaround sufficient? If not, maybe PacManFan will answer a PM.
I never ran Kymaera in DOS or Linux. You are correct that the videos don't work in DOS.
