Author Topic: Soft-15KHz - slim new tool for 15KHz on normal vga cards  (Read 1135780 times)
0 Members and 27 Guests are viewing this topic.
Haggar
  • Last login:February 13, 2017, 05:12:32 am
« Reply #1240 on: November 25, 2008, 04:06:17 pm »
- Project "PSremote" -
A "remote control" for PowerStrip to move/resize the image "on-the-fly" without rebooting or messing with the modelines.
Step 1: Move it!... *DONE*
Step 2: Resize it!... *DONE*
Step 3: Nice UI ala AdvV... *under construction*
Step 4: Go for world domination! ;D
Well my first real achivement is that I can move the image on screen without touching anything.
Next will be "resizing" of the screen, which most likely will be a little more complicatet that it seems.
As for now, It is just a "remote control" using PowerStrip (which is running the background to provide low-level access).
Stay tuned :)
Hey Sailor how's your project going on?
I'm very anxious to see it  ;D
SailorSat
  • Last login:Yesterday at 04:28:07 pm
    • For Amusement Only e.V.
« Reply #1241 on: November 25, 2008, 04:10:47 pm »
Actually PowerStrip seems to be messing something up.
It basically works however.
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #1242 on: November 25, 2008, 04:24:46 pm »
Not sure what your problem is, but I recall ages ago having lots of trouble with powerstrip and low pclocks - it would lockup/go really slow/be generally weird without a clean error message when you set it to a display with a low pclock.
 The author lowered the pclock floor for me a couple of times in some old betas which were successful in removing the problem. I believe these changes remain. Can't remember what the current hardcoded floor is, think it was below 5Mhz...
(no idea what issue you are having though)
SailorSat
« Reply #1243 on: November 25, 2008, 04:31:22 pm »
The issue actually is that I read a "timing string" from powerstrip, and write it back without modifications, which SHOULDN'T change anything at all, however it actually messes the cards output completely...
Happens both with a good old Matrox Millenium PCI, as well as several other cards I've tried.
Silver
    • Mods'n'Mods
« Reply #1244 on: November 25, 2008, 04:36:27 pm »
Ah, in that case can't help... only time I've had problems anything like that is when it turns out there is plenty of difference with UTF-8 vs UTF-16 vs whatever-txt-encoding.... just not easy to see!
Nemss316
  • Last login:April 28, 2010, 10:30:00 am
« Reply #1245 on: November 25, 2008, 05:34:56 pm »
I'm having some trouble on my config. as well, and am trying to figure out what to do.
I have my mame.ini files set to hwstretch 1 switchres 0. I get full screen on my games w/ no issues; but the problem i'm having is that some of my games aren't 100% smooth. SF2 for instance, when I throw a fireball, sometimes it disappears from the screen. When the player is still, the game displays perfect. But when I jump, its almost as if the game gets "jittery". Same goes for the rest of the SF games, and some other games as well. I can play the games, but when I see them run on my LCD, i realize how much cleaner the games are running on my regular PC.
FYI: I'm running a 2.4 P4, 1.5 GB of RAM, onboard sound, GeForce FX 5200. I'm using Soft15Khz, and d/l the AutoRes tool from Ultimarc. My MAME version is .112
Any Ideas?
Thanks,
Jason
« Last Edit: November 25, 2008, 05:36:56 pm by Nemss316 »
northerngames
  • Trade Count: (+18)
« Reply #1246 on: November 25, 2008, 06:08:49 pm »
you got the two backwards  :angel:
Nemss316
« Reply #1247 on: November 25, 2008, 09:24:36 pm »
I switched them around, and SF2 and most of my other games are small and centered w/ huge black borders around it.
Did I miss something?
Haggar
« Reply #1248 on: November 26, 2008, 02:40:47 am »
Try using these settings:
Use this settings for mame:
HARDWARE STRETCH MUST BE OFF
YOU MUST USE DIRECT-DRAW NOT DIRECT3D
SWITCH RESOLUTIONS MUST BE ENABLED
The command-line switches to do this if running Mame from a command line are:
-video ddraw -nohwstretch -switchres
SailorSat
« Reply #1249 on: November 26, 2008, 01:23:00 pm »
Behold! The Immolator!... Err... Whatever ;D
http://files.arianchen.de/soft15khz/psremote.zip <- consider IT a "proof of concept" plaything...
Controls are...
ESC = Fallback to defaults
ENTER = exit tool
Up/Down/Left/Right = Move the image (if possible)
Page Up/Page Down = Shrink/Expand image in height
Delete/End = Shrink/Expand image in width.
However please not that for some reason Shrinkin/Expanding the image most likely ---smurfs--- up powerstrip.
FrizzleFried
    • Idaho Garagecade
« Reply #1250 on: November 26, 2008, 01:32:20 pm »
Runtime Error 9 - Subscript out of range?
That's what I get when I attempt to run `er.
SailorSat
« Reply #1251 on: November 26, 2008, 01:42:41 pm »
You need to have PowerStrip running ;)
Ummon
  • Trade Count: (+13)
« Reply #1252 on: November 26, 2008, 06:01:35 pm »
Even more so, Nem needs to learn how to use mame, or mame32/UI as it's all in front of you then.
Yo. Chocolate.
Stephen Hawking
Ummon
« Reply #1253 on: November 26, 2008, 06:03:45 pm »
I remember seeing something like this in Power Strip itself but perhaps more complicated? Essentially your tool is just a specialized app to make PS do this without having to delve into it? And it's not necessary to load modes via PS, just have it running, right?
Yo. Chocolate.
Stephen Hawking
SailorSat
« Reply #1254 on: November 27, 2008, 12:32:55 am »
Yup.
Basically you would need to define hotkeys, as the default PowerStrip Controls don't work too well with lower resolutions.
Haggar
« Reply #1255 on: November 28, 2008, 09:47:23 am »
I've tryed the PSRemote.
It worked well for some resolutions.
With 321x240 and 304x240 when I've tryed to move the image, all screwed up, and I had to restart (esc key hasn't worked). After reboot, I had again the screwed up res. At second reboot it returned ok to 640x480.
One question: when you hit enter, it saves the modeline modified in the registry? To return at initial point I have to do an unistall-install?
« Last Edit: November 28, 2008, 10:23:40 am by Haggar »
SailorSat
« Reply #1256 on: November 28, 2008, 10:46:19 am »
Actually PowerStrip saves whatever resolution you tweaked...
To get back to stock, just don't start powerstrip :)
Ummon
« Reply #1257 on: November 28, 2008, 07:50:09 pm »
Gotta love beta testing.
Yo. Chocolate.
Stephen Hawking
Texasmame
  • No, no. He's in charge here.
  • Last login:February 18, 2022, 05:28:39 pm
  • Ba, ba, boom!
« Reply #1258 on: December 01, 2008, 12:56:24 pm »
I'm using a T.V.
Would there be any benefit to me using this software?
retrometro
  • Last login:May 24, 2024, 09:11:44 pm
    • Arcade, mame, retro... and the gp2x.
« Reply #1259 on: December 02, 2008, 09:02:34 pm »
I'm using a T.V.
I don't think any standard TV's will multisync to different resolutions / refresh rates, etc.  So no.
-------- gp2x and retro... play it forever! ------------------------
http://www.youtube.com/view_play_list?p=0EE573E86D5A86E0
SailorSat
« Reply #1260 on: December 03, 2008, 12:08:33 am »
Infact they do, as long as the signal is 15khz, and is fed via RGB.
Texasmame
  • Ba, ba, boom!
« Reply #1261 on: December 04, 2008, 12:51:22 pm »
K.  Thx.  Using SVid, so looks like a no here.
Ummon
« Reply #1262 on: December 04, 2008, 07:51:10 pm »
Try 640x480 interlaced. This is a default mode as long as 31khz modes aren't loaded (in which case it becomes VGA).
Yo. Chocolate.
Stephen Hawking
Haggar
« Reply #1263 on: December 06, 2008, 06:48:37 am »
Has anyone a 640x240@50Hz modeline (for Amiga games)?
shiloh
  • Last login:May 10, 2016, 02:58:07 pm
« Reply #1264 on: December 15, 2008, 11:32:36 pm »
Hello everyone
Today I received a new WG D9800 monitor for my cab. I do have an ArcadeVGA in my cab but I am testing on a separate computer Soft15khz and the new monitor to see if I'll switch to soft15k in my cab when installing the monitor.
So far it was pretty easy. However when I run games in standard resolution, they look good, I would say as good as my old standard resolution WG with the ArcadeVGA, but the OSD on the D9800 says it's running at a 31khz resolution not 15k.
what's wrong?
I am using a 6800gt with forceware 93.71. I have removed some modes to make sure there was less than 32 resolutions defined. Mame is set to ddraw, hwstretch off and swtichres on. I made sure that mame use the right resolution (checked by using the verbose mode or forcing the right resolution)
medium resolution seems to be ok and are reported as 25khz by the monitor OSD.
thanks all, much appreciated.
« Last Edit: December 15, 2008, 11:36:16 pm by shiloh »
northerngames
« Reply #1265 on: December 16, 2008, 04:53:08 pm »
are you using the avres tool from ultimarc so that mame runs them at the correct display res or are you using stock mame res settings wich would give you 31K mode's
shiloh
« Reply #1266 on: December 16, 2008, 06:10:57 pm »
I didnt use AVRES but I have done INI files for the ROM I use to make sure the games run in the correct 15K resolution. I have confirmed that it is in fact the case but turning on verbose mode on MAME and checking the used resolution. Mame is definitely using the correct 15k resolution
random92
  • Last login:March 24, 2012, 12:09:26 pm
« Reply #1267 on: December 17, 2008, 11:23:18 am »
Hey lads...what I want to know is, is it possible to output 240p to a normal crt tv by component? No SCART tvs in the US, unfortunately.
I have a radeon HD2900 if that matters. 480i just looks terrible for classic games. I used to think it looked decent until I bothered to play my old systems again.
Ummon
« Reply #1268 on: December 17, 2008, 05:03:46 pm »
....some good pictures of the display running, if you can. And it's possible, as with my 6200, that your 6800 is doubling the refresh. What does it say in the OSD in-game on that?
What systems? If you mean console, they were all on SD TVs, which of course were 480i.
Yo. Chocolate.
Stephen Hawking
shiloh
« Reply #1269 on: December 17, 2008, 06:13:27 pm »
I did some more test. I uninstalled soft15k and re-installed with only the 15k mode enabled. The desktop now appear in interlaced 640x480 and the D9800 OSD report a 15.7khz frequency.
Next I started mame with pacman. The monitor still shows a 31Khz resolution with pacman so it seems that my videocard is definitely doubling the lines.
is there something that need to be tweaked to have a 15k resolution or I need to switch to another card?
Pictures are available here: http://cid-e4ecfba58f51d061.skydrive.live.com/browse.aspx/Public?authkey=IDiSaNorwhM%24
here is the verbose output of mame -v pacman:
Parsing mame.ini
Parsing mame.ini
Video: Monitor 00010001 = "\\.\DISPLAY1" (primary)
DirectDraw: Using DirectDraw 7
DirectDraw: Configuring device NVIDIA GeForce 6800 GT
Target refresh = 60.606061
DirectDraw: Selecting video mode...
   640x 480@ 60Hz -> 63.906187
   256x 240@ 60Hz -> 62.276497
   256x 264@ 60Hz -> 62.281695
   288x 240@ 60Hz -> 62.273001
   296x 240@ 60Hz -> 62.272416
   304x 240@ 60Hz -> 62.271903
   321x 240@ 60Hz -> 62.271001
   321x 256@ 60Hz -> 62.271844
   336x 240@ 60Hz -> 62.270362
   352x 256@ 60Hz -> 62.270362
   352x 264@ 60Hz -> 62.270687
   352x 288@ 60Hz -> 70.016089
   368x 240@ 60Hz -> 62.269333
   384x 288@ 60Hz -> 68.475332
   392x 240@ 60Hz -> 62.268760
   401x 256@ 60Hz -> 62.268913
   448x 240@ 60Hz -> 62.267814
   512x 240@ 60Hz -> 62.267119
   512x 288@ 60Hz -> 65.724359
   512x 448@ 60Hz -> 64.491323
   512x 512@ 60Hz -> 64.213469
   632x 264@ 60Hz -> 62.266461
   640x 240@ 60Hz -> 62.266302
   640x 288@ 60Hz -> 64.662233
   720x 480@ 60Hz -> 63.715530
   800x 600@ 60Hz -> 63.389011
  1024x 768@ 60Hz -> 63.044791
DirectDraw: Mode selected =  352x 288@ 60Hz
DirectDraw: primary surface created: 352x288x32 (R=00FF0000 G=0000FF00 B=000000FF)
DirectDraw: New blit size = 224x288
DirectDraw: blit surface created: 224x288x32 (R=00FF0000 G=0000FF00 B=000000FF)
DirectSound: Primary buffer: 48000 Hz, 16 bits, 2 channels
RawInput: APIs detected
Input: Adding Mouse #1: \??\HID#Vid_045e&Pid_0713&Col02#7&ccc6a60&0&0001#{378de44c-56ef-11d1-bc8c-00a0c91405dd}
Input: Adding Gun #1: \??\HID#Vid_045e&Pid_0713&Col02#7&ccc6a60&0&0001#{378de44c-56ef-11d1-bc8c-00a0c91405dd}
Input: Adding Kbd #1: \??\HID#Vid_06a3&Pid_8020&MI_00#7&21e641d9&0&0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd}
DirectInput: Using DirectInput 7
« Last Edit: December 17, 2008, 06:33:20 pm by shiloh »
random92
« Reply #1270 on: December 18, 2008, 12:19:27 pm »
no, sir, they were not. they displayed at 15kHZ progressive. if anyone kows how to get a computer to give this kind of a signal to regular tv through s-video/component please share. it doesn't look like you can, however,....
thanks
Ummon
« Reply #1271 on: December 19, 2008, 09:10:19 pm »
thanks
I don't know what consoles you're talking about that wouldn't be used on a TV. Maybe an EDO or something?
Ahn-huh, notice the refresh. It's 101hz. It still gives natural scanlines - check my sig to learn why - but the refresh is doubled, or close to. However, there could be a cap to that on your monitor, meaning some games will need a range of up to 125hz to be able to display.
Yo. Chocolate.
Stephen Hawking
SailorSat
« Reply #1272 on: December 20, 2008, 04:05:00 am »
Does that happen on "more" resolutions or just one or two?
Test with quickres pls.
Right now I'm pretty clueless, as I've heard of that problem (NVidia only) several times now, but can't reproduce it on any of my cards :(
*EDIT*
You're sure you only remove resolutions with the customXXkhz.txt files?
SailorSat
« Reply #1273 on: December 20, 2008, 04:19:01 am »
You're right, however I don't know enough about that TV encoder chips.
All I can tell is that they resample the image from the framebuffer :)
shiloh
« Reply #1274 on: December 20, 2008, 09:50:17 am »
*EDIT*
I went thru all resolution with Quickres. 640x240 and 640x288 works fine and display in 15khz. all other resolutions are linedoubled.
I've found a cheap Radeon 9600 on ebay so I went ahead and bought it. That should fix it :)
random92
« Reply #1275 on: December 21, 2008, 03:42:40 am »
Ah, no problem. Thanks for the response anyway, Sailorsat.
JayL6
  • Newbie
  • Last login:June 30, 2014, 07:10:10 am
« Reply #1276 on: December 22, 2008, 07:29:50 am »
*EDIT*
Hi Shiloh,
I think that you have made the right choice in getting a different video card.  I had exactly the same problem as you trying to get soft-15KHz working with my 6800gt, it just wouldn't display the low resolutions at 15k.
Think that I tried everything, then gave up.  I then replaced my video card with a 7600gt and Soft-15KHz works flawlessly with it.
I haven't tried an ArcadeVGA video card, but the results that I get from soft-15KHz make the games on my arcade monitor look identical to how I remember them looking in a real arcade.
lettuce
  • Make It So!
« Reply #1277 on: December 26, 2008, 06:53:01 am »
Be careful of this however!!. My tri-sync monitor like 95% of other tri-sync monitors are not that great when displaying 15khz modes, you'll probably notice the right hand side of the screen will be compressed/squished. I sorted this problem out by using Mames built in resolution, which gave a perfect 15khz type display (natural scanlines) but was displaying in 31khz mode, as it was doubling the refresh rate, and had no compression on the right hand side of the screen what so ever, so was really pleased!!! But!.....my monitor specs are only up to 90hz on the horizontal refresh, and have been informed that running over this (in your case 101hz to 125hz) will in time cause your monitor to fail, so be very careful. As i didnt want my monitor to fail (not sure if it ever would, but to be on the safe side) i had to go back to the 15khz display modes for 15khz games and put up with the compression on the right hand side  :'(
random92
« Reply #1278 on: December 27, 2008, 08:50:58 pm »
Hmmm, should something like this work for normal TVs that accept Y-Pb-Pr only? An adapter like this can transcode the PC signal to the YPbPr mode. If the PC signal is 15kHz, no problem?
lettuce
  • Make It So!
« Reply #1279 on: December 28, 2008, 06:13:46 am »
Does the latest version of soft15KHz work with the latest Nvidia drivers??
