Author Topic: Soft-15KHz - slim new tool for 15KHz on normal vga cards  (Read 1171507 times)
0 Members and 12 Guests are viewing this topic.
gaijin4life
  • Last login:February 18, 2008, 06:31:14 pm
« Reply #280 on: February 07, 2008, 02:53:56 am »
I'm still in the dark about how to get this running properly on the arcade monitor.  I have a TinyXP PC running a Matrox Millennium II / PCI 8MB with the last released Matrox drivers for this card.  I run Soft15khz (from a folder called Soft15k), and select the Matrox card, then hit the "install 15k" button.  At this point it's still hooked to a PC LCD.  I then load quickres and the list of available resolutions is long and strong.  I select 320x240.  I then switch the VGA connector to the one going to the JPAC in the cabinet and get a double side-by side flickering image of the 320x240 tinyxp desktop on the arcade monitor, which is a Wells-Gardener 7602.  I'm sure this is related to the refresh rate or interlace (or lack thereof), but I cannot figure out what I'm doing wrong.  Ideas?
SailorSat
  • Last login:March 02, 2026, 11:07:22 pm
    • For Amusement Only e.V.
« Reply #281 on: February 07, 2008, 02:56:50 am »
You know you need to reboot after installing?
gaijin4life
« Reply #282 on: February 07, 2008, 02:59:34 am »
Oh, sorry, yes.  There was a reboot after the Soft15k, but before the quickres.
SailorSat
« Reply #283 on: February 07, 2008, 03:01:57 am »
There should be no resolution of 320x240 with Soft-15kHz.
Try switching to 640x480 first.
gaijin4life
« Reply #284 on: February 07, 2008, 03:09:22 am »
I just redid this to see what was happening.
If I *don't* reboot, I get a huge list in quickres - double image when I switch over to the arcade monitor.
If I *do* reboot, I only get 640x480, 800x600, 1024x768 at various color depths in quickres.  Still a side-by side image on the arcade monitor at 16/24/32 bit 640x480.
So you're saying I need to run soft15k (once), reboot, then select 640x480x32bit in quickres and then switch the connector to the arcade monitor?  If so, I've done that but still get the side-by side half images on the WG7602 arcade monitor.
(BTW, thanks for the great help)
« Last Edit: February 07, 2008, 03:14:28 am by gaijin4life »
SailorSat
« Reply #285 on: February 07, 2008, 03:19:12 am »
That more sounds like it doesn't work at all. You shouldn't be able to see anything on the LCD after the reboot.
gaijin4life
« Reply #286 on: February 07, 2008, 03:28:54 am »
So the fact that I can see windows on the LCD monitor means that it's not working?  If it does work, I should get an "out of range" message, then?
If that's the case, it isn't working, then, even though the install program seems to indicate that it thinks it's installed and working.
Any ideas on what I can check/change?
The one thing that may be causing problems is that this motherboard has a built-in AGP Intel845GL video circuit.  I've disabled it, but it might be worth mentioning.  I initially tried installing Soft15khz with that, but it would only show up greyed out and was not selectable, so I disabled it and put the Matrox card in.
SailorSat
« Reply #287 on: February 07, 2008, 03:31:21 am »
Hm... What driver version is "the newest"? Should be something like 5.92 or 5.94.
Do you have any other card available? (a GeForce or a Radeon?)
*EDIT*
The OnBoard Intel shouldn't interfere.
gaijin4life
« Reply #288 on: February 07, 2008, 03:38:35 am »
Version is 5.33 006
Where is the 5.92 version for the PCI Millennium II?  I didn't see anything that high on Matrox's site for that card.
Edit: Nevermind.  I found 5.82.018 in their legacy section.  I'll try that now.
« Last Edit: February 07, 2008, 03:42:38 am by gaijin4life »
SailorSat
gaijin4life
« Reply #290 on: February 07, 2008, 04:00:01 am »
Partial success!
I uninstalled Soft15khz, then the prior matrox driver, and installed the new matrox driver (called "final" on their site), then rebooted, then reinstalled soft15khz, then rebooted but the image was still visible on the LCD.  I had to go into matrox's monitor adjust controls and select 60 for the refresh manually then the lcd went out and soft15khz seemed to kick in.
I can SEE the windows desktop fine (well blurry, but overall okay) now on the WG7602.  However, then I try to run mame (neogeo roms on mamepp), it says the requested video mode is unavailable and Direct3D failed.  I'm running DirectX8.  Seems like I'm pretty close.
« Last Edit: February 07, 2008, 04:01:52 am by gaijin4life »
SailorSat
« Reply #291 on: February 07, 2008, 04:12:22 am »
Either set Direct3D Version to 8 in MAME, or try DirectDraw.
gaijin4life
« Reply #292 on: February 07, 2008, 04:23:59 am »
MAME was setting itself to version 8 automatically (at least it reported that in "-verbose" mode), so I'll give DirectDraw a shot.  Thanks for getting me this far so that the Soft15Khz is working!
SailorSat
« Reply #293 on: February 07, 2008, 04:28:59 am »
Now that I think of it...
I don't think the (ancient) Millenium II does support Direct3D 8 either, so DirectDraw is the way to go.
bent98
  • Hyperspin Moderator
« Reply #294 on: February 07, 2008, 07:19:13 am »
Sailor can you post some additional usermodelines that you use for mame?
SailorSat
« Reply #295 on: February 07, 2008, 07:53:49 am »
Err... Not really, I just use the base ones :)
However I got something lurking around.
We have the "Cruis'n"-Resolution (25kHz though)
modeline "512x400 25kHz 57Hz" 15,87 512 576 640 640 400 404 408 435 -hsync -vsync
bent98
« Reply #296 on: February 07, 2008, 09:32:18 am »
Cool.
Hey just to test since I am limited with modelines right now on nvidia card. can you tell me what modeline would run pacman as close as possible to its orginal state. Keep in mind I am running a Bilabs 27 inch monitor in the horizontal position.
thanks sailor
Btw I havent heard back from the omega driver team yet. I know you had mentioned intel driver limit. When he responses to my email I can ask about that too. Do you want to tell me specifically what to ask about the intel driver need to be addressed?
« Last Edit: February 07, 2008, 09:34:45 am by bent98 »
SailorSat
« Reply #297 on: February 07, 2008, 10:01:59 am »
Err... Is that a Multisync Monitor or just 15kHz?
In 15kHz you would use 352x288, however the game will be slowed down from 60Hz to 50Hz.
In 25kHz i would use 512x384, although you will get some borders above and below.
Its quite impossible to get close to its real state on a standard Arcade Monitor, although it COULD be possible your monitor can go up to something like 16.5kHz, and a vertical refresh of say 55 to 56Hz, however I wouldn't fool around with that as it would certainly not work with other games/resolutions.
Somewhere in there should be a counter running from 1 to 5, in Intel GMA drivers it references to "DTD_#" where # is the number. In the Intel Embedded drivers the same happens, although the registry key has another name.
bent98
« Reply #298 on: February 07, 2008, 10:54:35 am »
27" 15~48 kHz VeriFlat™
Autosync™
CGA/EGA/VGA/SVGA/XGA Penta-Resolution
V-Freq. 47~90 Hz
those are the specs so yes I can do 16.5hz. Would you be able to give me the specifix modeline that in your option would best run pacman.
thanks again for your help sailor
« Last Edit: February 07, 2008, 04:18:02 pm by bent98 »
SailorSat
« Reply #299 on: February 07, 2008, 11:15:04 am »
Be VERY carefull :) I don't belive there are that many monitors that support 15kHz - 31kHz, most support only 15-16kHz, 24-25kHz, 31+kHz.
However here we have 3 modelines running 352x288 pixel resolution with real 55Hz, 57Hz or 60Hz
modeline '352x288 18,7kHz 60Hz' 8,68 352 368 408 464 288 289 292 312 -hsync -vsync
modeline '352x288 17,7kHz 57Hz' 8,25 352 368 408 464 288 289 292 312 -hsync -vsync
modeline '352x288 17,1kHz 55Hz' 7,96 352 368 408 464 288 289 292 312 -hsync -vsync
Those are way higher than 16.5kHz ("extended resolution").
Although your monitor won't blow up if it doesn't work.
« Last Edit: February 07, 2008, 11:17:11 am by SailorSat »
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #300 on: February 07, 2008, 03:27:09 pm »
Interesting modelines -  I've got an old NEC presentation monitor stored away that will genuinely do 15-31Khz. I'll have a test at some stage...
Ummon
  • Trade Count: (+13)
« Reply #301 on: February 07, 2008, 04:44:32 pm »
Ahem. gaijin HAS to use DirectDraw to properly display native resolutions. If you want to know why, gaijin, read the Ultimarc monitor faq.
This one can. It spans something like 14.5-23khz, then jumps I think to 25-31.5, and maybe jumps again.
Not only a good test device, but also a good project monitor. What are you using soft15 with?
« Last Edit: February 07, 2008, 04:51:47 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
SailorSat
« Reply #302 on: February 07, 2008, 05:41:02 pm »
Not really... Hey COULD be using cabMAME ;)
Ummon
« Reply #303 on: February 07, 2008, 07:36:04 pm »
I don't know what in your build would make it different regarding native res. By the way, no more error. I have a suspicion it was a virus/malware thing that required an update in software.
Yo. Chocolate.
Stephen Hawking
bent98
« Reply #304 on: February 07, 2008, 10:34:57 pm »
I used a low res modeline generator and I get different number sailor. How do you cacluate the ones you came up with?
Also I tried using new build of soft 15 and when I click on install user
give me 'runtime error 9' subscript out of range
I did have a usermodes.txt with
Once I took out usermodes.txt It let me install user. What am I doing wrong?
« Last Edit: February 07, 2008, 10:58:28 pm by bent98 »
gaijin4life
« Reply #305 on: February 08, 2008, 12:33:46 am »
So I am now operational with a frontend on MAMEPP.  THANKS FOR ALL THE HELP with Soft15khz.  The hardest part was that I wasn't sure what was supposed to happen after the Soft15khz was installed.  Once it was clear that it was installed but not working, sending me off to get a newer Matrox driver, everything fell into place.
For the record, here's the steps to get it running on a Matrox Millennium II:
1. Install Matrox drivers. Version 5.82 is the final version for XP.
2. Reboot.
3. Install Soft15khz by running the program in a writeable directory and selecting the appropriate install (15, 25, 31, USER).
4. REBOOT.
5. When XP comes back up, it should no longer be visible on the computer monitor, if you get "out of range" that's good!
6. If you got "out of range" on your computer monitor after reboot when the windows desktop should have come up, switch the connector to your arcade monitor - it should be visible as a solid image now.  If you can still see windows on your computer monitor but not the arcade monitor, you may need to tweak Matrox montior settings.  Select the custom controls and UNCHECK "simple controls".  Select 640x480x32bit 60hz.
7. Once the desktop is visible, run mame from the command line with "mame - cc" to make a configuration file mame.ini.
8. Edit the newly created mame.ini file and replace "d3d" with "dd" so Mame will use DirectDraw instead of Direct3D.
At that point everything should work!
SailorSat
« Reply #306 on: February 08, 2008, 01:34:19 am »
cabMAME doesn't stretch die image to full resolution as base mame does.
i just used the modeline already in soft15kHz and simply pulled up the pixel clock.
i'll look into it.
« Last Edit: February 08, 2008, 01:38:29 am by SailorSat »
SailorSat
« Reply #307 on: February 08, 2008, 01:52:49 am »
sh*t... another time that stupid decimal seperators...
build 38 is up.
i didn't convert it at ONE point... nice find bent :)
Silver
    • Mods'n'Mods
« Reply #308 on: February 08, 2008, 06:22:05 am »
bent98 - if you are copying and pasting modelines from soft15Khz/this thread and pasting them into an online converter you need to note the decimal seperator.
I used an online modeline calculator which comes up with an incorrect result if you plug in:
as it does not read the 17,7 correctly. You need to change it to 17.7 instead.
Silver
    • Mods'n'Mods
« Reply #309 on: February 08, 2008, 06:25:32 am »
It's my plan to use it as a project monitor once I build a cab (several years in the planning so far...). I've actually got 2, but both need a bit of work and one does not appear to support the full scan range (does 15-17Khz, then jumps to 28khz or so). The other appears to support everything. Sadly I keep them stored away most of the time as they are absolutely massive and ridiculously heavy!
bent98
« Reply #310 on: February 08, 2008, 07:20:26 am »
I didnt get a chance to try to test build 38 but with the new build I still need to change  17,7 to 17.7 in usermodes.txt right?
SailorSat
« Reply #311 on: February 08, 2008, 07:41:09 am »
Soft-15kHz will read both.
bent98
« Reply #312 on: February 08, 2008, 09:24:43 am »
Sailor the modeline creation is confusing to me. Is there somewhere I could read up on it further or maybe you can shed some additonal light on the subject. Still not sure on how you came up with those values for the three test modes you told me to try out for pacman.
Secondly the issue I was having with my geforce 7950 doubleing refresh on certain resolutions. The fix was using those alternate modelines remedy the doubling.  How were the created? listed below
modeline '240x240@58,795' 4,83 240 252 276 310 240 243 246 265 -hsync -vsync (Soft 15 default)
modeline '240x240@60,436' 5,3 240 240 280 336 240 244 247 261 -hsync -vsync (nvidia geforce 7 friendly)
SailorSat
« Reply #313 on: February 08, 2008, 09:32:41 am »
Read http://easymamecab.mameworld.net/html/monitor1.htm, it pretty much describes it all.
bent98
« Reply #314 on: February 08, 2008, 06:25:25 pm »
I just tried out build 38. It installed with no errors.
I added thismodeline '352x288 17,7kHz 57Hz' 8,25 352 368 408 464 288 289 292 312 -hsync -vsync
to the usermodes.txt file
I did also see the resolution in forceware custom resolution tab. I tried running pacman and edited the pacman.ini file to reflect 352x288@57
I didnt seem to work. I did not remove orginal modeline 352x288 custom15khz.txt.
I think you said you can have two same resolutions co-exsist.
What am I doing wrong sailor?
« Last Edit: February 08, 2008, 08:57:28 pm by bent98 »
SailorSat
« Reply #315 on: February 09, 2008, 02:35:23 am »
Wait... I'll just take a look in my magical orb...
Don't know what you did :)
If you see the resolution in the forceware you should also see TWO refresh rates (57Hz and 60Hz)
bent98
« Reply #316 on: February 09, 2008, 08:07:48 am »
Yes I do see two.
I then edited pacman ini and updated the resolution to all reflect the proper refresh rate 352x288@57
than ran pacman
Once I ran PACMAN it seem to run it at the default 352x288  rez. Is there something im missing?
« Last Edit: February 09, 2008, 08:10:45 am by bent98 »
SailorSat
« Reply #317 on: February 09, 2008, 08:36:07 am »
Try running MAME with -verbose and look what it says.
bent98
« Reply #318 on: February 11, 2008, 08:53:33 am »
I removed the orginal res in custom15.txt and then it tried to grab the custom rez u made.
Only thing was monitor couldnt sync to it.
o well
Ummon
« Reply #319 on: February 11, 2008, 03:52:16 pm »
Um...when I select D3D on cabmame, I get a very little image.
Here's a question for you: I notice different timings of the same resolution will shift the image around the screen. Is it possible to create a timing specific to one's hardware that will minimize the amount of monitor adjustment of the image?
« Last Edit: February 11, 2008, 03:55:48 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
