Author Topic: NEO GEO MVS ARCADE CABINET , BUTTON A PLAYR 1 doesn't work  (Read 1831 times)
hayabusa_fmw
  • [Provisionally returned]
  • Last login:December 30, 2014, 03:24:56 pm
hey guys
i got a 1 slot neo geo cabinet
i will part it soon but meanwhile i wanna enjoy it.
but the problem is everything works exept the DARNG PLAYER 1 button 1
i put a new button , + new micro switch resoldered everything 4 times... still nothing.....
& when i go to the menu it says it's always pushed....... huh??
anyone.....
Kaytrim
  • I'm too nice a guy
Re: NEO GEO MVS ARCADE CABINET , BUTTON A PLAYR 1 doesn't work
« Reply #1 on: March 16, 2007, 05:49:05 pm »
Sounds like you have the wire connected to the normally open contact instead of the normally closed.
TTFN  :cheers:
Kaytrim
hayabusa_fmw
« Reply #2 on: March 16, 2007, 06:50:18 pm »
so what should i do :)
this is the ''thing i wanna know :) :)
thanks!!
4Aaron GE
  • Last login:July 22, 2013, 10:27:07 pm
« Reply #3 on: March 16, 2007, 08:15:02 pm »
Hook it up like this, i guess.  Also make sure the terminals aren't touching either.
hayabusa_fmw
« Reply #4 on: March 16, 2007, 08:55:21 pm »
still resoldered the thing exactly like player 2  nothing moves button B C D works.......
not A!!!!!!!!!1 grrrrrrrrrrr whyyyyyyyyyyyyyyyyyyyyy;)
4Aaron GE
« Reply #5 on: March 17, 2007, 01:12:40 am »
What happens if you disconnect the button completely?
fjl
  • Pixels Rule!
« Reply #6 on: March 17, 2007, 03:00:17 am »
If disconnected it should show up as not being pressed at all. If it does show that its still pressed then you have a short in the wiring leading up to the button. If you remove the wiring and it still shows as being pressed then either there is a short on your board like a small metal fell in it, bad solder or worst case the board itself is bad.
BobA
  • What Me Worry?
« Reply #7 on: March 17, 2007, 04:40:09 pm »
Here are some links to manuals and schematics incase you have to do a board repair.
[url][http://www.hardmvs.com/html/Downloads.htm/url]
hayabusa_fmw
« Reply #8 on: March 17, 2007, 06:19:02 pm »
thanks for the link
im still trying to figure this thing out.........
I feel weird about it cause i bought the cab only cause it had the mvs + 8 games with it........ & he told me it was 100% fonctional.....
for me a A button problem is like 20% fonctional
How can you play neo geo without A button it's the heart of the thing :)
I dusted the jamma harness + the pcb
see if it helps
i still get the same old problem...
Grrrr
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #9 on: March 17, 2007, 09:14:26 pm »
Did you try this ?
Working: Not Enough
Projects: Too Many
Progress: None
Crowquill
  • Last login:November 21, 2024, 09:42:17 am
« Reply #10 on: March 18, 2007, 12:38:35 am »
Have you tried to contact the seller? I agree that it's not 100%, but should be fixable. Even if it's a short on the PCB it should be fixable, but finding it gets tougher. Disconnect the switch and go from there.
At least with Neo-Geo games you can play most from the 2-player side.
