Author Topic: Patching Holes in metal CP  (Read 1255 times)
FrizzleFried
    • Idaho Garagecade
« on: January 17, 2007, 01:53:33 am »
OK...so I have a couple holes that I would like to fill in a metal CP.  The problem is that the new holes I want to drill will partly fall in to the current "hole".
What material should I use to patch the hole?  Should I try to drill my new holes first or could I patch...let dry...then drill new holes?
fjl
  • Pixels Rule!
Re: Patching Holes in metal CP
« Reply #1 on: January 17, 2007, 03:47:38 am »
There is perhaps some way to "patch" metal. But I don't know of any. If I where in your position, I would simply start over with a new metal CP. You can try bondo but its not really suited to fill holes that will be taking a beating.
Only other thing i can think of is to weld it. But that's excessive.
daywane
  • GRRRR!
« Reply #2 on: January 17, 2007, 07:34:42 am »
If it were me . I would use a piece of sheet metal under the CP
solder it in, or jb weld.
fill with bondo. let it harden. and drill. I find bondo is plenty stong.
I have never had luck drilling into a hole. drill bit jumps into the other hole and makes a ugly mess.
unless you plan on running a car over your CP . I think Bondo is stong enough
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #3 on: January 17, 2007, 07:48:35 am »
There are a number of ways to patch metal, so normally there is no need to "start again with a new panel".  :dizzy:
Standard technique (as seen in the Restoration section of the wiki) shown here:
http://girasoli.org/?p=104#more-104
BUT, having the hole overlap is the determining issue. As daywane point out, bits jump when trying to drill into a hole. Now, if you don't mind the extra panel depth, just patch as per Tony's tutorial above and drill new ... likely not a big deal for your project.
Cheers
Working: Not Enough
Projects: Too Many
Progress: None
_) (V) (-)
  • Last login:November 19, 2018, 11:56:39 am
  • There's supposed to be an earth shattering KaBoom!
« Reply #4 on: January 17, 2007, 09:24:09 am »
How big of a hole is it?
If it's a button hole and it only overlaps by 1/2 inch or so you should be fine.
Something you could do is take a patch of metal and have it braized in to cover the old hole, then use bondo to flush it up. You'll never know it was there.
Ninten-doh
  • Last login:March 31, 2017, 10:37:18 am
  • I promise sweetie, this is my last cab purchase
« Reply #5 on: January 17, 2007, 09:35:25 am »
FF, here's another related tutorial...
http://www.multigame.com/cp.html
shess
  • Last login:January 07, 2021, 04:17:28 pm
« Reply #6 on: January 17, 2007, 09:37:16 am »
I had the exact same issue with holes in metal.  I cut a 1x2" rectangle when what I really needed was a 1/2" diameter hole, don't ask me how I screwed that up.  Anyways, I took a piece of wood and clamped it underneath the hole and then took some bondo and filled in the spot so that it filled the area plus a little extra.  After it dried I sanded it down, but it turned out that my spreading job wasn't that great and the other side (where the wood was clamped) turned out to have a smoother finish.  So I flipped it over, sanded it smooth and then using the drill press, I made my 1/2" hole right into the new patch.  I haven't had a single problem with the patch being weak.  The key is to making the existing hole kind of rough.  Take a metal file and rough up all the edges, the bondo will stick better that way.  And when you're using the bondo, do it in a WELL ventilated area.  I did it outside and it still stunk horribly.  Good luck!
CheffoJeffo
« Reply #7 on: January 17, 2007, 09:42:20 am »
Working: Not Enough
Projects: Too Many
Progress: None
FrizzleFried
    • Idaho Garagecade
« Reply #8 on: January 17, 2007, 09:48:50 am »
Thank you guys... I will read the tutorials, etc.
mmmPeanutButter
  • Last login:December 20, 2020, 07:49:09 am
  • better living through gaming
« Reply #9 on: January 17, 2007, 11:19:25 am »
What I did on my centipede was get another piece of metal to go over the whole top surface and it had a bend at the top to wrap around the edge.
I cut all my new holes in this and didn't concern myself with the crap underneath.   I got the new piece of metal welded to the original panel and bondo'd the bottom edge so that the curve was smooth.
(If you need pics, I might be able to dig them up when I get home tonight)
