Author Topic: Only thing left on my cab is to fix the T-ball.. :(  (Read 1122 times)
s8n
  • Last login:April 02, 2003, 06:12:12 pm
  • The Prince of Darkness
« on: March 31, 2003, 08:44:01 pm »
my oscar spinner works fine, and the TB moves up and down, but dosent move in any other direction. i dont know what it could be, the axis' are wired fine, i think. im using an opti-pac, happ TB, winxp.
OSCAR
    • Oscar Controls
Re:Only thing left on my cab is to fix the T-ball.. :(
« Reply #1 on: March 31, 2003, 08:56:57 pm »
Did you try swapping the axis wires to see if you can isolate the problem to either a bad optic board or a broken wire in the harness?  I picked up a brand new Happ trackball not long ago, and mine was doing the same thing.  It turned out to be a broken wire in the harness that I didn't notice until I looked over all the wires very carefully.
If you swap the axis wires and the problem stays on the x-axis, then that could indicate a bad x-axis optic board.  If the problem moves to the y-axis, then you could have a bad wire in the t'ball harness.
s8n
« Reply #2 on: March 31, 2003, 09:56:29 pm »
well, thats what ill have to try, thanks oscar, hopefully its not a bad optipac  :-\
