Author Topic: Anyone here with CCTV security experience?  (Read 13688 times)
Ken Layton
  • Guru
  • Technician
Re: Anyone here with CCTV security experience?
« Reply #40 on: November 18, 2015, 01:49:57 am »
I have not done an upgrade such as that, but I don't see why you couldn't use your existing cables. If you get a Lorex system like I linked in the previous post, you should be able to directly swap out the cameras and DVR and reuse the existing camera cables.
dkersten
« Reply #41 on: November 18, 2015, 10:27:35 am »
Ken, have you ever installed an upgraded DVR/camera system like 1080p/720p on existing coax/power cables from a 480p system?  That kit looks great but I already spent a ton of time/effort running the cabling around my house for an older system (connections look the same though).  I would love a resolution upgrade now that those have come down so far in price.
Back when I was working professionally in the home theater business, all the engineers/manufacturers I talked to said coax cable (rg58, rg59, rg6) has a limit of about 600 lines of resolution.  Unless the cameras are sending digital data over a coax line, I would say the answer would be no.  On one hand I would expect modern cameras to use purely digital signals, but on the other, I would ask why use coax cabling when cat5 would be a better medium for digital signals...
Ken Layton
  • Guru
  • Technician
« Reply #42 on: November 19, 2015, 02:37:52 am »
Pre-made coax cables come with the Lorex system. That's what I used installing my friend's system and I'm getting 1920 x 1080 resolution.
Ken Layton
  • Guru
  • Technician
ahofle
    • Arcade Ambience Project
« Reply #44 on: January 02, 2016, 11:12:13 am »
I picked up the 8 camera Lorex system a few weeks ago from Costco when it was on sale for $449.  Installed it over my existing wiring and I am very happy with the results.  My only minor complaint is that the leads attached to each camera are shorter than my older cameras, so I couldn't place them in the same spots, but other than that I'm very happy with it.  I'm surprised how excellent the quality is over 100 feet of analog cabling.
