Author Topic: Kortek Chassis  (Read 2532 times)
hammad
  • Last login:August 14, 2011, 04:23:27 am
Kortek Chassis
« on: November 21, 2006, 01:26:41 pm »
Hello,
I have a request....if anyone can please mark out all the electrolytic capacitors using ms paint in this kortek chassis for me i will be very grateful to them.
eccs19
  • Last login:April 20, 2021, 10:36:08 am
  • Just plugin away!
Re: Kortek Chassis
« Reply #1 on: November 21, 2006, 02:45:58 pm »
I don't claim to be an expert, but I'm sure someone will correct me if I'm wrong, but any of those items that stand up and look like a barrel, and have the Y shape on the top, should be the electrolytic capacitors you are looking for.
Working - Mr. Do! - Neo Geo 4 Slot - Bartop Mame
Project(s) - Pacman
Thenasty
  • Last login:Yesterday at 11:00:10 pm
Re: Kortek Chassis
« Reply #2 on: November 22, 2006, 12:08:24 am »
Free VGA Breakout Cable
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
Re: Kortek Chassis
« Reply #3 on: November 22, 2006, 07:41:45 pm »
Yes, they are both right.
Why do you ask???
I assume the monitor is dead??
Based on the picture, the electolytic by the flyback has a "Bulged Top".
Just inb case the flyback is the transformer on the right with a red high voltage lead that goes to the picture tube.
If this is so, then it likely dried up, changed value and took ot other components- look for burnt resistors.
Unfortenately the list could go on....
Good luck
Rick Nieman
Niemandisplays.com
Rick@Niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
hammad
Re: Kortek Chassis
« Reply #4 on: November 22, 2006, 09:37:44 pm »
I want to know the value of the electrolytic cap that u can see in the flyback in this picture.....does anyone know what is the correct value of that electrolytic cap is in the flyback?
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Re: Kortek Chassis
« Reply #5 on: November 23, 2006, 01:49:57 am »
You've got the chassis...you tell us!
grantspain
Re: Kortek Chassis
« Reply #6 on: November 23, 2006, 03:52:51 am »
i am helping hammad resolve a few issues with this monitor,he has jail bars which is a cap fault on the ht smoothing circuit and i have told him to change all the caps,the reason he is asking about this particular cap is that someone has attached a resistor to the positive leg of the cap and i don't know why-it is possible its a factory mod but it seems more likely that its  a previous repair and its possible the last repair tech did not have the correct value cap so hence he is double checking the value
i worked on lots of these chassis in the distant past and do not remember any resistors connected to the solder side,if anyone has a schem for this chassis maybe they could look up that cap value
SirPeale
Re: Kortek Chassis
« Reply #7 on: November 23, 2006, 03:54:17 am »
Ah, when you put it in that context, it makes sense.
grantspain
Re: Kortek Chassis
« Reply #8 on: November 23, 2006, 04:12:32 am »
my feeling on this particular cap is to replace it with the value that is in there already and leave the resistor attached,change all the other caps and see what happens-what do you all think?
