Author Topic: Speech Plug-In (V1.5) In Development  (Read 27208 times)
loadman
    • MaLa
« on: October 30, 2006, 04:15:05 am »
[EDIT] This Plug-in is now being updated. See this post (and Beyond)http://forum.arcadecontrols.com/index.php?topic=59589.msg664148#msg664148
Here is a plug-in I quickly made just for fun.   :P
MaLa Speech Plug-In
It reminds me of the Voice on the game 'BEZERK'
My windows XP has the speech feature installed by default.
 If your windows has not maybe you could download the package from the folowing link:
http://www.microsoft.com/reader/developers/downloads/tts.asp
« Last Edit: April 20, 2007, 01:29:07 am by loadman »
youki
  • Atomic Front End Creator
    • Atomic Front End
Re: Speech Plugin for MaLa
« Reply #1 on: October 30, 2006, 05:49:07 am »
Really good idea that things.  Should be funny.
loadman
    • MaLa
« Reply #2 on: October 30, 2006, 06:53:48 am »
You could try it with Atomic if you want...  Very Easy  :P
uses
  SysUtils,
  Classes,
  Comobj;
var
  voice: OLEVariant;
begin
  voice := CreateOLEObject('SAPI.SpVoice');
  voice.Speak('Maa. Laa', 0);
youki
    • Atomic Front End
« Reply #3 on: October 30, 2006, 08:01:25 am »
uses
  SysUtils,
  Classes,
  Comobj;
var
  voice: OLEVariant;
begin
There is a big bug in your program...  on the last row...   ;)
headkaze
  • 0x2b|~0x2b?
« Reply #4 on: October 30, 2006, 03:00:28 pm »
Great idea loadman! I like cool things like this :)
How does it work exactly? Does it say the name of the game when you run it? Can you configure different voices?
loadman
    • MaLa
« Reply #5 on: October 30, 2006, 05:16:27 pm »
It uses 'text to speech' built in XP (not sure about 2000) either way it looks like you can download it from MS for other versions. And yes you can change voices languages via windows control panel it seems.
At the moment it is very simple
* It says MaLa on start
* It says the game name on launch
* It says (NOT TELLING) On MaLa quit/shutdown. You will have to try it
headkaze
  • 0x2b|~0x2b?
« Reply #6 on: October 30, 2006, 05:23:25 pm »
Can I take a guess? "All your base are belong to us"?
loadman
    • MaLa
« Reply #7 on: October 30, 2006, 05:25:52 pm »
 :laugh2:  I'm not that creative. (good idea though..Attitude)
  Think American
headkaze
  • 0x2b|~0x2b?
« Reply #8 on: October 30, 2006, 06:22:00 pm »
Okay I cheated and had a look in a hex editor  ;D
loadman
    • MaLa
« Reply #9 on: October 30, 2006, 06:48:10 pm »
You are just scared you will like MaLa  (Joke)
diverdown
  • Last login:April 21, 2025, 03:45:48 am
« Reply #10 on: October 31, 2006, 07:01:00 pm »
Will add it tonight
And the cabs still going great guns thanks  :notworthy:
If it ain't broke give it to me...i'll soon fix that
loadman
    • MaLa
« Reply #11 on: October 31, 2006, 07:38:38 pm »
Will add it tonight
cool... and as i said  I am open to any fun ideas for the final version, but my opinion is 'less is more'
headkaze
  • 0x2b|~0x2b?
« Reply #12 on: October 31, 2006, 08:13:38 pm »
You can download more Text-to-Speech Engines for SAPI5.Microsoft Mary, Mike and Sam 5.0 (68MB). I'm pretty sure they should work with this plugin.
One thing I would add to your plugin would be a button to open the Speech Properties window from Control Panel. The command line to launch it is:
rundll32.exe shell32.dll,Control_RunDLL "C:\Program Files\Common Files\Microsoft Shared\Speech\sapi.cpl",Speech
loadman
    • MaLa
« Reply #13 on: October 31, 2006, 08:42:56 pm »
Thanks.. I will try those
Good Idea,   The Plug-in only gets triggered when appropriate on certain evens so I doubt I would add that to it when MaLa can do it anyway...EG
You can launch things from MaLa with a user set-key. I have mine to bring up control panel if I hit the letter 'P'.
« Last Edit: October 31, 2006, 09:41:06 pm by loadman »
loadman
    • MaLa
Re: Speech Plugin for MaLa 1(RC8)or above *FINISHED*
« Reply #14 on: November 09, 2006, 04:34:46 am »
The MaLa Speech Plugin is finished
I sent it to Swindus so it should be available for download from the MaLa Website ...soonish.
Speech activated on:
MaLa Start (Custom)
Game Start (Will say launched game name)
MaLa Quit (Custom)
It has a separate ini file that you can edit to customise it for your cab for MaLa Start and MaLa Quit. This file needs to be in the plugin directory. Just edit it with notepad.
eg
[Settings]
MaLa_Start=THE MAME TABLE IS ALIVE
MaLa_Quit=PUT YOUR EMPTY BEER BOTTLE IN THE TRASH
« Last Edit: November 09, 2006, 04:36:17 am by loadman »
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
« Reply #15 on: November 09, 2006, 04:51:15 am »
Can be downloaded from the plugin page:
http://mala.arcadezentrum.com/plugins.html#Speech
edge
  • Last login:May 08, 2025, 09:08:47 am
  • AttractMode and GroovyArcade rock!
« Reply #16 on: November 09, 2006, 05:36:31 pm »
Nice job, loadman.  You are a plugin-in machine now.  :notworthy:
I can't wait to get back home to try out all this new stuff.  (I am still away for training.  :cry:)
loadman
    • MaLa
« Reply #17 on: November 09, 2006, 05:39:00 pm »
ta , That one was very easy
But hurry up and be trained already, I need your help, although it is forcing me to learn more Delphi
BULL
  • Last login:March 03, 2011, 02:18:08 am
  • GAUNTLET FOREVER
« Reply #18 on: November 10, 2006, 12:48:15 pm »
It tells me that speech.ini file not found, it reads the games allright but startup and quit doesnīt work.
any ideas?
loadman
    • MaLa
« Reply #19 on: November 10, 2006, 03:51:19 pm »
any ideas?
That was a 'cute' idea of mine for it to 'say' the error rather than a pop-up window.
It will do that if the ini file is not in the mala 'plug-in' directory with the speech plug-in. A base ini file is provided with the plug-in. The plug-in does not create it
Let me know if that does not fix it
« Last Edit: November 10, 2006, 03:53:40 pm by loadman »
BULL
  • GAUNTLET FOREVER
« Reply #20 on: November 10, 2006, 09:52:19 pm »
it is a "cute" idea  ;D
the ini is in the plugin dir.
loadman
    • MaLa
« Reply #21 on: November 10, 2006, 10:39:54 pm »
OK.. If you have changed the ini file can you post the text here?
Also What OS are you using etc
I want to try and re-create the problem
BULL
  • GAUNTLET FOREVER
« Reply #22 on: November 11, 2006, 03:22:40 am »
Solved, I was starting MaLa from a shortcut and thats why it didnīt work.
It works perfectly when I start direcly from the exe file.
thanks
BULL
loadman
    • MaLa
« Reply #23 on: November 11, 2006, 05:09:38 am »
thanks
BULL
Thanks for letting me know.
Try putting the path to mala in the 'start in' section of your short-cut properties (the same as in target bit but without '\mala.exe' at the end
BULL
  • GAUNTLET FOREVER
« Reply #24 on: November 11, 2006, 05:43:11 am »
yep, that fixed it
thanks
BULL
loadman
    • MaLa
« Reply #25 on: November 11, 2006, 07:59:03 am »
CM
  • Last login:January 02, 2012, 08:59:17 pm
  • The internet?!? Is that thing still around?
« Reply #26 on: November 15, 2006, 09:16:54 pm »
haha fun little plugin.     Dr. Sbaitso meets really difficult to pronounce ROM titles  ;)
loadman
    • MaLa
« Reply #27 on: December 11, 2006, 08:02:24 pm »
yep, that fixed it
thanks
BULL
Bull,
Would you mind trying the following version 'without' having anything in the 'start-in' section of your shortcut please? I think I fixed it
HERE
Replace your existing plug-in file with this one but keep your existing 'speech.ini' file ..  as you know both files need to be in the plugins directory.
Thanks for testing
« Last Edit: December 19, 2006, 07:17:51 pm by loadman »
BULL
  • GAUNTLET FOREVER
« Reply #28 on: December 12, 2006, 03:19:58 am »
it works but it plays the speech twice.
BULL
loadman
    • MaLa
« Reply #29 on: December 12, 2006, 06:57:56 am »
BULL
Thanks Bull
I just downloaded that version to make sure I did not make a mistake.
It does not so that for me.  The only thing I changed in the Plugin was how it searches for the Ini file
What and how many *.mplugin files do you have in the Plugins directory?
Is it possible you have two (one renamed?) and effectively it is running two speech-plugins?
BULL
  • GAUNTLET FOREVER
« Reply #30 on: December 12, 2006, 09:20:10 am »
sorry, didnt think. yes i renamed the first file, so mala played both files.
now that i removed the old plugin it works as it should.
thanks
BULL
loadman
    • MaLa
« Reply #31 on: December 12, 2006, 03:27:48 pm »
thanks
BULL
Thanks for testing Bull.  :cheers:
I will send the Plug-in to Swindus to replace the one on the MaLa Website
[EDIT] This is now on the MaLa website  HERE
« Last Edit: December 19, 2006, 07:18:47 pm by loadman »
Neilyboy
  • Last login:October 08, 2025, 08:19:14 am
  • what day is it...
« Reply #32 on: December 14, 2006, 09:45:42 am »
very cool plug loadman. ill have to try it when i get mala up and running..
Neil
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #33 on: January 03, 2007, 12:02:01 am »
Oooh dang!  I just found this.  Thanks guys!
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
« Reply #34 on: January 03, 2007, 12:01:56 pm »
sounds like fun!
I use the windows text to speech in Unreal Tournament 2004 (not a cab game) to read the chat text from other players.
This sounds like a nice feature to have.
I need to give Mala a try (yeah more cab work, this thing will never ever be finished).
loadman
    • MaLa
« Reply #35 on: January 03, 2007, 04:00:13 pm »
This very simple Plug-in can give your Cab a early '80's  feel
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #36 on: March 28, 2007, 06:18:06 pm »
This is a very sweet plugin, and like it.
It do have one problem:
Try to run Q*Bert, wich say it very funny (Q Astrerix Bert). All other chars than letters should been removing before speeching that.
loadman
    • MaLa
« Reply #37 on: March 28, 2007, 08:21:46 pm »
He he . I will 'Astrerix' fix that 'Astrerix' up for the next 'Astrerix' version  ;) which is a couple of weeks away  ;)
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #38 on: March 29, 2007, 10:32:38 am »
sorry for the spelling, but I guess you known I was talk about. It just diddent like *.
loadman
    • MaLa
« Reply #39 on: March 29, 2007, 11:56:20 am »
COOL  :D
