Author Topic: UltraStik Mapper plugin for MaLa Version 1.3.00 now released (1/30/09)  (Read 166225 times)
0 Members and 12 Guests are viewing this topic.
squirrellydw
Hmmm At a guess I would have said that is dependent on Windows...  So maybe install in a different order?
So unplug, restart and plug in one at a time?  Any idea if I should plug the one I want to use in first or last?
To continue with the guessing I would say first (so therefore, it is probably last  :badmood:).
Thanks guys it worked,  I pluged in the two I wanted to use first and it worked.
I b**ch. People listen!!
fatfingers
  • Last login:April 17, 2025, 05:26:08 pm
  • Got UltraStiks?™
How are you going to handle reboots?
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
W.W.P.M.D.?                                       I'm here to help ... I just don't do it. ™
squirrellydw
I rebooted once and all is still good.  See what happens tonight
fatfingers
  • Got UltraStiks?™
Cool.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
loadman
    • MaLa
and thanks for the Tip 'Space Fractal / Denmark' I will put that in the MaLa Wiki
squirrellydw
Hey fatfingers can you help me out with this?
http://forum.arcadecontrols.com/index.php?topic=67724.0
fatfingers
  • Got UltraStiks?™
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
I'm having trouble editing the "path" to get this working.   When I follow the instructions up until the edit part I'm not sure what to do next.  Do I just add a semicolon to the end of what's there and then c:\programfiles\ultramap (it's the folder where the ultramapper is installed)?
Any help would be great.  Thanks!   :cheers:
fatfingers
  • Got UltraStiks?™
Yes, that is exactly what you do.  Except, the path you need to add probably has a space between program and files.  This is probably what you want to add:
;C:\Program Files\UltraMap
If you still cannot get this to work let me know.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
Thanks.. I'll try right now and post the results in 5 minutes...
OK, it didn't seem to work.  After I make the change and launch MaLa I get an error message saying:
Cannot find Unistik game configuration file named:
C:\Documents and Settings\Bella\My Documents\Arcade\MaLa v 1.0 R
When I go to make the change to the path this is what I do:
right click on My Computer -> Properties -> Advanced Tab -> Environment Variables -> then I select "path" under system variables - > Edit
The line that comes up to edit says "%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\system32\Wbem" and then I add ";C:\Program Files\UltraMap" to the end of that line.
I'm probably missing something obvious - any help to get this working is most appreciated!  Thanks!!    :cheers:
fatfingers
  • Got UltraStiks?™
Please do the following for me:
  • Stop MaLa
  • Create a file called umapper.log in the MaLa directory
  • Start MaLa
  • Play a couple of games (some 4-way; some not)
  • Stop MaLa
  • Send me the umapper.log file at email address gmail.com, username fatfingersbyoac
Thanks.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
What kind of file should umapper.log be?  I made a wordpad file and it didn't do anything...  how do I create it?  Sorry for being so clueless!
fatfingers
  • Got UltraStiks?™
[confused mode]
That should have been just fine.
[/confused mode]
 :dizzy:
Edit:  Are you sure you put it in the MaLa directory?  Like C:\Program Files\MaLa?
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
I'll try it again... My MaLa folder is the default name... MaLa v1.0 RC9 and it's not in program files - I installed everything in the "Bella's Documents" folder - I'm not sure it matters but I thought I'd let you know.  I just opened wordpad and saved the file as umapper.log.  I'll post the results!  Thanks for all your help with this.   :cheers:
I just thought of something - is this compatible with RC9?
« Last Edit: July 01, 2007, 08:54:07 pm by javeryh »
squirrellydw
make sure you are showing file extensions.  Just thought I would mention that incase its named umapper.log.somethingelse
yes its compatible, mine works fine now after a little help from FF
fatfingers
  • Got UltraStiks?™
It is definitely compatible with RC9 -- I use it all the time.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
Jep, works great here too!
This is what I'm afraid of - how do I show file extensions?  I'm pretty sure the file is actually named "umapper.log.wpd" or something like it.  I will work this out tonight.   :cheers:
fatfingers
  • Got UltraStiks?™
OK, open an explorer window and browse to the MaLa directory.  Then, right click and choose New->Text Document.  Then type in the name of the file (umapper.log) and say yes I want to change the file extension when it asks if you want to.
All should be good.
Stupid windows...
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
squirrellydw
To show ALL file extensions open my computer, choose tools from the top menu, folder options, view, make sure there is NO check next to "hide extensions of known file types
fatfingers
  • Got UltraStiks?™
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
squirrellydw
OK, thanks to all of your help I was able to create the umapper file.  It has been sent to your gmail account.
« Last Edit: July 02, 2007, 10:55:10 pm by javeryh »
fatfingers
  • Got UltraStiks?™
I have sent a reply to your account and have attached a new plugin that will hopefully fix your issue.
Let me know how it goes!!!
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
Wow awesome - thanks a lot!!  Grr... now I have to wait like 10 hours to try it...
Was there something different/unexpected in the umapper.log file that wouldn't ordinarily appear?  As soon as I get home I'm going to install the new plugin and change the path... :cheers:
fatfingers
  • Got UltraStiks?™
Uh...change what path?
The thing I noticed is that some strings were getting chopped off due to buffer sizes so I increased the sizes.  Hopefully I can get that new version released soon-ish.  I've really had it ready for a long time except for the documentation which I cannot seem to get right (I know too much about the plugin).  So, if anyone cares to write a good document for installing the thing and how it works, let me know.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
Don't I have to add ";c:\program files\ultramap" to the path in "my computer -> properties -> advanced -> environment variables"?
Sorry I haven't had a chance to test it yet - my wife just gave birth yesterday and we've bee a little busy!   :cheers:
squirrellydw
congrats
fatfingers
  • Got UltraStiks?™
Yeah!  Congrats!!!
And yes, you do have to add that to your path -- I just thought you already had done that.
See you in a few years!!!   :laugh2:
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
fatfingers
  • Got UltraStiks?™
Re: UltraStik Mapper plugin for MaLa 1.0RC8 Version 1.1 now released (1/18/07)
« Reply #150 on: August 25, 2007, 06:27:29 pm »
It has come to my attention that the qbert map file is missing from my package -- sorry.  It isn't clear to me which file is missing, so I'm posting two of them here.  The qbert.txt file must be placed in the Maps folder under the Mala tree and be renamed to qbert.ugc.  The 4-Way, 45 Degree Angle.txt file must be placed in the Maps folder under the Ultramap tree and be renamed to 4-Way, 45 Degree Angle.um.
Enjoy and sorry.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
ARTIFACT
« Reply #151 on: August 25, 2007, 08:34:36 pm »
you rule fatfingers!!!
because of you my cab is going to rock
BTW could someone confirm whether or not this plugin is needed or if recent mame versions automatically do it? i just love how games feel right now and i dont want to uninstall it to test for myself ;)
ARTIFACT
« Reply #152 on: September 11, 2007, 11:56:28 am »
for some reason moving the joystick has no effect in qbert ... before i had d the new map files above, it would error but still work as a regular 8 ways stick
now with the correct map files ... no errors programming the stick any more BUT qbert does not move... :(
what is going on?
squirrellydw
« Reply #153 on: September 11, 2007, 02:13:30 pm »
works fine for me, did you put the files in the correct directory?
fatfingers
  • Got UltraStiks?™
« Reply #154 on: September 11, 2007, 05:52:38 pm »
what is going on?
Please post the mala and ultramapper debug log files.
Edit: Oh yeah, and make sure you don't have some funky settings in the mame interface for the qbert game.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
ARTIFACT
« Reply #155 on: September 11, 2007, 07:11:31 pm »
OK how do I delete thsoe settings and go back to defaults, in case that is the issue - I did go thru that once to try to fix it.
fatfingers
  • Got UltraStiks?™
« Reply #156 on: September 12, 2007, 09:50:15 am »
I believe you have to delete the qbert.cfg file.  But I'm not certain.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
ARTIFACT
« Reply #157 on: September 12, 2007, 05:26:03 pm »
i did that... no control in qbert at all... :(
fatfingers
  • Got UltraStiks?™
« Reply #158 on: September 12, 2007, 06:30:12 pm »
Time to post umapper.log then.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
ARTIFACT
« Reply #159 on: September 12, 2007, 06:40:03 pm »
ok, will do as soon as i get a chance - thanks!
