Author Topic: UltraStik Mapper plugin for MaLa Version 1.3.00 now released (1/30/09)  (Read 167574 times)
0 Members and 24 Guests are viewing this topic.
fatfingers
  • Last login:April 17, 2025, 05:26:08 pm
  • Got UltraStiks?™
Edit: cleaned up first post to be more realistic in today's world.
Hello.  In my first attempt at actually contributing to this fine forum instead of just take, take, taking, I have written a plugin for MaLa 1.0RC8 (and above).  This plugin keys on the game selection, game start, game end, and emulator selection events and will apply map files (.ugc files) to your UltraStiks before a game is started and after a game has exited.
Installation consists of the following steps:
This plugin calls UltraMap.exe which is supplied by and may be downloaded from Ultimarc's website.  The PATH environment variable no longer needs to be modified to include the path to UltraMap.
Good luck!
« Last Edit: January 30, 2009, 09:19:38 am by fatfingers »
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
W.W.P.M.D.?                                       I'm here to help ... I just don't do it. ™
edge
  • Last login:May 08, 2025, 09:08:47 am
  • AttractMode and GroovyArcade rock!
Re: UltraStik Mapper plugin for MaLa 1.0RC8
« Reply #1 on: October 20, 2006, 05:14:05 pm »
Nice job, fatfingers!
I should be getting my UltraStiks next week so I'll miss out on all the bug squashing. ;)
fatfingers
  • Got UltraStiks?™
« Reply #2 on: October 20, 2006, 05:59:18 pm »
haha!  You overestimate my availability!   ;D
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
Aurich
  • Last login:September 12, 2021, 01:34:32 am
« Reply #3 on: October 20, 2006, 06:19:51 pm »
Then, spend about 3.5 weeks generating all of your .ugc files
There must be a way to autogenerate this for most games, no? Maybe not for an oddball like Q-Bert, but most 4/8/analog.
fatfingers
  • Got UltraStiks?™
« Reply #4 on: October 20, 2006, 06:21:59 pm »
There is certainly a way and I'm working on it, but it may only work for mame v.106 since the xml format between that and .108 seems to have changed and I currently am using .106.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
edge
« Reply #5 on: October 20, 2006, 06:47:19 pm »
Fatfingers,
From the way I understamd the plugin technology works, there should be a record available to your plugin that contains info about the selected/launched game (see below).
See the below excerpt from the Mala Plugin SDK pdf.
I think, instead of having UGC files for every game, maybe you can create the standard configs - ie, 8way.ugc, 4way.ugc, etc - and based on what is in "InputControl: Pchar; : Control type (mame.xml)" - you can call the correct UGC.
I haven't tried it, but it seems possible.
What do you think?
type
TEventGame = record
Description: Pchar; : Name of the game
Rom: Pchar; : Rom file of the game
CloneOf: Pchar; : Master rom file if any
Manufacturer: Pchar; : Manufacturer of the game
Genre: Pchar; : Genre of the game (catver.ini)
Year: Integer; : Year
InputButtons: Integer; : Count of input buttons (mame.xml)
InputCoins: Integer; : Count of coins (mame.xml)
InputPlayers: PChar; : Count of players + alternating
VideoScreen: Pchar; : Screen type
VideoOrientation: Pchar; : Screen orientation
VideoWidth: Integer; : Width of screen
VideoHeight: Integer; : Height of screen
DriverStatus: Pchar; : Driver status
Controls: Pchar; : Control type (controls.ini)
JoyUp: Pchar; : Game function Joy Up (controls.ini)
JoyDown: Pchar; : Game function Joy Down (controls.ini)
JoyLeft: Pchar; : Game function Joy Left (controls.ini)
JoyRight: Pchar; : Game function Joy Right (controls.ini)
Button1: Pchar; : Game function Button 1 (controls.ini)
Button2: Pchar; : Game function Button 2 (controls.ini)
Button3: Pchar; : Game function Button 3 (controls.ini)
Button4: Pchar; : Game function Button 4 (controls.ini)
Button5: Pchar; : Game function Button 5 (controls.ini)
Button6: Pchar; : Game function Button 6 (controls.ini)
Button7: Pchar; : Game function Button 7 (controls.ini)
Button8: Pchar; : Game function Button 8 (controls.ini)
Details: Pchar; : Control details (controls.ini)
RomPath: Pchar; : Path of rom file
Extension: Pchar; : Extension of rom file
Played: Integer; : Play counter
end;
fatfingers
  • Got UltraStiks?™
« Reply #6 on: October 20, 2006, 07:09:06 pm »
I will most definitely look into that possibility, edge.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
loadman
    • MaLa
« Reply #7 on: October 20, 2006, 07:22:22 pm »
And when your finished you need to get to work on a Plug-in for a Serial LCD (reading mamewah type LCD files) for CIRCO and the Beta-brite LED Plug-in for Timoe    :P What do you want for X-mas?
The wife has said I've exceeded my PC allowance this month allready so I'm off to mow the law (And no that's not a Euphemism)  ;)
fatfingers
  • Got UltraStiks?™
« Reply #8 on: October 20, 2006, 08:58:14 pm »
If I had any idea what you are talking about, perhaps...but I don't.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
loadman
    • MaLa
« Reply #9 on: October 20, 2006, 10:22:15 pm »
Just kidding
fatfingers
  • Got UltraStiks?™
« Reply #10 on: October 20, 2006, 11:18:18 pm »
Yeah, I know.  :-)
How familiar are you with the plugins?  I'm having some difficulties getting my plugin to show up in loaded plugins right now even though the debug log claims it loaded it?  :banghead:
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
EnderWiggen22
  • Last login:March 23, 2010, 09:32:27 pm
« Reply #11 on: October 21, 2006, 12:08:00 am »
Sorry to throw in this newbish interjection, but what are plugins used for in mala and what exactly is this one attempting to accomplish?
Terrorism and Patriotism are only separated by success
fatfingers
  • Got UltraStiks?™
« Reply #12 on: October 21, 2006, 12:14:11 am »
Plugins in MaLa are new in version 1.0 RC8.  There are certain events that plugins can be called for (like game selection, game start, game end, etc.).  This particular plugin is used upon game start and game end to apply appropriate map files to Ultimarc Ultrastik joysticks so that the joysticks will operate in 4-way mode if it is a 4-way game, 8-way if an 8-way game, etc.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
fatfingers
  • Got UltraStiks?™
« Reply #13 on: October 21, 2006, 12:19:06 am »
Solved, I guess.  Since my machine is pretty pristine, I had to statically link the CRT into my plugin or the plugin wouldn't truly load.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
loadman
    • MaLa
« Reply #14 on: October 21, 2006, 12:35:50 am »
I have the code for the 'Delphi' version of the plugin and all I do is rename the built LEDWizControl.dll to LEDWizControl.mplugin and mala finds it when it is the plugin folder ok.  I don't know about C++
fatfingers
  • Got UltraStiks?™
« Reply #15 on: October 21, 2006, 01:00:30 am »
I do believe I have the next version working now.  Changes include:
  • No longer need maps for all games.  Instead, the InputControl field of the MaLa event is used to determine what map to apply to the sticks (thanks, edge!).  If no joysticks are in this field, then no maps are applied.
  • The plugin will first check to see if there is a specific map file for the rom name before using the InputControl field to determine the map name.  This allows for things like having one 4way.ugc file for all 4way games, but also for a qbert.ugc file that allows for qbert to have a slightly different map file than the standard 4way.ugc
  • Added ability to assign the MaLa map file at MaLa start time. (mala.ugc)
  • Added ability to assign a map at MaLa exit time. (malaexit.ugc)
I may still have to work out what the best way is to invoke the UltraMap program.  Currently you basically have to install it in your MaLa folder.   >:(
I'm a little sleepy right now so I will post more details/where to get the plugin tomorrow.
« Last Edit: October 21, 2006, 01:02:04 am by fatfingers »
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
loadman
    • MaLa
« Reply #16 on: October 21, 2006, 02:32:12 am »
Another bonus is Developers/users can develop plug-ins for hardware or other features without the MaLa main code being altered or SWINDUS necessarily being involved.
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
« Reply #17 on: October 21, 2006, 03:47:00 am »
Another way to solve this:
Check if a file for a rom exists and if not use a default file for this game like the mala.ugc file.
EDIT: forget it ...  ;)
« Last Edit: October 21, 2006, 03:51:58 am by swindus »
swindus
« Reply #18 on: October 21, 2006, 03:50:55 am »
Yeah, I know.  :-)
Enable the debug log in MaLa and watch the log. There are a lot of information about loading the plugins. To show your plugin properly in MaLa implement the PluginName and PluginCopyright function.
EDIT: Hmm, I should read the complete thread before posting ....
Good work fatfingers!  :applaud:
« Last Edit: October 21, 2006, 04:01:37 am by swindus »
fatfingers
  • Got UltraStiks?™
« Reply #19 on: October 21, 2006, 11:37:25 am »
This plugin is now working very well for me.  If there is anyone out there that would like to give it a try, I'd like to see how it works on someone else's machine before I send it out to the masses.  Please PM me if you're interested in giving this a go.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
Aurich
« Reply #20 on: October 21, 2006, 01:14:51 pm »
I haven't ordered my Ultrastiks yet, so I can't beta test or I'd offer to, but I just wanted to voice my appreciation for your efforts. :)
Your solution now sounds very reasonable, as you can leave the default Mala map as an 8-way and then only deal with the occasional oddball ROM that needs some settings tweaks or missing info added.
gamecreature
  • Last login:October 29, 2008, 08:35:37 pm
  • I'm making this up as I go along.
    • Gamecreature
« Reply #21 on: October 21, 2006, 01:39:39 pm »
Same here - I'm hoping to get some ultrastiks and then I'll be looking forward to adding this functionality to my cab!  ;D
Make your cabinet look its best with custom art from
Gamecreature!
fatfingers
  • Got UltraStiks?™
« Reply #22 on: October 21, 2006, 02:08:31 pm »
Thanks guys!  Let me know when you're ready!
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
kkingsto
  • Last login:January 13, 2021, 10:49:55 am
« Reply #23 on: October 26, 2006, 08:54:29 pm »
Just tried this.. Got an error saying the file was not a valid plugin???
loadman
    • MaLa
« Reply #24 on: October 26, 2006, 09:06:48 pm »
You have to pay SWINDUS
[DR EVIL VOICE]   One Million Dollars  [/DR EVIL VOICE]    :laugh2:
Sorry I am in a weird mood....  I can't help as its fatfingers code
fatfingers
  • Got UltraStiks?™
« Reply #25 on: October 27, 2006, 09:56:45 am »
Sorry about that.  If you read the whole post I ran into the same issue when I tried it at home.  The issue is one of C Runtime DLLs existing or not existing on your machine.  I have solved this issue in the latest plugin.  However, I have not posted that plugin yet as I have been waiting for beta testers before posting for general availability.  If you're willing to give beta testing a shot (this plugin works like magic on my machine), then please let me know.  The one caveat is that I cannot set you up until I get home and I will not be home until Sunday at the earliest.
Oh, one last thing, I have now removed the plugin attachment from the first post.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
Aurich
« Reply #26 on: October 27, 2006, 12:42:20 pm »
The cab my UltraStiks are going into is still bare MDF, don't wait on me, I'm not likely to be ready to test anything for another month or two at best. :)
fatfingers
  • Got UltraStiks?™
« Reply #27 on: October 27, 2006, 02:15:14 pm »
No problem.  Just waiting for anyone to volunteer.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
kkingsto
« Reply #28 on: October 27, 2006, 03:25:46 pm »
I'll volunteer.   I've got 2 ultrastiks.  I've already set one up and going to do the other one sometime this weekend.
fatfingers
  • Got UltraStiks?™
« Reply #29 on: October 27, 2006, 03:33:03 pm »
Great, I can hopefully send you the package Sunday night.  If not then, Monday.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
kkingsto
« Reply #30 on: October 29, 2006, 03:30:43 pm »
OK...
fatfingers
  • Got UltraStiks?™
« Reply #31 on: October 29, 2006, 07:17:28 pm »
OK...
PM sent with query on how to send the package to you.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
kkingsto
« Reply #32 on: October 29, 2006, 08:16:45 pm »
OK...
PM sent...
fatfingers
  • Got UltraStiks?™
« Reply #33 on: October 29, 2006, 09:37:01 pm »
OK...
PM sent...
Package sent
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
kkingsto
« Reply #34 on: November 03, 2006, 08:03:40 pm »
Been playing around with the plugin for a few days.   It works great!!!
loadman
    • MaLa
« Reply #35 on: November 03, 2006, 10:06:37 pm »
Good News  ;D
  • Last login:Yesterday at 07:32:51 pm
« Reply #36 on: November 05, 2006, 06:35:30 pm »
Wow - great thread!  I'm looking at a Ultimarc 360 right now and this would be a perfect solution!
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« Reply #37 on: December 16, 2006, 11:29:48 am »
Was this plugin ever released?  I would like to try it out but I didn't see where to download it.
fatfingers
  • Got UltraStiks?™
« Reply #38 on: December 16, 2006, 02:55:37 pm »
Funny you should ask today.  I just sent a message to swindus today so he can post the plugin for download.  When he has it posted, I will update this message with details.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
fatfingers
  • Got UltraStiks?™
« Reply #39 on: December 17, 2006, 05:54:08 pm »
I have it on good word loadman's word  ;D that Swindus is MIA.  So, I have attached the plugin and instructions to this message.  I hope that's not a misuse...when Swindus returns and posts the plugin I will remove these attachments.
The first one is a .txt file of installation/usage instructions.  The 2nd one is a .rar file that must be renamed (just remove the .txt from the end of it).
Let me know how things go!
Edit: That didn't work (renaming rar file) so I removed the attachments.
« Last Edit: December 17, 2006, 06:53:40 pm by fatfingers »
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
