Author Topic: Just installed a Betson Multisync and ArcadeVGA...  (Read 4804 times)
Banacek
  • Last login:November 08, 2017, 05:01:31 pm
« on: September 26, 2006, 12:35:05 am »
I installed the drivers, and then installed the Tri-Sync util. The monitor is getting an image fine, but the color is way off. What's the best way to correct the color? I'm sorry, but I've never owned a arcade monitor before so I'm kind of new to this :)
Thenasty
  • Last login:February 22, 2026, 07:36:08 pm
Re: Just installed a Betson Multisync and ArcadeVGA...
« Reply #1 on: September 26, 2006, 12:39:42 am »
maybe you just need to degause the monitor. Sometimes you get wrong colors cause the way how the monitor is setup (magnetic field). Hope thats all it is...
Free VGA Breakout Cable
Banacek
« Reply #2 on: September 26, 2006, 12:51:34 am »
Nah, that didn't change anything. Here's a pic (if it helps):
The color is off. Am I supposed to adjust anything initially, or is automatic? The monitor is new. Man I hope it's not the monitor...
Banacek
« Reply #3 on: September 26, 2006, 01:11:57 am »
Facing the monitor east has made a big difference, but I'm still not sure about the color. Compared to the pics in the Retroblast review, the colors just don't look right to me. Hmm...
Banacek
« Reply #4 on: September 26, 2006, 01:33:51 am »
For comparison:
My Monitor:
Normal Picture:
Apparently I have no green. Awesome.
StephenH
  • Last login:January 09, 2023, 06:15:45 am
« Reply #5 on: September 26, 2006, 03:39:24 am »
I would check the following:
1) Just for curiosity, I would check to see if you have a bad VGA cable by trying a different cable.
2) If you have the ability to swap connections somehow, swap the color pins, for example green with red.  This will tell you if the problem is in the monitor or what is sending it.
3) If Green is dead, I would recommend contacting Betson and see if they would exchange it for a working one.
grantspain
« Reply #6 on: September 26, 2006, 05:37:15 am »
thats a good bet on the vga cable,i had the same fault on an arcade piece which turned out to be exactly that
also the convergence is out-if its a digital chassis then there should be an adjustment for that on the osd advanced menu
Banacek
« Reply #7 on: September 26, 2006, 11:00:48 am »
Since I just bought it, I'm going to contact Betson to do an exchange. The VGA cable isn't swappable, so I can't try a new one. Thanks for the help, I guess I just lucked out with this one...
Banacek
« Reply #8 on: September 28, 2006, 06:19:19 pm »
For the record, got a new Betson 27'' today and it works great! Must of been a fluke with the other one...
wildfire123
  • Last login:November 28, 2006, 02:07:21 am
« Reply #9 on: September 28, 2006, 07:25:29 pm »
is your thing connect to a j-pac? think you can show a pic of your jamma connector? thanks
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #10 on: September 29, 2006, 07:12:51 am »
He has an ArcadeVGA....
Could you post some comparision pics of the same game running at different resolutions? I have not seen and ArcadeVGA working on these large Multi-sync (15Khz-SVGA) monitors before)..
Banacek
« Reply #11 on: September 29, 2006, 10:33:56 am »
Sure, as soon as I get the software all set up. If only I didn't have work and school...  :hissy:
Silver
    • Mods'n'Mods
« Reply #12 on: October 06, 2006, 04:37:13 pm »
Heh, I find there is never enough time for this kind of project. I just realised that I bought my IPAC over 3 years ago, and have still not built my cab. Argh.
Banacek
« Reply #13 on: October 08, 2006, 11:57:34 pm »
Hey, I tried using the MAME Resolution Tool this weekend so I could see it in action, but the tool seems to be picking resolutions that are way off. Once I get this figured out I will take pics, but I have midterms this week so it won't be til the weekend :(
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« Reply #14 on: October 09, 2006, 11:43:51 am »
Banacek
I have this monitor as well. Let us know if when playing games at 15khz you get the rolling over the hill affect. Especially noticeable on side scrolling platform games. I know I do :(
My old user name was marlborroman13, but I kicked the habit many years ago!
Silver
    • Mods'n'Mods
« Reply #15 on: October 09, 2006, 02:47:39 pm »
Hey, could you explain a bit more about "rolling over the hill"? I take it you don't mean vertical rolling...?
Banacek
« Reply #16 on: October 10, 2006, 11:50:29 pm »
Banacek
I'll have to check it out. How do I change to 15khz? I didn't see it in the Mame resolution tool.
Silver
    • Mods'n'Mods
« Reply #17 on: October 11, 2006, 06:23:11 am »
Most of the modes the ArcadeVGA supports are at 15Khz - once the drivers are installed anyway, I think (I don't have one).
They won't be listed as 15Khz, but resolutions such as 288x240 @ 60Hz are 15Khz resolutions. 640x480 @ 60Hz (The lowest typically supported by windows normally) is 31Khz - the lowest supported by most PC monitors.
Banacek
« Reply #18 on: October 11, 2006, 01:33:32 pm »
Ok thanks. I'll play with it this weekend...
AMDman13
« Reply #19 on: October 12, 2006, 12:02:58 pm »
The rolling over is best explained as the graphics get squished at the sides of the screen. You will notice it right away when playing games like Ghouls-N-Ghosts, Xmen, Shinobi basically any platform side scroller.
Silver
    • Mods'n'Mods
« Reply #20 on: October 12, 2006, 12:10:41 pm »
If the image is 'stable' ie the whole screen is not moving up or down or left and right, but lots of the image is compressed into the edges, I would suggest altering the monitor controls when in that mode.
Try reducing the width of the image.
Silver
    • Mods'n'Mods
« Reply #21 on: October 30, 2006, 04:46:22 pm »
*bump* - any chance of some pics?
squirrellydw
« Reply #22 on: November 29, 2006, 10:41:19 am »
I would also like to see some pics.  I plan on using the same setup.  How much did you pay for the monitor if you don't mind me asking?
I b**ch. People listen!!
