February 03, 2026, 11:20:56 pm
just noticed a bugwhen you pause a song just as it starts (within the first second), it cancels the song, and then plays the next song in the queue.i suppose this would normally not be an issue, but thought i would let you know anyway.
Quote from: dibb1er on August 26, 2006, 06:14:12 amjust noticed a bugwhen you pause a song just as it starts (within the first second), it cancels the song, and then plays the next song in the queue.i suppose this would normally not be an issue, but thought i would let you know anyway.Yes... the sound libraries I'm using return the song position to 0:00 when the song ends, so I check to see if a song is currently playing and if it isn't, I check the clock to see if it's 0:000 (ended) or something else (paused). Thus, if you pause a song before the counter leaves 0:00, it decides that the song has ended and moves on. I'm currently rebuilding the virtual disc changer; I'll try to fix this while I'm there.
