January 30, 2026, 12:58:09 pm
I'd like to use the 5V pins on the J-PAC to power the perfect 360 josticks. I'm paranoid about being sloppy and having the ground pin make contact with the 5V pin. Does radio shack have a harness that'll easily plug into the pins? Also, should I connect the ground to the common ground for the other buttons or the the ground pin beside the 5V pins?Thanks for your help.
