Author Topic: Perfect 360s  (Read 2101 times)
jets
  • Last login:February 25, 2005, 06:40:39 pm
  • all your base are belong to us
Perfect 360s
« on: March 04, 2003, 09:48:46 pm »
I would like to replace my Happ Super joysticks with Happ p360s. I have two questions to ask:
1) I need to know where to get the 5V to power each stick. I'm running a cabinet with a J-PAC. I have no clue where to begin with this.
2) Happ's website does not show the measurments of the stick. I'd like to know if the 4 holes for the bolts will line up with the existing holes my Supers use, I know that Competitions will.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Perfect 360s
« Reply #1 on: March 04, 2003, 10:31:32 pm »
1) There are many past posts about the p360, look them up.  You can get 5v from alot of places on a computer, like the USB port.
2)  Yep, jamma standards:)
jets
Re:Perfect 360s
« Reply #2 on: March 05, 2003, 12:44:50 am »
I'd like to use the 5V pins on the J-PAC to power the perfect 360 josticks. I'm paranoid about being sloppy and having the ground pin make contact with the 5V pin. Does radio shack have a harness that'll easily plug into the pins? Also, should I connect the ground to the common ground for the other buttons or the the ground pin beside the 5V pins?
Thanks for your help.
DeathMonk
  • Last login:April 03, 2015, 02:01:12 pm
    • MameStation.3
Re:Perfect 360s
« Reply #3 on: March 05, 2003, 10:03:53 am »
You can do what I did:
Take one of the LED leads from the computer case, and use that to plug into the PAC..
Or..
Get a USB Cable and use the 5v from there.
Now with cup beer holders!
Minwah
    • MAMEWAH
Re:Perfect 360s
« Reply #4 on: March 05, 2003, 12:11:11 pm »
Or grab 5v from a spare disk-drive power cable (red for +5v, black for gnd).
...or you can even get 5v from a ps/2 (mouse/keyboard) port if you have one spare.
(search for usb / ps2 pinouts on google for the connections)
SirPoonga
  • Puck'em Up
Re:Perfect 360s
« Reply #5 on: March 05, 2003, 12:28:51 pm »
I don;t have 360s, BUT you aren't going to have a large glob of solder.  Then you could use heat shrink tube to cover the pins afterwords.
