Author Topic: Found Space Invaders Cab - Need Advice  (Read 7791 times)
jsw2068
  • Last login:April 16, 2009, 01:06:07 am
« on: May 14, 2006, 07:45:28 pm »
I found a Space Invaders Cabinet at a local thrift store for $275. I talked them down to $200. I plugged the unit in and the PCB seems to work fine. The monitor however seems to be shot. It has a brightness problem and vertical lines every half inch or so.  Without being able to work on it and adjust it I don't know how easy of a fix it is.
My questions:
1. Is it a fair price for $200?
2. What version cabinet is it. The pictures below are from my camera phone which sucks. I think it's a 1978 cabinet, but not sure
3. What would the costs be to fix? Monitor(if needed), Bezel, control panel needs replacement.
Also the thing had no sound when I fired it up.
I want to get this for restoration because I think someone else might destroy/hack the cab into something else.
The cabinet itself is in great shape just some normal wear and tear/ scraps and scuffs but nothing damaged greatly.
Let me know what you think.
-Jay
Fozzy The Bear
  • Handbags at dawn in here!!!
Re: Found Space Invaders Cab - Need Advice
« Reply #1 on: May 14, 2006, 08:39:20 pm »
$200 !!!!!!!  What the hell are you waiting for!!!! Grab it NOW!!!
Best Regards,
Julian (Fozzy The Bear)
Hiub1
  • Last login:June 05, 2011, 11:43:25 am
  • www.sleepyjack.com
« Reply #2 on: May 14, 2006, 11:28:03 pm »
Are you Fing kidding me? Sounds like a cap kit could fix the monitor problem, and anything else you could take your time to replace! That is an AWESOME deal my friend, go  for it!
deadkenndys1105
  • Last login:November 27, 2012, 03:55:05 pm
« Reply #3 on: May 14, 2006, 11:33:34 pm »
Grab that thing now.  The only sound in space invaders is when the space ship go acrost the screen so you need to play for a little.  I could be wrong tho its been a long time.
17 years old and totaly addicted.
Luigi
  • Collecting/restoring cabs
« Reply #4 on: May 15, 2006, 04:07:49 am »
Hi.
Grab it!!!
The brightness problem together with the vertical lines.....maybe it is ok, when you turn the SCREEN (a little poti directly at the ....oh ---steaming pile of meadow muffin---.....what is "Zeilentrafo" in english?? DST? The thick wire goes from there to the rubber thing on the tube.
ok - there are two pots , one for FOCUS the other one for SCREEN. If you turn SCREEN to high on a normal functioning cab, you get a bright picture with horizontal/vertical lines (depending on the directions of the monitor). Turn the SCREEN back a little and maybe tha picture is ok then.
EDIT: I just saw in the manual that the FOCUS pot is separated. So you must search the (damn) with the SCREEN-pot. I will post a picture as soon as I get one.
DO THIS after you bought the cab. If you correct the picture at the  shop, the price might rise  ;)
Sound : There are 8 (eight!!) different volume controls for the different game sounds. Maybe you need to adjust them there.
Get the manual here : http://www.crazykong.com/manuals/SpaceInvaders.man.pdf
Let us know about your decision. If you don't want it, I'll take it for 200$ incl. shipping to Germany  ;D
Thorsten
« Last Edit: May 15, 2006, 04:55:26 am by Luigi »
aumameman
  • Last login:November 18, 2009, 09:50:07 pm
  • AUSSIE MAMER !!
    • Arcade joystick - First attempt
« Reply #5 on: May 15, 2006, 04:40:20 am »
$200! go for it man, make sure to post photos after the restore.
-- The Internet has you --
Fozzy The Bear
« Reply #6 on: May 15, 2006, 08:04:06 am »
 :lame: You are wrong....  space invaders also has the continually speeding up thump thump thump noise, the sound of your missile base being fired and the sound of hits on aliens, as well as the sound of your laser base being blown up..... Where were your ears when you were playing it!!!
Best Regards,
Thenasty
  • Last login:Today at 12:51:27 pm
« Reply #7 on: May 15, 2006, 08:26:33 am »
where in chigago is this store located ? Better hurry up before I drive from NJ to get it for $200  ;D
Free VGA Breakout Cable
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #8 on: May 15, 2006, 08:43:55 am »
I betcha he tried it out in Mame...and he doesn't have samples, or doesn't have them enabled.
Thenasty
« Reply #9 on: May 15, 2006, 09:00:26 am »
Thats the only thing you hear when you get abducted by the alien space ship.  :o
Fozzy The Bear
« Reply #10 on: May 15, 2006, 09:07:01 am »
Very Probably......
Again!! JSW... GRAB IT NOW! Before somebody else beats you to it! that cab looks to be in excellent condition for an orginal machine.
Best Regards,
Luigi
« Reply #11 on: May 15, 2006, 09:20:15 am »
I don't have a picture of the Space Invaders Cab or the monitor chassis.
The SCREEN pot should be located at the thing in the red rectangled part.
jsw2068
« Reply #12 on: May 15, 2006, 11:04:55 am »
Thanks for all the advice.
I will grab it tonight. They are holding it for two days for me.
I checked eBay and it seems to vary on the price of the machine.
I picked up a Time Pilot that I'm still in the process of restoring so this one will have too wait a few months. But I'll check the monitor and sound out right away. So I can play it.  :)
Any idea where to get a replacement bezel?
I found a vinyl overlay for the control panel on ebay.
Alow any idea what colors are used on the cabinet? If I want to touch up or repaint the scuffs on the cabinet I'll need to color match them.
-Jay
Level42
« Reply #13 on: May 15, 2006, 11:31:56 am »
I'd buy it right away if I could get a classic like that for that price !
On the sound, indeed how can anyone forget the sound of Space Invaders ? That thick thud-bass sound with each step to the side.....that was one of it's major charms in the day.....
But this guy may never have seen a real cab of couse :)
ahofle
    • Arcade Ambience Project
« Reply #14 on: May 15, 2006, 12:32:50 pm »
LMAO  :laugh2:
MameMaster!
  • Engage number one!
    • Mame Invaders!
« Reply #15 on: May 15, 2006, 12:34:04 pm »
...seriously....for $200. that's a no brainer purchase for that sort of arcade history.
There is so much repro stuff out there you can make that minty for under $500. total.....(maybe even less).
jsw2068
« Reply #16 on: May 15, 2006, 12:47:02 pm »
I just saw one end on eBay for $187 that was in Indiana.
I think I will grab this cab and refurb it. I would I don't have to put too much money into it.
-Jay
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #17 on: May 15, 2006, 12:56:52 pm »
You may want to shop around for a METAL control panel repro, not vinyl.
NO MORE!!
jsw2068
« Reply #18 on: May 15, 2006, 03:08:51 pm »
Does the vinyl look that bad?
I thought  I could ovrlay it on the current panel for now and wait for one to surface
-Jay
shardian
« Reply #19 on: May 15, 2006, 04:49:37 pm »
OMG! I just realized that my church has had one of these collecting dust upstairs for years. If I remember correctly, the cabinet was in great shape, the monitor was operable, but needed tweaked, and the coin door was missing. I didn't know anything about arcade games while I was up there looking at this thing, but now I believe it is time to make a "donation" to the church to "unburden" them of this machine.  ;D ;D ;D
subcriminal
  • Last login:November 20, 2019, 12:58:00 pm
« Reply #20 on: May 15, 2006, 05:57:52 pm »
Sound's like a bargain cab and the screen problem could just be the brightness turned up too high on the LOPT. Mine gets green flyback lines when too high.
WTF's with these new emotes? Looks like a kiddie took over the place. It sucks to see people flaming posts with a stupid green blob saying LAME :(
Fozzy The Bear
« Reply #21 on: May 15, 2006, 07:36:37 pm »
  :troll:  :soapbox: :tool:   :laugh2: :laugh2: :laugh2:
Best Regards,
deadkenndys1105
« Reply #22 on: May 15, 2006, 09:28:54 pm »
Very Probably......
Best Regards,
Like I said its been a long time.  I figured it did but it wasnt im mame.  I played it when I was 5.  I had a gut feeling I was wrong to.
babydickonboard
  • Last login:May 22, 2008, 08:28:56 pm
  • {/....KILL YOUR TELIVISION....\}
« Reply #23 on: May 17, 2006, 07:07:38 pm »
i got my space invaders cab ( which I still haven't restored ) from out of the back of a truck going to the dump! stoked i landed that cab for free.  :)
shardian
« Reply #24 on: May 18, 2006, 10:27:59 am »
I went to get that space invaders from the church I mentioned last night. They would have given it to me, except for the fact it was DUMPSTERED two weeks ago!!! That frikkin thing has set there for almost 2 decades, and they finally decide to get rid of it within 2 weeks of someone actually wanting it. Coincidence, or a sign I didn't need it. Either way, my wife sure smiled big when I found out it was gone.  :'(
Glaine
  • Last login:April 24, 2013, 12:09:17 pm
« Reply #25 on: May 18, 2006, 02:25:12 pm »
We're like bloody historians of our trade, and our families HATE the stuff.
RayB
  • There's my post
    • RayB.com
« Reply #26 on: May 18, 2006, 07:37:07 pm »
What a ---smurfette---!!
NO MORE!!
Thenasty
« Reply #27 on: May 18, 2006, 07:53:55 pm »
What a ---smurf---!!
you mean ----Smurfett---- is that how you spell it  ;D
jsw2068
« Reply #28 on: May 21, 2006, 04:18:46 pm »
I got the cab home this weekend and the sound does work during game play. Is there no sound in attract mode?
The lines in the monitor are gone with the pot adjustments. The screen is still really bright. and suggestions on correcting this?
-Jay
Stingray
« Reply #29 on: May 24, 2006, 12:47:57 pm »
Mine's a cocktail, but there's a brghtness pot on the back of the monitor. Very nice find for $200.
-S
Glaine
« Reply #30 on: May 24, 2006, 11:18:40 pm »
I am glad for your good haul. Ironic how the machine itself will be invading the wife's space very soon.
danny_galaga
  • Last login:Today at 07:05:15 am
    • dans cocktail lounge
« Reply #31 on: May 27, 2006, 12:53:08 am »
good one! you wont be sorry. and yes, no sound in attraft mode...
