Author Topic: Mounting: Replacement Joystick for MS Pac-Man/ GALAGA  (Read 2473 times)
rbarr110
  • Last login:Yesterday at 12:10:10 pm
  • I already built my own arcade controls!
« on: March 31, 2006, 12:05:05 pm »
I just got me a dedicated 4-way, but have mounting questions.
http://www.happcontrols.com/joysticks/5060841125r.htm
If I am going up through 3/4" of CP material only the ball and maybe 1/4" of shaft is above the top of the CP.  This seems too litlle.  Should I recess the CP for the joystick?
Anyone have pictures they can share to show how they mounted theirs?
quarterback
Re: Mounting: Replacement Joystick for MS Pac-Man/ GALAGA
« Reply #1 on: March 31, 2006, 12:17:52 pm »
Yeah, these are really made for metal CPs.  There are longer-joystick-shafts available.   A guy named tornadoterry sells them.   He's an ebayer from Tejas.  I can never remember his exact ebay name, but I'll see if i can find it for you.
-- Chad Tower
Zeosstud
  • Last login:January 20, 2026, 05:52:04 pm
« Reply #2 on: March 31, 2006, 12:19:48 pm »
That particular joystick specifically states its for metal control panels only but your on the right track for your own use.  Either route out a place for the mounting plate OR get a replacement joystick.  I know I have seen/read that they are available.  I hear its a great joystick, you will like it once your happy with how it mounts.
Rodney
quarterback
« Reply #3 on: March 31, 2006, 12:23:02 pm »
tornadoterrysdot is his ebay user name.  Here're his auctions: http://search.ebay.com/_W0QQsassZtornadoterrysdotQQhtZ-1
-- Chad Tower
eschmunk
  • Last login:May 03, 2017, 05:03:33 pm
« Reply #4 on: March 31, 2006, 01:40:21 pm »
I have the ms pacman/galaga 4 way.  I mounted it by recessing the cp from the top.  I cut a hold to fit the base and routed the top.  After you lock it down then I put the switches back on.  Works great.
AtomSmasher
    • Atomic-Train
« Reply #5 on: April 01, 2006, 11:28:57 am »
Thats what I did too, works great.
RobotronNut
  • Last login:December 22, 2018, 11:39:19 am
« Reply #6 on: April 03, 2006, 12:37:16 am »
for the ms-pac / galaga reunion:
if you want to bottom-mount it without routing, you can use the link in my signature to obtain a tornadoterry shaft and mcmaster-carr ball knob or a betson joystick. i'm using both, and they're both working well for me.
to see my "Frankenpanel" and design notes, click here.
quarterback
« Reply #7 on: April 03, 2006, 01:58:00 am »
I replaced my Ms. Pac reunion shaft with a longer Wico red balltop.  A while back I removed it from my CP and I'm selling it in B/S/T if you're interested.
LINK
-- Chad Tower
RickDIII
  • Last login:June 03, 2007, 10:18:28 pm
  • Finished 1st Cab!
« Reply #8 on: April 03, 2006, 02:00:28 pm »
I just did this over the weekend.  Did a write up on it today.  Would have put it in here if I was paying attention.   :dizzy:
http://forum.arcadecontrols.com/index.php?topic=52286.0
