Author Topic: Dual Monitor Sitdown  (Read 3631 times)
Birdtales
  • Last login:October 06, 2020, 10:00:31 am
  • You won't like me when I'm angry.
    • Birdtales
« on: February 09, 2003, 03:48:16 pm »
I've read back through the archives and all of the threads on the new board. There was a discussion back in November about dual monitors but the person wanted to split the Mame screen.
 I just want to know if Mame will display a copy on two displays. I picked up a dual monitor sitdown (Road Rage 4WD) this weekend at auction. I'd like to Mame it but want to know if the displays will work before I spend the money on dual cards.
 I plan to ask Andy too if his card was ever tested with dual cards and monitors. That is again IF Mame will display on two of them. Any comments will be welcome.
Coming Soon
tom61
  • Last login:September 18, 2017, 12:46:56 am
Re:Dual Monitor Sitdown
« Reply #1 on: February 09, 2003, 04:20:28 pm »
You'll need a single card with dual outputs. In Windows, most cards have an option to 'mirror' or 'clone' the main display.
If you're going to use dual arcade monitors, the only option I know about is Andy's card under DOS. Under DOS the second display port outputs the same signal as the primary port. In windows though, it outputs VGA compatable signals.
Thenasty
  • Last login:Yesterday at 10:04:40 pm
« Reply #2 on: February 09, 2003, 11:04:59 pm »
If what he is asking about is "Can I display the game in dual monitor" such as Punchout, Playchoice 10,  Darius (side by side monitor) then the answer would No. MAME don't support dual output meaning display Puchout specs on one, and play the game on the other.
Free VGA Breakout Cable
eightbit
  • Last login:September 07, 2019, 07:38:11 pm
  • My cab is never done...
« Reply #3 on: February 10, 2003, 08:32:19 am »
You can get monitor splitters. This will display the same screen to more than one monitor. I have one that will do up to 4.  This will work with any video card or OS.
You can get a dual headed card or run 2 compatible video cards and usually they can be configured to show the same image on both screens. This will probably require Windows and will work with Mame.
My statements are my own opinions. They have the value that the reader gives them. My opinion of my opinion varies between foolish and brilliant and these opinions often change with new information.
Birdtales
    • Birdtales
« Reply #4 on: February 10, 2003, 09:47:11 am »
But would a monitor splitter work on arcade monitors? I'm gonna do this thing so I'll report back what I found the to be the best way to do it.  I only gave 115.00 for the game so I won't be out too much if I can't make it work. Right now the game is working perfect on one side. The other side needs a cap kit and some work on the steering controller.
 I'm thinking Andy's Arcade VGA and DOS may be my best bet but I would like to run in Windows if I can.
« Last Edit: February 10, 2003, 09:48:41 am by Birdtales »
Coming Soon
eightbit
« Reply #5 on: February 10, 2003, 01:32:46 pm »
With Andys card you should run Windows just fine.
I missed the part about you mentioning 2 arcade monitors. Assuming that you want the same picture on both, can't the cable simply be split? I have no first hand experience with arcade monitors.
tom61
« Reply #6 on: February 12, 2003, 06:02:09 pm »
Hmm... I think a simple 'Y' monitor splitter would work, though you might need video amps on both monitors.
BombProofPlane
  • Last login:February 11, 2009, 04:14:14 pm
« Reply #7 on: February 26, 2003, 12:23:10 am »
well if your using jpacs that already has amps
so what are you gonna be doing a versus style cab or what?
put 2 pcs in and play racing games?
put 2 ps2s in and play gt3?
Birdtales
    • Birdtales
« Reply #8 on: February 26, 2003, 01:50:06 pm »
No it's a Road Riot 4WD. I just want one set of controls in front of each monitor.
Coming Soon
Anonymously
  • Last login:May 26, 2005, 02:13:11 am
  • MarMags Arcade
« Reply #9 on: February 26, 2003, 03:12:33 pm »
hmmn even the spliter works, how can you display 1 player on one side and 2 player on the other side?  If you mirror the image it will only mirror the one players view. :-\
No Offense, it's just a suggestion
Birdtales
    • Birdtales
« Reply #10 on: February 26, 2003, 03:18:03 pm »
I only wanted the same image on both monitors. Mame doesn't support two different views as in a VS cabinet.
Coming Soon
BombProofPlane
« Reply #11 on: February 26, 2003, 05:28:33 pm »
well thats what i meant
a vs cabinet is the same image mirrored on both monitors
http://www.arcade-infinity.com/galdcjc16b.htm
Birdtales
    • Birdtales
« Reply #12 on: February 26, 2003, 05:48:11 pm »
Coming Soon
