Author Topic: K7200 Issues  (Read 1099 times)
CPickler
  • Last login:August 20, 2006, 02:37:14 am
    • CPU Studios
K7200 Issues
« on: January 10, 2006, 04:47:49 pm »
I just upgraded the standard 1988 Well's Gardner monitor that came with the Double Dragon 2 cabinet.  I put in a new K7200 and powered it up and the image is moving very quickly up and to the right.  I have adjusted all the controls I can see and they are not making much of a difference in the extreme rolling.  I used the same connector I wired up to use on the old monitor.  Do I need to rewire my connector for the new monitor?  I will attach pictures and more details in about an hour.
Thenasty
  • Trade Count: (+17)
  • Last login:February 03, 2026, 08:27:56 pm
Re: K7200 Issues
« Reply #1 on: January 10, 2006, 10:34:48 pm »
I have wg7202 monitor and I also had an old WG 46xx something. I don't remember exactly what happened when I connected the NEW one thinking it would just be a swap and it goes, I was wrong. I found out after lots of fidling that the NEW one's V-Sync/H-Sync must be separated. In my older setup, this wires was twisted to get composite connection and I'm assuming that this would be your case.
Free VGA Breakout Cable
CPickler
    • CPU Studios
Re: K7200 Issues
« Reply #2 on: January 15, 2006, 05:33:29 pm »
thanks.
Where can I get the new molex (or plastic) connector for connecting to the monitor and connecting the wires into the connector?
Q*Bert_OP
  • Oh yes, we did!
Re: K7200 Issues
« Reply #3 on: January 16, 2006, 05:06:23 pm »
Bob Roberts
