Author Topic: VGA Break out to K7400 monitor  (Read 1958 times)
killbill
  • Last login:December 17, 2025, 04:32:58 pm
  • When I die, I want to go to arcade heaven!
« on: December 11, 2005, 10:24:54 pm »
Hi,
I just purchased a Wells Gardner K7400 monitor off of a guy.
« Last Edit: December 11, 2005, 10:26:43 pm by killbill »
Thenasty
  • Last login:Yesterday at 10:27:24 am
Re: VGA Break out to K7400 monitor
« Reply #1 on: December 12, 2005, 07:50:38 pm »
some monitor needs the H/V separated, if this 2 wires are connected, you get COMPOSITE out. I dunno if K7400 needs to be separated but , my WG k7201 needs to separated, composite did not work for me.
Free VGA Breakout Cable
killbill
« Reply #2 on: December 13, 2005, 01:39:18 am »
Hey Nasty,
Thanks for the response.
« Last Edit: December 13, 2005, 01:45:33 am by killbill »
Thenasty
« Reply #3 on: December 13, 2005, 08:45:56 am »
I could not control the output of the monitor. I had to split the connection and it became stable. Its been like this since w/no problems.
Here is a rough diag.....
If you need composite, just take V/H together (vga brkout cable, pin 13,14) and just twist it w/the Vsync on the Arcade PCB or the H/Sync (either one).
killbill
« Reply #4 on: December 14, 2005, 11:35:26 pm »
Hey Nasty,
Do you have of those $6 labelled VGA breakout cable left?
Please let me know.
