Author Topic: Why my PAC-MAN credits up to 99 ???  (Read 4879 times)
BUCKETHEAD
  • Last login:April 04, 2024, 07:31:52 pm
  • Don't hate the player .... Hate the Game
« on: September 30, 2005, 08:00:01 pm »
My PAC-MAN cabinet recently started giving me 99 credits with one Quarter.
And it is not set on FREE PLAY.
The real annoying thing about this is.  It credits one number at a time
until it reaches 99.
It has all the original wiring in it.
Any guess what my problem may be?
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Why my PAC-MAN credits up to 99 ???
« Reply #1 on: September 30, 2005, 08:09:11 pm »
Ghosts.
Sell it on Ebay. You'll make a killing.
Don't forget to write a 2-pager explaining how your grandpa used to play the machine and then he died in the same room.
NO MORE!!
Q*Bert_OP
  • Oh yes, we did!
« Reply #2 on: September 30, 2005, 08:16:04 pm »
Wires crossing? Bad coin switch?
brophog
  • Last login:January 20, 2019, 03:49:41 am
« Reply #3 on: September 30, 2005, 08:17:05 pm »
That's my guess is a faulty coin mechanism.
BUCKETHEAD
« Reply #4 on: September 30, 2005, 08:41:19 pm »
Both coin switches on each side have the same effect ( 1 - 99 )
But i can press the RED credit button, On the inside right of the coin door
and it will add one credits like normal.
This is what confuses me
« Last Edit: September 30, 2005, 08:46:16 pm by BUCKETHEAD »
DarkKobold
  • Last login:June 18, 2013, 11:31:23 pm
« Reply #5 on: September 30, 2005, 10:07:47 pm »
Is it clicking on the coin counter as well? It might be a TTL chip stuck at high, or something, since the test credit is a seperate input, I believe.
My games: Tapper, Asteroids, Cocktail-MAME, Tron, ROTJ, Tempest, Star Wars (not working)
My wants: Warlords Cocktail
tbombaci
  • Last login:October 31, 2024, 01:32:56 pm
« Reply #6 on: September 30, 2005, 10:21:06 pm »
From Usenet:
>>If I had to guess given your symptoms I'd say 8E should be replaced.
>>This chip inputs both the Rack Advance and the Coin 1 lines.
>>Given that you said the inputs are high I believe that the RM8 resistor
>>network is probably good.
>>Kev
The whole post:
http://tinyurl.com/bovtf
-Tom
BUCKETHEAD
« Reply #7 on: September 30, 2005, 11:41:46 pm »
I will check the COIN COUNTER tomorrow.
What exactly is a  TTL chip ??
If it does happen to be
Thenasty
  • Last login:Today at 02:47:10 pm
« Reply #8 on: October 01, 2005, 04:07:07 pm »
if you think the COIn COUNTER is shorted, just disconnect it and try again. This will illimate your Coin Counter issue and you can now check the COIn SWITCHES. The best thing really to do is just disconnect the wires from the COIN SWITCH and test it that way without using the coin switch or counter. Just simply rub the 2 wires together and see if still gives you 99 credits. Hope that made sense. If it still gives you 99 credits, then its somehwere in your PCB (TTL Chips).
« Last Edit: October 01, 2005, 04:08:55 pm by Thenasty »
Free VGA Breakout Cable
BUCKETHEAD
« Reply #9 on: October 02, 2005, 08:47:43 pm »
Disconnected the Coin Counter today.
Same result  99  Credits   >:(
Even replaced it with another newer Coin Counter i had lying around.
It didn't even work.
Didn't try the rubbing of the two wires together.
I will try that this week sometime.
I did disconnect the wires from the chip on the right side of the cabinet.
The side opposite of the PCB.
I believe that chip is a COIN advance pcb?
Maybe im wrong?
But it will not coin up at all with that unplugged.
But still will from the RED credit button.
quarterback
« Reply #10 on: October 05, 2005, 12:03:50 pm »
Are the coin switches hooked up as NO or NC?
-- Chad Tower
BUCKETHEAD
« Reply #11 on: October 05, 2005, 04:06:22 pm »
NO  or  NC ?
Sorry my friend!
You have lost me there!
I haven't been in this long.
What exactly does that mean?
And i can answer your question.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #12 on: October 05, 2005, 04:10:27 pm »
Normally Open, Normally Closed.  The lugs on the microswitched are labelled that.
BUCKETHEAD
« Reply #13 on: October 05, 2005, 07:45:56 pm »
Gee,  I keep on learning all kinds of
useful info here!  :)
I will check tomorrow.
It is out in my garage.
And im in for the night.
BUCKET ...
quarterback
« Reply #14 on: October 08, 2005, 12:35:14 am »
If a switch is "NO" (normally open) then it will only "close" when a button is pressed (or, in this case, when a coin goes through)
If a switch is "NC" (normally closed) then it will "open" when a button is pressed.
You want your switches to be hooked up as "Normally Open", so they're only activated when a coin goes through.   If they're hooked up "NC" then they're constantly 'telling' your PCB/computer/whatever that a connection has been made, as if a coin were falling through an "NO" switch.
It seems like this could be the source of your problems.
Some coin mech wiring pictures are on this page for more info: http://www.retroblast.com/articles/token-convert2.html
-- Chad Tower
BUCKETHEAD
« Reply #15 on: October 11, 2005, 08:41:01 pm »
Thanks for all the help,
In trying to help me solve this problem.
I could never find out the cause,  It has OLD SCHOOL coin switches in it.
Which made it hard to figure out the NO / NC
So i finally had enough   >:(  And wired the Coin switches to the CREDIT BUTTON
on the inside of the Coin Door.
That made everything work PERFECT!   :)
Just the way i liked it.  Before it screwed up!
One day i wanna yank out the Original wiring harness
and replace it with a JAMMA harness and a JAMMA to PAC adaptor.
Again thanks for all the help!
Thenasty
« Reply #16 on: October 12, 2005, 05:42:22 pm »
BUCKETHEAD
« Reply #17 on: October 12, 2005, 08:03:03 pm »
Nope the COIN SWITCHES are working fine!
I get 1 CREDIT for 1 QUARTER.
I was getting  99 CREDITS for 1 QUARTER.
I wired the COIN SWITCHES to the CREDIT BUTTON wire.
Now, there could have been a short or a break somewhere in the
Coin Switch wires before i cut them from the switches.
I really didn't want to trace the break or short all the way through the cabinet.
And so i thought of this easy fix, For my problem.
But like i said,  This is the way i like it to Coin up.
So i'm gonna leave it this way.
Until i Jamma it one day.
I really to appreciate everyone's input on this problem.   :)
