Author Topic: AdvanceMenu - how to reconfigure keys??  (Read 2355 times)
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
« on: June 19, 2005, 03:38:36 pm »
advancemenu seems to do everything i want.  the only thing i'm stuck on is reconfiguring keys.
when it's in my cab i'll be using a jpac.  will i need to reconfigure the jpac so i can emulate an ENTER key (to run games) or can you reconfigure advancemenu to accept say Player 1 Start as the key to run games.
thanks for any input
Fat_Trucker
  • Last login:September 08, 2010, 11:44:22 am
Re: AdvanceMenu - how to reconfigure keys??
« Reply #1 on: June 19, 2005, 05:33:14 pm »
Should work from the off. The J-Pac usually treats P1 start as a shift key so if you hold it down you can combine it with the joystick and other buttons for all the other mame functionality (P1 + Joyleft = Tab, P1 + Fire1 = Coin 1 etc).
I'm pretty sure that most arcade oriented front ends will let you use P1 Start as your game launch button without any reconfiguring.
I didn't touch it....honest!
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 09:58:56 pm
« Reply #2 on: June 20, 2005, 10:10:55 am »
if you don't want to re-program the Jpac/Ipac, then just look in the ADmenu.rc file.
Example for the ENTER that you wnat to change look for:
event_assign enter
and enter what you want, lets say you want the letter R for ENTER
event_assign enter R
simple.
Free VGA Breakout Cable
