Author Topic: MAME Crashing and I-Pac Problem  (Read 1451 times)
BWK900
  • Last login:July 24, 2005, 07:18:11 pm
  • Megaman
« on: May 28, 2005, 04:41:14 pm »
I have an Ipac4 and it is set with the default mame settings.  I changed a few things in mame so I can match it exactly with the Ipac.  It worked extremely well for a while even when I had four people playing.
But yesterday, my friends and I were playing a game that required it to hit all the buttons.  Then, Mame just kept crashing to the desktop.
When I try to reprogram the IPac,  all it says is device not found, but I can still play with it perfectly.
Could anyone diagnose my real problem and tell me how to fix it?
Thenasty
  • Last login:Yesterday at 11:35:24 am
Re: MAME Crashing and I-Pac Problem
« Reply #1 on: May 28, 2005, 04:49:52 pm »
I bet its got something do to with  CTRL, ALT, and that button in between. MAME default uses CTRL and ALT so maybe you need to use a more secure KEYBOARD keys to use. Just my 2c.
Free VGA Breakout Cable
BWK900
  • Megaman
« Reply #2 on: May 28, 2005, 04:54:54 pm »
yeah, i think thats my problem, but I'm not able to reprogram my IPAC.  It always says "device not found."
AlanS17
    • AlanS17
« Reply #3 on: May 28, 2005, 06:00:32 pm »
This is probably stupid to bring up as you're proba bly already checked, but have you tried the following page?
http://www.ultimarc.com/ipac3.html
It's how to program the ipac from the official site.
AlanS17
    • AlanS17
« Reply #4 on: May 28, 2005, 06:02:07 pm »
The WinIPAC utility has been hit-or-miss for me. Try the interactive method mentioned on the link above.
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
« Reply #5 on: May 28, 2005, 06:19:58 pm »
The Ctrl+Alt+P Method is the best.  I only use winIPAC for the on-the-go flashing in MAMEWAH.  Otherwise, the interactive method that AlanS mentioned is the best way to go.
BWK900
  • Megaman
« Reply #6 on: May 28, 2005, 06:52:54 pm »
thanks, i'll try that when i pull my CP out later.
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: May 31, 2005, 07:14:33 am »
My Guess is ALT-ENTER, this is P3B3 and P1B2.  In MAME, it is also used to swap between full-screen and windowed mode.
Start MAME, go to the Tab Menu - Input (General) - User Interface - and look for the Toggle Fullscreen input.  Set this to Numpad 5 or some other unlikely to be used key.
