Author Topic: HELP needed with pre-stripped and labelled VGA breakout cable from Ultimarc  (Read 1360 times)
Wyluli
  • Last login:February 11, 2013, 06:38:03 pm
  • Stupid Stupid Rat Creatures!
I purchased the pre-stripped and labelled VGA breakout cable from ultimarc to hook up my computer (with arcade VGA card) to my cabinet (which has a 25" Hantarax arcade monitor).
To make a long story short, I found out from Ultimarc that the cable may be mis-labled.
Does anyone here have one of these cables and if so, can you please give me the pin-out by color?
R, G, B = colours
H Sync =
V Sync =
Ground =
(Hopefully this will work, example: R = black wire, B = red wire, G = purple wire, and so forth.)
Thank You.
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 01:25:44 pm
if you a multimeter you can easisly check which is which.
pins:
1 = Red
2 = Green
3 = Blue
5,6,7,8,10 = GROUND
13 = H/Sync
14 = V/Sync
to make composite twist 13/14.
Free VGA Breakout Cable
