Author Topic: Problems with mamewah and advancemame  (Read 1710 times)
GMZombie
  • Last login:March 22, 2022, 10:11:23 am
  • I am a living Legend who fixes stuff... mostly
« on: May 05, 2005, 04:01:37 am »
ok heres the problem...first off i sometimes have problems getting a list of games...i look at the log and at the end when its trying to use advmame.exe -verify roms or sumthing i get a (flags 17)
then if i get the list to work it will freeze when it starts the game up....any answer on this...im using 1.6.1 mamewah with advmame 95 dos version under a windows 98
Thenasty
  • Trade Count: (+17)
  • Last login:January 29, 2026, 11:38:03 am
Re: Problems with mamewah and advancemame
« Reply #1 on: May 05, 2005, 07:14:00 am »
advmame don't have a  -verify   parameter. Maybe thats causing your problem, just a guess.
Free VGA Breakout Cable
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #2 on: May 05, 2005, 08:33:25 am »
AdvanceMAME doesn't have the -verifyrom flag, so the {autodosbox} flag won't work.
  In your <emu>.ini (in C:\mamewah\ini), change your commandline_format flag {autodosbox} to {nodosbox} and try again.
-sab
GMZombie
« Reply #3 on: May 06, 2005, 04:44:20 am »
alright so i got the game to actually start up but it always freezes on me...what should i do? Always freezes right at the Press ok to continue screen...but when i type it in on the command prompt it will work fine....im using advmame .95 and im gettin pissed that i cant use this...
Thenasty
« Reply #4 on: May 06, 2005, 08:30:14 am »
first change
 misc_quiet no
to
misc_quiet yes
so that way no press this and that garbage.... ;)
and 2nd, what game is it ?
GMZombie
« Reply #5 on: May 06, 2005, 02:29:53 pm »
umm it is all games that do that...any game i choose.
Thenasty
« Reply #6 on: May 06, 2005, 07:20:01 pm »
advmame works fine if you do it manually. But if you launch a game from MAMEWAH, thats when it freezes. Anyone here must have use this 2 together that can guide you more that I do at this point. I'm just a pure Advance Menu and Advmame user.
GMZombie
« Reply #7 on: May 07, 2005, 04:30:13 am »
since i couldnt figure this out i went to advmenu and was wondering if there is a background image i could have besides the white...also is there an option to shutdown windows within advmenu...or is it manually that must be done....as i liked that mamewah was able to shutdown comp from the front end...thanx for the answers
