Author Topic: Lexan?  (Read 4850 times)
wescotte
  • Last login:September 15, 2004, 01:16:15 am
  • I'm a llama! I didn't want to change it
Lexan?
« on: November 25, 2002, 08:22:58 pm »
What exactly is it? Is it simply a fancy name for plexiglass? Just wondering the advantages of using it over a cheaper substance?
Eric
Thenasty
  • Last login:Today at 12:51:27 pm
Re:Lexan?
« Reply #1 on: November 25, 2002, 08:50:27 pm »
correct me if I'm wrong but I think plexi will break in peices if punch hard enought but lexan won't.
Free VGA Breakout Cable
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
Re:Lexan?
« Reply #2 on: November 25, 2002, 08:59:47 pm »
Lexan and Plexiglass are DIFFERENT things.  They look similar but Lexan is very strong compared to plexi.  For your cabinet, don't by plexiglass.  For example, i learned the hardway that if you try to drill any holes in a thin sheet of plexi, the thing will start to crack really bad.  But lexan does not have this problem.  But lexan.  Not much more expensive than plexi and worth it.
Jakobud
hyiu
  • Last login:August 29, 2014, 05:36:15 am
  • too many games... too little time....
    • www
Re:Lexan?
« Reply #3 on: November 25, 2002, 09:06:25 pm »
yeah... lexan is more expensive, but much easier to manage....
if you're getting a new piece to cover the monitor... then I guess buying plexi or lexan does't really make a different...
(since there's no cutting at all other than cut it to size...) and I'd expect noone playing your cab will bang on it...\
but if you're getting something to cover the control panel... definitely get lexan... cos it can be cut and drilled just like wood using the wood drilling bits and saw bits.... much easier to manage....
Another Brilliant mind ruined by education....  :p
SNAAAKE
  • -Banned-
  • Last login:July 21, 2004, 03:44:18 am
  • Banned for abusive postings.
Re:Lexan?
« Reply #4 on: November 25, 2002, 09:41:01 pm »
drilling plexi is not that big a deal but if you have money then go lexan..its about 100% times stronger then pleaxi.However..i love the look of plexi glass compared to lexan..plexi is much shinier then lexan(I used both plexi&lexan)and is cheap solution for my huge panels.
eightbit
  • Last login:September 07, 2019, 07:38:11 pm
  • My cab is never done...
Re:Lexan?
« Reply #5 on: November 25, 2002, 09:56:25 pm »
I prefer glass for the monitor and marquee. I don't like the look of plexi for these.
My statements are my own opinions. They have the value that the reader gives them. My opinion of my opinion varies between foolish and brilliant and these opinions often change with new information.
liche
  • Last login:November 13, 2007, 08:05:18 am
  • This is my BOOMSTICK!
Re:Lexan?
« Reply #6 on: November 25, 2002, 10:45:02 pm »
Well, Plexiglass (TM) is the commercial name for Acrylic.  As you know Acrylic is probably the most difficult plastics to machine due to its brittleness and low melting temperature.  However, acrylic has an extremely high transmissibility constant which means is extremely clear and transparent, hence its use for windows, etc...
Lexan, on the otherhand is the commercial name for Polycarbonate.  Its much easier to machine than acrylic, but is a bit more expensive.  It also has a much higher melting temperature meaning it will be more difficult to thermoform than Plexiglass (acrylic).
wescotte
Re:Lexan?
« Reply #7 on: November 26, 2002, 03:07:18 am »
Weird.. So lexan is easier to make yet cost more? Well.. I was trying to figure out what to use over the CP, Marquee and monitor. I was assuming I'd use Plexi for the marquee since it's cheaper. Glass for the monitor would be ideal but expensive. Lexan seems the way to go for my CP.. Is lexan nearly as transparent as plexi? I mean if I decided to create some sorta artwork for my CP? Or maybe just some texture or something.. Just a thought..
Thanks for the info
Eric
(heheh look at megaman get jiggy with it!)
SNAAAKE
  • -Banned-
Re:Lexan?
« Reply #8 on: November 26, 2002, 11:13:12 am »
its as good...very minor difference...here is a pic of plexi in action...and lexan in action....you figure which look better..first pic is plexi and second is lexan.
You can clearly see that lexan is not AS shiny but works better then anything.
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
Re:Lexan?
« Reply #9 on: November 26, 2002, 12:28:52 pm »
Saying Lexan is stonger is kind of misleading...
Its actually a softer material. Its less brittle thats why it is easier to work with and is more resistant to impact and cracking during drilling, but it's also slightly more prone to scratches than Plexiglass.
My preferance is easlily Lexan though. It's really nice to work with and certainly durable enough for our applications.
If you build a frankenpanel, chances are I don't care for you as a person.
m3talslug
  • Last login:February 07, 2007, 04:22:25 pm
  • I want to Build My Own Arcade Controls!!
    • M3talslug's Control Panels
Re:Lexan?
« Reply #10 on: November 26, 2002, 02:29:54 pm »
Q: What is the difference between Lexan/Acrylic/Plexiglass etc.
A:
Lexan is a trademark of GE plastics.
Plexiglas is a trademark of Rohm & Haas Co.
Lucite is a trademark of E.I.DuPont DeNemours & Co.
Acrylite is a trademark of American Cynamid Co.
Perspex is a trademark of ICI Group.
Lexan is polycarbonate.
Plexiglas, Lucite, Acrylite, Perspex and acrylic are polyacrylate.
Polycarbonate is harder than polyacrylate, and if someone wants to go dig up the physical properties listings, there's probably a wealth of other differences. I don't think it matters much in a case modding context.
Lexan is much more shatter resistant than Acrylic. Acrylic is more scratch resistant than Lexan.
Acrylic is available in different grades:
Extruded material is manufactured by pushing pellets through a highly polished die. There can be slight imperfections in the surface. Extruded material is usually less expensive and more difficult to work with.
Acrylic can also be cast There are different casting methods, with the more expensive material being more uniform in thickness. Cell cast is the highest grade, and continuous cast is in the middle.
courtesy of http://linear1.org/gm/archives/00000136.php
Brax
Re:Lexan?
« Reply #11 on: November 26, 2002, 03:13:47 pm »
It doesn't jive in my head thats polycarbonate is more shatter resistant and yet 'harder'. I would think the two properties are incompatible. I do agree its more shatter resistant.
Just for fun I'm going to do a Rockwell test on the two materials.. I have to get a hold of some Lexan first. (maybe in a few weeks) I'll post the results just for curiousity sake.
I love seeing people use all these fancy resources at their disposal for arcade machines! hehe
