Author Topic: WIP: GAMEBIT update 27-5-2005  (Read 5974 times)
pgielen
  • Last login:January 27, 2023, 10:35:09 am
« on: April 21, 2005, 03:10:45 am »
Hello,
I finally come up for a name for my arcade cabinet.
It's gone be GAMEBIT
I want to use the following picture and vectorice it in adobe illustrator.
This is gone be the first time that i use illustrator and i hope it is possible for me.
If there is anybody that have hints ore tricks for illustrator specially the colouring
I wood appreciate it
Thanks in advance
Patrick
« Last Edit: May 27, 2005, 10:22:57 am by pgielen »
zorg
Re: need hints and triks for adobe illustartor
« Reply #1 on: April 21, 2005, 03:35:29 am »
humm this is an ambitious starting point, anyway you should check the Frostillicuss  tutorial, it was (and still) the starting point for a lot of tracers.
<URL:http://www.localarcade.com/4images/details.php?image_id=223&mode=search>
I'm on the planning stage
pgielen
« Reply #2 on: April 21, 2005, 03:49:00 am »
Thanks for the link, but i already had this tuturial, i hope someone can explain some more about the gradient tool ore an other tool to colour this picture
Bones
  • [Moderator]
« Reply #3 on: April 21, 2005, 04:12:57 am »
I am so far from an experienced Illustrator user that I really don't have a right to give advice, but I will.
This advice involves buying a good Illustrator book and sacrificing a couple of hundred hours fooling around before attempting anything too serious.
Good luck, if you can pull it off that's a cool pic.
pgielen
« Reply #4 on: April 21, 2005, 04:48:08 am »
This is what i have made so far
Bones
  • [Moderator]
« Reply #5 on: April 21, 2005, 07:50:52 am »
Forget the book. You are in control.
pgielen
« Reply #6 on: April 21, 2005, 08:15:18 am »
« Last Edit: April 21, 2005, 08:52:49 am by pgielen »
spriggy
  • Last login:October 07, 2025, 01:33:26 am
« Reply #7 on: April 21, 2005, 08:44:04 am »
Brokenbones1 makes a good point.
If you are planning on playing with AI often, a well illustrated manual does wonders.
I came across some great, simple tricks/tips/concepts this way.
Some good threads linked to AI tips exist on the forum as well.
Search away....
"Once a Knight, always a Knight.   Twice a night.. and your doing alright!!" ::)
mahuti
« Reply #8 on: April 21, 2005, 10:48:23 am »
For coloring... you'll either need to band the colors (instead of the nice smooth transitions) or you'll need to use the gradient mesh tool. I like the gradient mesh tool, but it's a tough tool to master.
http://forum.arcadecontrols.com/index.php/topic,15736.0.html
That topic has a few things that I created using the gradient mesh tool in my younger days.... took some time, I'll tell you. You can do it, but it's tough.
If you are going to use it, use lots of small gradient mesh areas that blend with each other. Don't try to use the mesh tool across the whole thing, or all of the extra bezier points will drive you mad.
dphirschler
  • Last login:February 10, 2021, 10:32:54 am
    • dphirschler homepage
« Reply #9 on: April 21, 2005, 03:35:54 pm »
You don't necessarily have to use the gradient mesh tool.  Try fiddling around with radial and linear gradients.  If you draw the right shapes, then you have remarkable control ofver your gradients.  Also, you can combine a little "banding" with using simple gradients.  And also make use of semi-transparant shapes.
Darryl
pgielen
« Reply #10 on: April 21, 2005, 05:43:15 pm »
Thanks for the replay,
I'm going to find some information about this gradient mesh tool.
mahuti
« Reply #11 on: April 21, 2005, 07:05:45 pm »
The samples that come with Illustrator include one (or more) elaborate gradient mesh examples. Those will give you a good idea of how it works. Based on how complex your illustration is... it could be a major undertaking.
Another sample... the mortal kombat marquee I traced uses the gradient mesh tool
http://localarcade.com/arcade_art/details.php?image_id=25
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
« Reply #12 on: April 21, 2005, 08:49:31 pm »
I think you mean here: http://localarcade.com/arcade_art/details.php?image_id=258&mode=search
You linked to Carnival. ;)
pgielen
« Reply #13 on: April 22, 2005, 04:37:13 am »
I found a link to a tutorial about the gradient mesh  tool
http://www.magicalbutterfly.com/tutorials/meshtutorial/meshtutmain.htm
pgielen
Re: WIP: GAMEBIT
« Reply #14 on: April 26, 2005, 02:52:21 am »
My first update with colour.
If anybody knows some links to coloring tutorials, I wood appreciate it
  • Last login:Yesterday at 08:50:58 am
Re: WIP: GAMEBIT
« Reply #15 on: April 26, 2005, 06:00:51 am »
Looks like you are doing just fine with the coloring so far, lol.  Looks good.
pgielen
Re: WIP: GAMEBIT
« Reply #16 on: April 26, 2005, 06:40:17 am »
« Last Edit: April 26, 2005, 08:59:47 am by pgielen »
Crowquill
  • Last login:November 21, 2024, 09:42:17 am
Re: WIP: GAMEBIT
« Reply #17 on: April 26, 2005, 11:52:08 am »
While I'm not sure what you're using this for, this might have been one case where vectorizing wasn't needed. If you know what issue to look in or find Marvel promo posters you probably could've gotten a high-enough resolution scan to print decent.
Vector art is a great thing, but sometimes not needed. I'm still torn about reproducing hand-drawn art. In many cases we're preserving old artwork that's hard to come by. On the other hand, many times some of the character is lost of the original drawing. In an interview comic superstar Mark Silvestri once made a comment that the stuff you regularly screw up is what becomes your art style. It can be done well (see Felsir's posts), but it is tricky.
Gradient Mesh tool is definitely the way to go to do that type of shading if you want it to look just like the original. Like Mahuti said though, it can be very tricky and very time consuming.
pgielen
Re: WIP: GAMEBIT
« Reply #18 on: April 27, 2005, 02:46:53 am »
I want to use this for my side art.
I want to put some charactors like pacman and donkey Kong on the playing carts.
I found this one on the internet and i really liked it, and i don't now where this picture is coming from.
If there is someone who knows from what issue this picture is, let me know.
Maybe I can use the original picture.because I cant get the colouring part right, I just keep adding and deleting colours.
Maybe I start on vectoring some less complex art , i really liked playing whit AI
BobbyG66
  • Last login:November 13, 2016, 11:52:09 am
  • Current project: Dodgeball
« Reply #19 on: April 27, 2005, 01:01:12 pm »
There's a game called Mortal Carnival?
I gots to get me that!
That would be sweet!
Half of the people you meet are below average.
JonnyBoy
  • Last login:November 12, 2009, 01:59:00 pm
  • Inka Dinka Do
Re: WIP: GAMEBIT
« Reply #20 on: April 27, 2005, 10:59:58 pm »
That is amazing for your first attempt. I am still trying to figure out this $%&ing program and my results are nowhere near as nice as yours. Good job.
I had to beat them to death with their own shoes...
Felsir
  • Last login:July 09, 2025, 03:34:33 am
  • Creating cab artwork
    • Felsir's World
Re: WIP: GAMEBIT
« Reply #21 on: April 28, 2005, 02:00:15 am »
Here is a little hint to get your meshes or colour shadings better. I reduced the image to a 8 shades of grey without dithering. You can see how the colours flow and the directions of the shades. Use the colourpickertool in your favorite (bitmap) graphic software to find out what the colours you need for the gradient.
The greyscale image isn't completely suitable for tracework, but it helps "sensing" how the colours in the image flow. So to get the best results tweaking by hand is required.
pgielen
Re: WIP: GAMEBIT
« Reply #22 on: April 28, 2005, 04:23:15 am »
Felsir,
Thanks for this hint.
I was serious thinking to stop on this project, but i will try it again whit this new input from you
pgielen
Re: WIP: GAMEBIT
« Reply #23 on: May 03, 2005, 04:15:51 am »
OK after a lot of ours playing whit colour gradient and gradient mesh i created this.
This is all the colouring i did so far, let me now what you think of it
Felsir
    • Felsir's World
Re: WIP: GAMEBIT update 3-5-2005
« Reply #24 on: May 03, 2005, 04:18:52 am »
Looks great! Keep it up!
pgielen
« Reply #25 on: May 04, 2005, 03:30:07 am »
a little update, completed the other boot.
pgielen
Re: WIP: GAMEBIT update 13-5-2005
« Reply #26 on: May 13, 2005, 09:26:10 am »
and another update
Veinman
« Reply #27 on: May 13, 2005, 10:18:15 am »
Really coming along! Any guess how many hours you have in this? ;D
pgielen
« Reply #28 on: May 13, 2005, 10:36:34 am »
I spent way to much time in this, i don't even want to know how many ours.
But this is me first piece i try to make, so maybe the next one goes a little bit faster.
If i am so stupid to try to make on other one
pgielen
« Reply #29 on: May 18, 2005, 04:22:12 am »
I fineshed the coat.
I want to add 1 female and 2 male charactors on the playing cards, but i don't know witch one.
I was thinking for the female miss pacman and one male donkey Kong for the other male i have no idea.
If you have a cool character in mind let me know.
Thanks in advance
AmericanDemon
  • The Reason the short bus was invented... 100% Slacker Guaranteed, 4:20 yet?
  • Last login:February 27, 2026, 01:01:31 am
  • Still an AmericanDemon
Re: WIP: GAMEBIT update 18-5-2005
« Reply #30 on: May 18, 2005, 09:14:04 am »
You should either put Dig Dug or Mr Do.  ;)
pgielen
« Reply #31 on: May 27, 2005, 10:21:10 am »
And another update.
it is almost complete now  ;D
I am just not so pleased whit the playing cards, if there is anyone who have some idea about them let me know.
Dire Radiant
  • Last login:January 23, 2025, 06:30:10 pm
  • Cor, chief!
Re: WIP: GAMEBIT update 27-5-2005
« Reply #32 on: May 27, 2005, 02:01:43 pm »
Make each card like an ace of spades but instead of a large spade, have the three types of space invader.
pgielen
« Reply #33 on: May 27, 2005, 04:33:19 pm »
sounds good, i will give it a try
