Author Topic: GunCon2 driver here!!! (Bacon is tasty)  (Read 263122 times)
quarterback
Re: GunCon2 driver here!!! (Bacon is tasty)
« Reply #320 on: May 14, 2005, 06:20:56 pm »
There are very few actual details for the stand-alone video amp on his website, but here's the link.
http://www.ultimarc.com/JShopServer/product.php?xProd=12&xSec=2
More info here:
http://www.ultimarc.com/vidamp.html
-- Chad Tower
vibez
  • Last login:February 09, 2011, 08:33:20 am
« Reply #321 on: May 14, 2005, 06:29:35 pm »
Just to confirm, do I hook the RCA ground to a normal ground, or the video ground on the jamma connector?
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
« Reply #322 on: May 14, 2005, 06:35:31 pm »
video ground
MiKman
  • Last login:September 15, 2025, 07:58:44 pm
  • Blah
« Reply #323 on: May 14, 2005, 07:00:53 pm »
Thats a good point. But I ment how would we wire up 2 guns. How would we connect the 2 rca cables & usb ports.
once you have soldered on an RCA connector (where ever you are going to do that) 2 guns is easy.  my guncon2 came with an rca Y splitter so a second gun can be hooked up.  Then it's just a matter of having an extra USB port to plug it into and having mame support 2 guns...  Should be a cinch  ;D
vibez
« Reply #324 on: May 14, 2005, 07:41:59 pm »
ok i've hooked it up to my jpac. Not much to say really. Once I plug it in, the cursor just moves to the top right of the screen. Nothing I do with the gun moves it. But when I move the mouse, I can only shift the cursor about 5 pixels up or down. I Dont know what to make of this. Interestingly enough, I tried the control panel & when I try to test the buttons. None of them work
« Last Edit: May 14, 2005, 07:43:35 pm by vibez »
DaemonCollector
« Reply #325 on: May 14, 2005, 07:44:48 pm »
if your buttons arn't working it sounds like the driver might not be installed. Did you make sure to install it properly?
vibez
« Reply #326 on: May 14, 2005, 07:48:27 pm »
the 'new hardware detected' box poped up & I pointed it to the driver folder. I guess thats all I needed to do?
DaemonCollector
« Reply #327 on: May 14, 2005, 08:13:34 pm »
hmmmm...go to your device manager and make sure under pointing devices, theres an "HID-Complient Mouse", if there is right click it anc check properties. Does it say GunCon Device there?
vibez
« Reply #328 on: May 14, 2005, 08:42:39 pm »
ok it works at 800x600, but not at 640x480 which is the interlaced display the arcadevga forces at this res. Intrestingly the buttons only show up in the  control panel when at 800x600.
DaemonCollector
« Reply #329 on: May 14, 2005, 08:43:51 pm »
thats messed up...haha. I had mine running at 640x480 interlaced. How is your gun performing?
vibez
« Reply #330 on: May 14, 2005, 09:29:51 pm »
same as yours I think. dead zones on the left of the screen & Tracking is off by an inch. Looks like this wont work with a jpac & arcadevga due to the interlaced modes the arcadevga puts out. unless i'm missing something.........
Smog
  • Last login:April 30, 2007, 06:50:51 am
  • .357
    • How to make a cheap GunCon2 work on your PC
« Reply #331 on: May 14, 2005, 11:06:53 pm »
Don't know why you are having this problem but it surely does not depend from interlace. 640x480 is an interlaced res just like 800x600 is, in fact you could not display neither 640x480 or 800x600 in progressive mode on a NTSC monitor....
V.0.04 is OUT. Please update.
GunCon2PC Driver on http://guncon2pc.no-ip.org/
MiKman
  • Blah
« Reply #332 on: May 14, 2005, 11:54:03 pm »
Anyone else with a real guncon2 not getting all the buttons to register properly?  particularily the trigger?
Billkwando
  • Last login:February 08, 2024, 10:42:45 pm
« Reply #333 on: May 15, 2005, 01:18:54 am »
I have a real Guncon, but the only thing that isn't working is the B button on the right side (unless the thumbpad is supposed to work which I don't think it is).
"If you believe you're up against a swordsman who is proficient in the Way, you will lose."-Miyamoto Musashi
IntruderAlert
  • Last login:May 02, 2007, 09:10:59 am
  • Chicken.. Fight Like A Robot
    • Intruder Alert
« Reply #334 on: May 15, 2005, 01:31:35 am »
domenica, 15 maggio 2005
Since I am facing more problem than expected setting up a piece of code in the driver, I feel I MUST release something even if not complete just to quiet your hunger
This mean that the new release is not a major one but still full of news.Here we go :
Whatsnew v0.04
control panel executable included in driver .zip file, not yet as a real installation pack.
Added support for :
   . Custom Edge values
   . Enable/Disable selfcalibration
   . Button Remapping
   . Pointer sensitivity regulation
VIM (Very Important Missings) / Todo list :
  . Saving results of selfcalibration
  . Implement centering
  . Write manuals / help
  . HID interface selection
Postato da: SmogDragon a 04:55 | link | commenti (2)
http://lightgun.splinder.com/
vibez
« Reply #335 on: May 15, 2005, 07:11:45 am »
Below are my findings to date with a jpac/arcadevga setup. If anyone is running a similar setup, please post your finding.
Here is my setup
XP pro sp2
ArcadeVGA 9200 videocard
j-pac
15Hz hantarex polo monitor
Guncon2 Compatible Logic3 P99L Laser Blaster
I didn't need to build the circuit as the jpac does everything the circuit does. I hooked the gun up to the Vsync &Vgnd on the jamma connector.
I have tested this setup on all the modes supported by the arcadevga. Starting at 240x240 & going all the way up to 1024x768
The guns seems to work as well as everyone else says. There are a few dead spots & the cursor seems to be tracking about an inch off.
The trouble is that the gun doesn't even register at the following resolutions.
512x448
512x512
640x480 <<<- Big worry, as this is my prefered res!!!
1024x768
The buttons don't even work when in the control panel. The gun never takes over from the mouse & it is as if the gun isn't attached.
The arcadevga manual states that "the Windows desktop, by default is displayed at 640 X 480" Maybe this has something to do with it?
Another point worth mentioning is that the accuracy of the gun changes at different resolutions. Does this mean we need to re-calibrate if we switch resolutions?
« Last Edit: May 15, 2005, 10:38:04 am by vibez »
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #336 on: May 15, 2005, 10:33:07 am »
Doesn't the jpac take the sync to a 5v point to point signal??
I thought the gun needed a 1 volt.
Later,
dabone
IntruderAlert
    • Intruder Alert
« Reply #337 on: May 15, 2005, 07:48:44 pm »
vibez, where exactly did you connect the gun to the jpac?
which pins?
looking at this page: http://www.ultimarc.com/jpac2.html on the J-PAC JAMMA Edge connector pinouts
it says that there is a composite sync on "P" (Solder Side) and a video ground on "14" (component side)
Have you connected "P" to the center connection of the RCA connector and "14" to the outside connection of the RCA connector?
AlanS17
    • AlanS17
« Reply #338 on: May 15, 2005, 08:32:02 pm »
Getting this working with a J-Pac shouldn't be much different from using the video amp. Just splice the sync signal leading from the JAMMA edge connector into the monitor. If you're having a hard time singling out that specific wire, check below. It'll show you what's what. Make sure you're pulling from the correct side (solder side). Just look for the placement of the "key" (the plastic notch that tells you which side is up).
Anyways, here's a JAMMA pin configuration diagram...
http://www.mameworld.net/pc2jamma/images/jamma.gif
MiKman
  • Blah
« Reply #339 on: May 15, 2005, 10:11:06 pm »
Well I decided to take my 'new' gun apart and I found out why my trigger doesn't work. Yhe plastic peice that hits the switch when you squeeze the trigger is cracked at the thinnest point and just flexes when you squeeze the trigger instead of pushing the switch >:( not a happy camper... gonna try and glue it with some epoxy tonight, hope it holds...
IntruderAlert
    • Intruder Alert
« Reply #340 on: May 15, 2005, 11:51:07 pm »
don't feel bad..
this is a great excuse to try hacking a real arcade gun with guncon2 parts! ;)
daveg2000
  • Last login:January 02, 2009, 08:55:51 pm
  • PSP? Yeah right. GP2X Baby! This thing is awesome
    • www.davegrams.com
« Reply #341 on: May 16, 2005, 01:21:24 am »
Hey guys.. I just flew threw the 9 pages of stuff here and looks as if
brandon's S-video to Composite 'hack' still is not able to be calibrated?
(or did I miss an update to that somewhere through the posts?)
I'm ready to pick up a GunCom2 and start hacking up wires to help
out if I can.
I have a S-Video out (not composite) on my Video Card and
am interesting in testing stuff out if need be.
I wasnt able to get the TV-Out ActLabs gun to work on my 32" tv,
(it wouldnt go down past a certain point on the screen - whatever that meant)
and am ready to start goofin around w/something new.
I tried to pick out all of the S-Video chat in the last few pages, but it looks
as if discussion went to force feed back and VGA connections....
Can anyone get me up to speed so I can figure out how I can help?
(I just re-cooped from frying out my Motherboard AND Powersupply in my
PC... so Im ready to start blowin stuff up agian!  haha)
...so I will ask you... "Deal, or No Deal?"
brandon
  • Last login:December 26, 2025, 08:29:45 pm
  • I <3 arcade games.
« Reply #342 on: May 16, 2005, 01:50:10 am »
out if I can.
vibez
« Reply #343 on: May 16, 2005, 04:00:59 am »
To IntruderAlert & AlanS17
Yes I have connected it up correctly to the jamma board. The inside wire of the rca connects to 'P' & the outer braid connects to pin 14. As mentioned, This is working in 90% of the resolutions I can choose. In fact I would say the gun tracking is working better than what most people are experiencing. The cursor is lining up perfectly with the gun, just experiencing about 10mm of dead spots in the corner of my screen.
The problem is that when I run in either of these resolutions
512x448
512x512
640x480 <<<- Big worry, as this is my preferred res!!!
1024x768
The composite signal from the arcadevga/jpac must be changing, as the gun is no longer detected.
Those of you using a videoamp, are you using an Arcadevga too? I really cant understand why the signal is changing at those resolutions causing the gun not to work????
EDIT:: Andy is a top guy!! I have emailed him about the problem with the gun & an arcadevga/jpac setup. He's buying a gun & will inverstigate :) Stay tuned........
« Last Edit: May 16, 2005, 10:12:57 am by vibez »
AlanS17
    • AlanS17
« Reply #344 on: May 16, 2005, 10:14:10 am »
512x448
512x512
1024x768
Are you saying that 800x600 is actually working? Did you try that one?
vibez
« Reply #345 on: May 16, 2005, 10:58:14 am »
800x600 is working fine here. BUT the big problem is my monitor (and most arcade monitors) only support up to 640x480, therefore the picture doesnt fit on the screen, so you wont see the edges of your games
Flinkly
  • Last login:March 14, 2017, 01:14:21 pm
« Reply #346 on: May 16, 2005, 12:10:42 pm »
i said it before, but everyone seems bent on the video amp and jpac connnections.  couldn't you just hook the gun up to the second video port on an arcade vga card and do a dual screen with the video card?  in my mind it should work, and you wouldn't have to worry about video quality since it doesn't go to the screen, but it would be the same image...
feel free to point out my mistakes.  the only problem i can see is all the extra work (and heat) for the video card.  i guess it might not target as well due to poorer quality of image...but i still haven't checked what kind of second port connection is on the newer arcade vga.
AlanS17
    • AlanS17
« Reply #347 on: May 16, 2005, 12:27:33 pm »
vibez
« Reply #348 on: May 16, 2005, 12:51:11 pm »
I think I read somehwhere that the video quality isnt very good at all. Which would backup your point about the tracking being off. If you tell me what to do, then I can give it a road test
markb
  • Last login:April 30, 2011, 06:41:02 am
  • The One and Only.
« Reply #349 on: May 16, 2005, 05:38:10 pm »
Looks like Smog and Andrea at advancemame have had some success in getting 2 guncons working. ;D ;D ;D
AlanS17
    • AlanS17
« Reply #350 on: May 16, 2005, 10:10:23 pm »
I finally got my guncon2 in this afternoon. Got my VGA universal mount monitor up and running too. Now I just gotta get it all working together...
daveg2000
    • www.davegrams.com
« Reply #351 on: May 16, 2005, 11:41:54 pm »
I dont know how far this will get,
but is there any chace the topic of GunCon development
can get spit up into the 4 main categories?
VGA, Composite, SVideo and Arcade Monitors?
For example someone (like me) who has been trying to follow
the converstaion on SVideo development has just had to weed through
9 (soon to be 20) pages of conversation on all of the various topics.
It gets fustrating for some of us that wouldnt have interest in all of these
different areas..... Or for someone new trying to figure out what
is being talked about every few posts....
If you dont like the idea, thats okay..... its just  a thought.
It seems as this topic is HOT right now and will continue to be for a while....
Laterl
Flinkly
« Reply #352 on: May 17, 2005, 02:28:45 am »
someone could do a recap for those respective kinds of monitors every once in a while, but you'd have to get one of the spearheaders to do it since most of us are like you and just following one kind, or someone who understands all this could do it...
as for the arcadevga tryout (vibez), just hack the appropriate cable to plug into the second arcadevga output, and then go to preferences (from the desktop) and output to a second monitor.  since i can't try it out, i can't tell you exactly what to do.  you might not be able to do it at all since windows might not see another monitor hooked up, or like alan said, it might not work due to a different signal or poorer quality.  it's not too big of a deal to try out, since we should be able to do it our original way by splicing in our gun between the monitor and the card.  good luck if you do try it.
DaemonCollector
« Reply #353 on: May 17, 2005, 02:31:31 am »
I tried hooking up to the composite and windows won't let me, because as you said windows dosn't see a monitor hooked up. So unless somone knows how to force the TV display, theres no real way to test this.
forbiddenlyrics
  • Last login:July 10, 2010, 03:19:34 pm
  • I'm Bart Simpson Who The Hell Are You?
« Reply #354 on: May 17, 2005, 03:46:29 am »
Man I got a GunCon2 at goodwill like 2 months ago for $3. Now I can finally use it! I'll be trying this as soon as I have a few spare moments.
brandon
« Reply #355 on: May 17, 2005, 11:05:57 am »
your video card has to be connected to a TV to get the composite sync from the TV out.  if you are trying to use a PC or arcade monitor but get the sync from the TV out that wont work as far as I know.
Flinkly
« Reply #356 on: May 17, 2005, 12:42:13 pm »
actually, my radeon on my normal comp lets me turn on dual monitors displaying the same screen even when i don't have anything hooked up to it, so it should work to be able to turn it on...windows shouldn't give you any problems.
the more i think about it though, the less i think it will work (or could).
brandon
« Reply #357 on: May 17, 2005, 12:50:48 pm »
yeah.. because the gun has to sync with the display that its pointing at.  Getting sync from a TV and pointing at a PC monitor doesnt work.. I tried clone mode already for the heck of it..  I dunno about with an arcade monitor instead of PC but I have my serious doubts about it as well.
IntruderAlert
    • Intruder Alert
« Reply #358 on: May 17, 2005, 01:45:29 pm »
I've got a "How To" web page made but I need a host
IntruderAlert
    • Intruder Alert
« Reply #359 on: May 17, 2005, 02:06:07 pm »
Laterl
OK i've posted over here but it has banners >:(
http://intruderalert.bravehost.com/GUNCON.htm
If someone else wants to host it instead please do so
Thanks to everyone who contributed
