Author Topic: I found a way to completely hide BIOS boot screen!  (Read 12352 times)
SadGamerGeek
  • Last login:November 27, 2005, 06:23:54 pm
    • Sad Gamer Geek
« on: March 17, 2005, 04:52:35 pm »
I'm always getting great advice from this forum, so I'm pleased I might finally be able to post something useful to others. This may be already well known, but I haven't seen it mentioned.....
As I've managed to hide all traces of Windows XP, the BIOS screen is the last thing on my set-up that really gives the game away that a normal PC is at the heart of my system. My BIOS doesn't allow a graphic to cover all the "detecting Hard Drive" type messages, so that wasn't an option. At the suggestion of a friend at work I did the following:
1. Added a (very cheap) PCI video card (already have AGP one) to PC
2. Set "Video Card" to "PCI" (instead of AGP) in BIOS set-up screen
3. Reboot PC
For me, that's all I had to do.  The BIOS messages (and Windows boot screen) are now output-ed only on the PCI card. As my monitor is still plugged into the AGP card, the screen stays completely blank until Windows starts (with MameWah as my shell). If I need to make any BIOS changes I'd need to plug the monitor into the PCI VGA output, but that will be an extremely rare occurrence.
I was expecting to need to disable the PCI card in Windows, but XP hasn't even noticed the addition of the card.
Result!
This is probably quite set-up dependant, but it worked a treat for me, and I would hope it will be useful info for others....
Cheers,
Richard
Onid
  • Last login:April 28, 2005, 07:40:06 pm
Re: I found a way to completely hide BIOS boot screen!
« Reply #1 on: March 17, 2005, 04:58:30 pm »
Good idea. Hope you remembered to turn off the Windows start chimes to as this is always a dead PC give away.  ;D
SadGamerGeek
    • Sad Gamer Geek
« Reply #2 on: March 17, 2005, 05:00:34 pm »
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #3 on: March 17, 2005, 06:05:44 pm »
Very helpful!  Me likes!  Which card did you use?
SadGamerGeek
    • Sad Gamer Geek
« Last Edit: March 17, 2005, 06:28:19 pm by SadGamerGeek »
Chris
    • Chris's MAME Cabinet
« Reply #5 on: March 17, 2005, 09:04:58 pm »
Another quick and easy solution is to plug in an Act-Labs gun.  You won't see anything until the mouse drivers initialize.
--Chris
--Chris
jcrouse
  • Last login:January 09, 2010, 05:53:51 pm
    • CPViewer
« Reply #6 on: March 17, 2005, 11:14:20 pm »
Thenasty
  • Last login:February 13, 2026, 10:27:24 am
« Reply #7 on: March 18, 2005, 06:42:18 am »
Free VGA Breakout Cable
jfunk
  • Last login:October 24, 2018, 04:36:39 pm
  • BYOAC Wannabe
    • JFunk's Arcade
« Reply #8 on: March 18, 2005, 08:21:04 am »
Another way to hide the boot info is with a custom BIOS boot screen.  Finding a mobo that'll let you override the default can be difficult, though.  I found a GREAT one for my setup:
ASUS A7N8X-VM/400
Has the MyLogo2 ability (for a 256 color custom boot screen), onboard almost everything (for ease of use) and is a SOLID mobo as well.  Runs Athlons or Semprons..
Anyways, the bios boot screen stuff is SUPER easy.  My PC boots into MAMEWAH (through XP) and it's pretty darn hard to see the tell-tale signs of the computer/OS..
Thanx!
chemame
  • Last login:January 26, 2007, 01:54:05 pm
« Reply #9 on: March 18, 2005, 09:29:03 am »
--Chris
Is this true only of the VGA version maybe? I run two act-labs svid-out guns, and I have my signal immediately upon boot, bios screens and all. The only time I DON'T get a signal through the gun video lines is if the USB is not properly connected.
Errr.... and when the svideo line gets pulled out of my video card, that is   ;D
Che
drunkatuw
  • Last login:April 24, 2025, 02:25:30 pm
    • Drunk at UW.com
« Reply #10 on: March 18, 2005, 10:53:10 am »
--Chris
Che
I have 2 s-video guns and I do not see the bios or any boot screens.  The first thing I see is the windows splash screen.
Scoobie
  • Last login:December 26, 2024, 12:53:48 am
« Reply #11 on: March 18, 2005, 11:11:38 am »
Now, if only I could get rid of that windows splash/welcome screen... ???
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
« Reply #12 on: March 18, 2005, 01:49:39 pm »
Also, how can I remove/change the windows chimes/noises on startup/shutdown?
Start / Settings / Control Panel / Sounds and Audio Devices
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
« Reply #13 on: March 21, 2005, 02:02:34 pm »
THANKS!
This solution is the *BEST*. Not only did it hide my bios, it hid my Windows Startup screen (which I had already hacked to be a screenshot of one of my favorite games).
It took no effort - I did not have to make any BIOS changes since the PCI card already overrides the onboard video.
And the results are phenomenal! Now the first thing you see is MAMEWAH!
Thanks again. This post should be included in some sort of "How to hide windows" FAQ / Hall of Fame.
Joseph Elwell.
