Author Topic: Problem with DMAME and Arcadeos  (Read 1777 times)
Craig
  • Last login:September 29, 2014, 05:51:56 am
    • Creation on the Web
« on: March 06, 2005, 05:19:28 am »
I have set up a box with dmame and Arcadeos.
Arcadeos loads fine. Dos MAME runs games fine from the command line.
The problem is, when I run games from Arcadeos, the game loads fine but when I press ESC to exit the game back to Arcadeos, it comes up with this error which fills the screen and I have to reboot.
Bad command or file name
etc etc.................
It seems that it is trying to maybe load a program while exiting MAME.
Has anyone got any ideas about this? Anything I could try and change or look at?
Thanks for any help.
I love the life I lead. I wish I could afford it.
elvis
  • penguin poker
    • StickFreaks
Re: Problem with DMAME and Arcadeos
« Reply #1 on: March 06, 2005, 06:34:49 am »
First place I'd be looking are all and any .bat files on the system.  Starting with the autoexec.bat and working from there.
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #2 on: March 06, 2005, 07:46:57 am »
It does it forever, or did you not wait, tried to either ctrl-c and it didn't work, so you hit reset?
Craig
« Reply #3 on: March 06, 2005, 07:59:23 am »
It did it forever, and didn't see the HDD light ticking so I rebooted.
CTRL+C or +X or +Q didn't do anything. I haven't seen it happen before.
SirPeale
« Reply #4 on: March 06, 2005, 08:12:28 am »
It appears it's trying to load something when Mame stops.  You did say  you can launch a game right from AOS, right?
Craig
« Reply #5 on: March 06, 2005, 08:21:15 am »
I can run a game from it but when it exits, it comes up with that error.
Thenasty
  • Last login:January 22, 2026, 11:19:58 pm
« Reply #6 on: March 06, 2005, 10:34:27 am »
sounds a loop (BAT) but CTRL-C shoul dhave broken it.
Free VGA Breakout Cable
Craig
« Reply #7 on: March 07, 2005, 10:17:35 pm »
Here is the latest.
Installed the earlier version of mame (0.68), disabled the autoexec.bat and config.sys so nothing was running except DOS. Installed an earlier version of arcadeos (2.47), was running 2.52. Loaded arcadeos, ran a game, exited, did the same thing. Bad command or file name.  Could this have something to do with my hardware? What is it looking for?
Craig
« Reply #8 on: March 07, 2005, 11:28:39 pm »
I tried it on another system and it still comes up with that error. Bad command or file name.  ???
SirPeale
« Reply #9 on: March 08, 2005, 07:28:54 am »
The only thing I can think of is you're doing something in your setup that isn't liked (obviously) but why it would cause it to loop, that I'm not sure of.
So, just to make sure:
1) Your autoexec.bat and config.sys has *only* the bare minimum needed for starting properly (himem.sys, sound drivers and sound declaration, etc)
2) The PATH variable is set correctly in your autoexec.bat
          PATH .;c:\dos;
    be sure that period is there, it states current path as the first place to look.
3) at the end of autoexec.bat, it changes to the AOD dir
          cd \arcadeos
    then launches in the next statement
          arcadeos
Thenasty
« Reply #10 on: March 08, 2005, 07:32:16 am »
Here is the latest.
Craig
« Reply #11 on: March 08, 2005, 08:31:21 am »
Problem solved.
I remembered never having this problem in the past. This time I had all my ArcadeOS files in the root of c:\, so I moved them into a seperate folder c:\aos and it works fine from there.
Thanks for the suggestions and comments.
Now for some gaming.......  :D :D :D :D
