Author Topic: beginner question regarding trackball\hole saw  (Read 1284 times)
milhouse
  • Last login:March 02, 2023, 08:03:32 pm
« on: March 04, 2005, 03:41:25 pm »
I ordered a 2.25" trackball from Ultimarc and am making my first (of many, probably) trips to Home Depot. I did not get a mounting plate and I was planing on using thin metal to make my own.  Obviously I will need to have a round hole for it.  So do I need  a 2.25" hole saw? Or is that the diameter of the ball itself, making the hole size smaller?   I also know there is a small lip around the trackball that looks to be about a quarter of an inch wide.  Does that change the hole saw size?
Sorry its a stupid question, but I couldn't find any answers searching the board (you'd be surprised how often hole saw and trackball are posted).
Also, just to be safe, a standard button hole saw size is 1 1/8", correct?
Thanks.
Thenasty
  • Last login:December 04, 2025, 11:40:37 am
Re: beginner question regarding trackball\hole saw
« Reply #1 on: March 04, 2005, 03:54:22 pm »
it will actually cut the hole around the LIP size. The 2.25 hole saw is just right for it.
Free VGA Breakout Cable
alex627
  • Last login:March 04, 2005, 07:50:28 pm
« Reply #2 on: March 04, 2005, 07:22:38 pm »
Dial saws are very nice. Less grabbing than a hole saw AND they are adjustable. Hole saws generally kinda suck. They get hot and grab. MDF is dense and gummy so the heat can be a problem. If your using plywood then hole saws are fine.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: March 04, 2005, 07:47:59 pm »
I ordered a 2.25" trackball from Ultimarc .... So do I need  a 2.25" hole saw?
2.25", yes.
Hole saw, fostner, blade type all work, some better in different materials.  Since you're doing metal, I'd suggest a metal cutting hole saw.
Yes the ball is also 2.25".
umm, see your next question
yes.  The hole would be smaller, but the lip changes the hole size back to 2.25".  And yes, the lip totals ~1/4" (1/8" on each side).
Not a stupid question.  You knew enough to understand where all the factors came in, but not how they finally ended up.  Which is the perfect reason to ask, after searching of course.
Not really, not everyone searches like you did.  :)
The standard is 1 1/8", yes.
Thanks.
Welcome. :D
Robin
Knowledge is Power
milhouse
« Reply #4 on: March 04, 2005, 10:55:29 pm »
Thanks guys
