Author Topic: Ps/2 to USB Mouse?  (Read 1320 times)
Voodooray
  • Last login:July 24, 2006, 04:52:41 am
  • Load ya swine!!!!!
Ps/2 to USB Mouse?
« on: March 03, 2005, 03:16:17 pm »
Hi everyone.
I have built a spinner using a PS/2 mouse and i was wondering if i could convert it to USB?
I know you can get little plugs that will change one to the other but i have some solderable USB plugs and i wondered if i could just re-wire it.
Also if i did, would it still work in mame?
Thanks in advance.
Voodoo Ray
88 Acid Revival, Safe!
Voodoo Ray.
spystyle
  • Thanks alot, now I have to build a time machine and warn myself yesterday!
  • Last login:February 23, 2021, 02:30:18 pm
Re: Ps/2 to USB Mouse?
« Reply #1 on: March 03, 2005, 03:27:33 pm »
It seems more sensible to use the adapter plug than to permanently convert it  ???
But, if you are determined to, I bet you could google up the "pin outs" and come up with something
Thenasty
  • Last login:February 03, 2026, 08:27:56 pm
« Reply #2 on: March 03, 2005, 04:36:41 pm »
Thanks in advance.
Voodoo Ray
keep it in mind for the future that if your CONTROLS work in WINDOWS, it will work with MAME.
Free VGA Breakout Cable
Chris
    • Chris's MAME Cabinet
« Reply #3 on: March 03, 2005, 04:45:27 pm »
Hi everyone.
The mouse has to be designed to work with one of those adapters.  You can't just plug any old mouse into one. The mouse has to detect it's plugged into USB instead of PS/2 and adjust its output accordingly.
--Chris
--Chris
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #4 on: March 03, 2005, 05:55:26 pm »
I found a small mouse from a 1996 computer and I threw a PS2-USB plug on it and it actually worked.
ften
  • Last login:March 06, 2022, 10:20:43 pm
  • Beep Beep
    • Fathertom.net
« Reply #5 on: March 03, 2005, 06:26:11 pm »
I just happen to have a picture of what the inside of those adapters look like.
http://www.fathertom.net/xbox/Xboxmem.htm
Although I used it used it to modify a Xbox memory card you can see from the picture it's basically just strait wire connection.
pin
« Last Edit: March 03, 2005, 06:28:31 pm by ften »
Voodooray
« Reply #6 on: March 04, 2005, 11:03:33 am »
Thanks for the info gang!
Might have a bash at it this weekend.
On a different note, i just wanted to say how greatfull i am that you all take time to answer my questions.
Much appreciated ;)
Voodoo Ray
Voodoo Ray.
NoOne=NBA=
« Reply #7 on: March 04, 2005, 02:34:24 pm »
Out of curiousity, what will this accomplish for you, other than allowing it to hot-swap?
